Question about GE GSS25JFM Side by Side Refrigerator
Freezer not worknig.
I have a GE side by side refrigerator, freezer model GSS25JFMD-WW that is about 13+ years old and the freezer seems to have stopped working. The fan inside the freezer is running but the air is barely cool at best. The refrigerator side still seems just a cold as it always has been but everything in the freezer has thawed out. The last time I took anything out of the freezer and it seem to be working fine at that time was Wednesday morning and it is now Friday.
There are no coils on the back but I took the sheet metal cover off the lower back and vacuumed the cage and the white plastic fan on the end of the cage is running but still only cool air inside the freezer.
Suggestions?
  • GE Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezerFreezer not worknig. - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Jun 05, 2010
GE GSS25JF side-by-side: freezer not working.
I would change the 12 year old with a new model. The new models are more economic and the thechnic uses for sure less energy and the space is more, then the pump and engine the isolation less to.
Feb 04, 2014 | GE Refrigerators
I have a GE refrigerator model # GSH25KGMB WW. It is a side by side with an ice maker and water dispenser. We have had it for about 9 years now. The ice maker hasn't been working right for about 6 or 7...
you could have several problems.
Since you mentioned your ice maker not working right - first check to see if your ice maker is hot (be carefull it can burn you if it is hot) - it is possible for an ice maker to hang in the heat cycle of the cycle producing excessive heat in the freezer. If this is the case unplug the ice maker and/ or just replace it.
The refrigerator gets it cold from the freezer so if the freezer is not working right, you'll soon notice it in the refrigerator side.
You can also check to make sure the evaporator fan motor is running(in the freezer) and the condenser motor(at the compressor) as well.
Also check the back panel of the freezer for excessive frost build up.
Jun 30, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE side by side (GSS25JFMD WW) is not cooling. It's blowing cool air, but not cold .
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE refrigerator Model#GSS25JFMD Refrigerator is at 50 degrees, freezer at 34 with the dials turned all the way up. Any previous experience with this?
Check for frost about 1 foot up on the back wall in the freezer section . Is so , then a defrost problem is there .
Jul 16, 2009 | GE GSS25JEMWW Side by Side
GE GSS25LGM freezer not working. It's about 8
it seems like the thermostat on the freezer side is not function right but does the motor of the freezer run or not if not check thermostat
May 16, 2009 | GE GSS25LGM Side by Side Refrigerator
GE refriferator cooler side is warm/warming
possible cause the fan motor that takes air from the frezer section may not be working or seizing up check to see if your fan is working after seting your dial at corect numbers thans from gilles
Mar 15, 2009 | GE GSS20IEP Side by Side Refrigerator
GE TFX20JR BK WW side by side won't cool or freeze
First point: The entire fridge is cooled by the freezer section. A fan blows air across to the food section.
2) Every 8 hours or so, a timer shuts off the compressor cycle, and starts up a heater to defrost the freezer coils. If the heater(s) are burnt out, or if the safety thermostat (to prevent overheating) is open, then you will have no defrost. The coils will frost up and eventually prevent airflow to the food section. Milk goes sour.
3) In rare circumstances, the timer itself can stall. This cause the same symptoms as above, but this is not as common as the other 2 causes of No Defrost.
Sequence: Check heater continuity. Check safety thermostat continuity while cold. Check defrost timer operation.
Hope this helps. I am a journeyman with 39 years exp. Happy New Year.
Dec 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge Freezer not working
with min. toubleshootin. remove food store else where. Unplug unit. mop up water from ice melting. after 12 hour plug back in. If this work let me know. And I let U know step 2. Good luck.
Oct 12, 2008 | GE GSS25JEMWW Side by Side
Fridge and freezer warm at top, colder but not normal on lower shelves
How old is this frig? If it is older that 12-15 years, get a new one. Make sure there is not blockage to keep the air from circulating properly. The vent from the freezer to the cooler should also be free from blockage as well.
Aug 24, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
GE GSS25JFM Side by Side Refrigerator Logo
279 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
