Question about GE Nautilus 24" Built-in Dishwasher
I have a GE Profile Performance TRITON Tri Clean Wash System Quiet Power III. My grandkids played with the push button pad and now the drying light blinks and it won't work!!! HELP! Thanks Tina
buffalonyman
  • 1865 Answers
SOURCE: i have a ge profile quiet power 3 model #
The control board may have failed. There is no way to know the exact problem without troubleshooting with a multimeter
Posted on Sep 02, 2009
SOURCE: NORMAL Wash light is blinking and I can't CANCEL
We had the same issue with ours...tried turning off at the breaker, still didn't reset. Contacted appliance repair who came in and unplugged it from underneath the sink, waited a few seconds and plugged it back...dishwasher reset and repairman charged trip charge and labor $65 BUT problem is resolved and we now know what to do in the future.
Posted on Oct 18, 2009
SOURCE: GE profile performance dishwasher- not starting after child pushed buttons.
The only way we have been able to fix this is to turn off the breaker to the dishwasher for 5 minutes and then turn the power back on. The dishwasher should reset.
Posted on Oct 22, 2009
SOURCE: GE Profile Triton Triclean wash system - quiet
I hit the pump with a hammer and it started washing and continues to do so. Thanks
Posted on Nov 16, 2009
SOURCE: my ge quiet power 3 dishwasher will not start, the
I have the same problem. If I turn the circuit breaker off (for 30 seconds) then turn it back on, the lights will light up, but the controls don't work. After several minutes, the lights go out again.
Posted on Jul 19, 2010
My GE 24 in Profile PDW8280JSS door wont open: Now the "clean" light is on. I tried cutting power for over an hour, I have run wash cycles, the lock handle will not move. The unit did not have...
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Apr 04, 2011 | Dishwashers
The GE Profile Dishwasher will not allow me to start without the heated drying light coming on. I want to wash without this headed drying at the end of the wash. When I try to turn it off it turns the...
Try pressing the "Start/Reset" pad hold it for 5 seconds to reset the dishwasher and wait 2 minutes. If the problem persists, reset (reboot) the dishwasher by turning off power to the unit at the house circuit breaker/fuse box for 30 seconds. Or if its pluged in below the sink like mine unplug and plug back in. Restore power and the dishwasher should function normally.
Aug 02, 2017 | GE 24 in. Profile PDW9800J Built-in...
Getting F7 code on a ge profile performance oven , oven light will not turn off and control panel will not respone.....beeps when I push CLEAR OFF button.
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Try gliding your finger flat across the keypad rapidly and see if you can unstick the key / touch pad. Usually once this code appears it will repeat.
On self cleaning ovens this is the service check:
Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Thanks for using FixYa!
Kelly
Mar 09, 2010 | GE Profile JTP56 Electric Double Oven
Whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Press to start-nothing happens-no buttons pushed respond
IN MY CASE, IT WAS THE "HEAT DRY" PAD. THE CONTROLS WERE LOCKED INADVERTANTLY. NEED TO PRESS AND HOLD FOR THREE SECONDS TO UNLOCK. I FOUND THE INSTRUCTIONS ON THE WEB.
Apr 08, 2009 | GE 24 in. Profile PDW7800 Built-in...
No power or functionality - DOA
Ensure power is available to the unit, check the door switch for proper operation
Mar 23, 2009 | Dishwashers
Whirlpool Quiet Partner II
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode. the test mode will stop the light from blinking and you can use the dishwasher again
Nov 26, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
GE Nautilus 24" Built-in Dishwasher Logo
208 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
