Question about Minolta 280PX TTL Flash
My Minolta flash 280px does not sync with my Minolta x700
2 Suggested Answers
Rick Riggins
  • 1812 Answers
SOURCE: foam is falling out & sticky in my minolta x700
This is light seal material that keeps the film chamber light tight to prevent contamination of the film. If this is bad, chances are the camera itself will need some servicing. The light meter and shutter speeds need to be calibrated as well as the lubricants changed in the cameras various mechanisms. This can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Posted on Aug 14, 2011
Shutter Curtain Doesnt Reset Mirror
If your shutter curtain doesnt close, it may be out of Sync with the shutter button. My Minolta x700 had this problem. My camera guy fixed it for me with a couple of tinker moves. Contact your nearest camera repair shop (if available) and ask how much it would be to fix the Sync between depressing the shutter button and the curtain. it may just be some grime that has it stuck.
Mar 18, 2014 | Minolta X-700 35mm SLR Camera
Minolta auto 280px
Did you put them in the right way? did you check all contacts in the speed light / electro flash? is needed, please clean the contacts. If you did not use this speed light for a long time, some contacts (also from the switches) could be corroded. when you sure you have the right batteries, correct inserted, and it won't start. try pushing the on / off several times. ( no pressure will be needed)
Don't use manganese (Zinc-Carbon) batteries. Best choice would be NiMH.
Nov 26, 2013 | Cameras
Minolta x700 will not flash when shutter button is depressed. Also, with the flash attatched, the shutter will open and not shut...like with a long exposure, then when it shuts, the flash will fire. I...
How does it function without any flash attached? If it only malfunctions with this flash attached I'd bet it's an issue with the electronics in a dedicated flash. If that's not the case, either consult a local tech, KEH Camera online, ebay the camera, or scrap it.
Jun 13, 2011 | Minolta X-700 35mm SLR Camera
I don't know how to load or unload the film for my Minolta x700
You can download the manual from
http://butkus.org/chinon/minolta/minolta_x-700/minolta_x-700.htm
There are illustrated instructions for loading/unloading film beginning on page 17.
Feb 22, 2011 | Minolta X-700 35mm SLR Camera
MY MINOLTA X700 WONT TURN ON
Check your battery first. Make sure it working well. If still fails, you have internal problem and need a service on dealer.
Regards
Dec 17, 2010 | Minolta X-700 35mm SLR Camera
I have a minolta x700 and xg1. the film advance leaver will not work on either one
get it serviced,CLA by a camera tec,since both cameras require mantainec.
Mar 05, 2010 | Minolta Photography
Minolta x700 winder broken off camera
needs repairing at a qualified shop
when was it last cleaned or serviced ?
if you think the camera is worthy, since its old how much is it worth to you vs a new one
May 22, 2009 | Nikon FM10 35mm SLR Camera
User Manual
Here's a link to the manual:
http://www.angelfire.com/ca4/shikishima/manual/x700.pdf
Mar 02, 2009 | Minolta X-700 35mm SLR Camera
35 mm, Minolta X700
Is the re-wind button stuck in? If so it can be released by moving the take-up sprocket manually. If that did not work there is a broken take up gear. This was a common problem with the X700, a white plastic gear was used at the bottom of the take up spool mechanism that just was not strong enough especially when trying to get just one more shot from the roll of film. No new parts are available.
Sep 20, 2008 | Photography
Minolta 280PX TTL Flash Logo
62 people viewed this question
Top Minolta Cameras Experts
David Payne
David Payne
pontelemon
pontelemon
Tony Parsons
Tony Parsons
Are you a Minolta Camera Expert? Answer questions, earn points and help others
