Question about Refrigerators
Not cooling fridge not cooling but u can hear fan running,feel slight breeze,freezer on bootom same as top,hear motor running feel breeze but everything started to defrost
  • Refrigerators Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezernot cooling - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Jun 05, 2010
My GE fridge (gss25jemaww) stopped cooling. The light still goes on and off like normal, and the motor works, but the fridge and freezer do not cool anymore. Everything inside thawed.
This tell me the compressor is not running. I would like you to pull the fridge away from wall unplug and remove the cover over the compressor. Feel top of compressor and if too hot to hold hand there keep unplugged and let me know. There are some test I would like you or someone skilled with a test meter to do to eliminate the compressor start components and motherboard. Sea Breeze
Jan 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My 5 year old fridge/top freezer ge profile just stopped cooling, motor running but no cooling
First thing I need you to do is unplug pull away from wall and remove the cover over the compressor. Feel the top of the compressor and if too hot to hold your hand on the top leave the refrigerator unplugged until we can decide if this is the start components or another part like a fan not working all the time. I will send a manual and be available for assistance if you want, Thanks, Sea Breeze
Jan 24, 2010 | GE Profile Arctica Stainless Steel Top...
Freezer is cold... fridge is not
Could you pull it away one more time and feel the compressor to see if cool, warm or too hot to hold your hand on. That tells me a lot of things. I want to see if your compressor is shutdown, running but not cooling or trying to start and cannot. That will help me to answer what we need to do next. Sea Breeze
Aug 19, 2009 | Refrigerators
Problems with Whirlpool 21.0 cu. ft.
checklist: freezer fan running, compressor fan running, compressor running, any frost buildup on back wall of freezer. you may have to take a rag and touch the compressor to feel if its vibrating to see if its running unless you can hear it. please reply
Jun 12, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Warm fridge
If you are sure the fan is running either the damper motor (vent in fridge section) is bad and not opening or there is ice in the return vents and not letting air circulate. Take out the bottom drawers in the fridge and look down the two return vents in each corner with a flashlight. If they are iced up the top will not cool.
Nov 17, 2007 | Maytag MFD2560HES Bottom Freezer French...
Refrigerator compartment not cooling
If you are sure the fan in the freezer is running and you don't feel any air flow out of the top middle vent inside the fridge section, then the damper motor must be bad. The damper motor is behind that vent cover inside the fridge section.
Nov 16, 2007 | Amana AFD2535DES French Door Refrigerator
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Thanks
Carol
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Roper fridge not cold
That is then the first thing you will need to insure is running. The fan can be removed and checked. Now if the compressor is not running I would believe you have another problem. You can hear or feel the compressor running and the fan is usually connected to the compressor wiring so they both should be running at the same time. I have seen the fans run for a short period of  time after the refrigerator was turned off and then back on after cooling, so if stopped and starting of the condenser fan can at times trick you to believe the fan is OK
 Hope I have been helpful, Sea Breeze
Oct 28, 2007 | Roper RT21AKXKQ Top Freezer Refrigerator
Tfx27fhc
The most common problem is the evaporator fan motor which is located behind the back panel of the freezer and it moves cold air up to the fridge.  You will be able to hear it when you open the freezer door.  May have to hold the light switch in the freezer shut for it to come on.  If the fan is running feel for air flow out of the vent in the top middle of the fridge section.  If you don't feel air and the fan is running then the damper motor behind that vent is bad.  All of this is assuming that there is no frost buildup on the back panel of the freezer.  If there is frost buildup then it is a defrost problem.  Let me know what you find.
Oct 10, 2007 | Amana Easy Reach AFD2535DE Bottom Freezer...
Warm fridge, cold freezer...
Listen for a fan running when you open the freezer door. May have to hold the light switch closed for it to come on. If you don't hear it then the fan is most likely bad. The evavorator fan motor is the most common repair on the trio's
Oct 06, 2007 | Maytag MFD2560HES Bottom Freezer French...
Refrigerators Logo
59 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
