Question about Refrigerators
Does a new main board for a GE Fridge (part number WR55X10942)have any manufacturer's warranty, and if yes-how long is it usually? Thanks
  • 677 Answers
for you to know about GE fridge manufacturer's warranty, and if yes-how long is it usually, you will need to contact GE fridge contact service for them to give you the right answer cause they are the manufacturer of such product.
Asking some one else, he might not be too sure to give accurate answer.
You can use thislink toget to the contact address of GE fridge for assistance.It's free.
(geappliances.com/service_and_support/contact/)
Hope that helps.
Take care.
Posted on Jun 17, 2010
I have a zfsb26dnd ss GE Monogram with a Dispenser board dead. ordered a new board and same result, ordered a new main control board and still nothing has changed. what else could I check or change?
You changed the main control board---is that the main mother board on the outside back wall of the refrigerator???? If not then the mother board may need changed. Part number WR55X10942. Just about every part of the refrigerator operation runs through that board. If you did change that already I would look for possibly a bad wiring connection to the dispenser system. There is usually wiring and plugs going through the hinge area of the door with the dispenser in it. some are at the top hinge some at the bottom depending on model number.
Jun 10, 2015 | GE Monogram ZFSB26DRSS Stainless...
No power to compressor
Is GSS25JFPCC the correct model number? If yes and many other GE refrigerators that have a motherboard. The motherboard for your refrigerator is found on the back and is item location 801 found HERE If you would like to replace the=> WR55X10942 Main Control Board or here=> WR55X10942 Main Control Board
I can provide you a service manual and explain all the things to consider when replacing the board. Things like fan motors, compressor start relay/overload and run capacitor also need to be examined to prevent the new board from going bad. A fan motor can cause this if it shorts. Yours sounds like the compressor circuit on the board down to the compressor has shorted on the morher board. I am here if you would like my assistance, Sea Breeze
Aug 31, 2013 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
GE model Pfs22miwww. Condenser fan and compressor not running. Tested start cal it is ok. Changed ontology board. Condenser fan now running. Still no compressor
Have you changed out the WR55X10942 Motherboard? Here is a link to test points on the motherboard HERE and here is a service manual HERE I don't mind helping answer your questions so feel free to contact me, Thanks Sea Breeze
Mar 22, 2013 | GE G.e Refrigerator Wr55x10942 Motherboard...
I have a freezer on top GE profile arctic fridge. It heated up for 24 hour then went back down and is now hovering at 7 freezer and 42 fridge. What is wrong?
This is a common problem with the GE Artica and Profile. The mother board=> WR55X10942 Main Control Board Compressor start components and condenser or evaporator fans must also be considered in the diagnostics. If you would like to do this yourself let me know and I will be glad to help you go throgh with the testing, Thanks Sea Breeze
7_10_2012_2_44_57_am.jpgWR55X10942 Main Control Board
Jul 09, 2012 | GE Profile Arctica Stainless Steel Top...
Hello, I have a few problems with a GE side by side refrigerator. It's a model GSS25JERF CC. First problem was getting no water, then I was sometimes not getting any ice from the door even though the tray...
Trouble described as
EVERYTHING "appears" normal ... "Nothing works"
I have experienced a similar circumstance...
(much older machine)
But I'll stop here & go look for your DEFROST Timer (No)
Or CONTROL BOARD... (Yes, yours = WR55X10942)
Defrost timers can mimic this if the
mountings are loose and the ...
motor runs on "ground" rather than "neutral" (v-rare)...
but circuit boards do fail & cause these issues
easy to change (right lower side on back (@ freezer))...
Purchasing a SPARE
now could save you another
significant food loss & inconvenience in the future
Easyapplianceparts $141.24
Main Electronic Control Board
Appliancepartspros $142.99
GE WR55X10942 Main Control Board AppliancePartsPros com
See video guides
http://www.appliancepartspros.com/ge-main-control-board-wr55x10942-ap4436216.html#videol
Partsselect
http://partsselect.com/
Owners Manual
GE ESH22XGRECC Owner Manual And Installation Instructions Page 72
Mar 24, 2017 | GE GSS25JF Side by Side Refrigerator
I am replacing a defective GE refrigerator main board (WR55X10416) in my GDS20SBSASS GE fridge with the newer WR5510942 main board. I have read elsewhere that a wire on this board may need to be cut,...
You should have included instructions that came with this board and the serial# is what dictates if a wire is cut or not on the main board. there also might be a wire on the harness that plugs into the wall that needs to be cut although I have yet to find one.
The provided link has pics of the instructions. just check your serial # to verify and follow the directions
GE WR55X10942 WR55X10656 Refrigerator Main Control Motherboard CB10942
cb10942-wr55x10656-wr55x10942-refrigerator-main-control-board-ge-pliqakvp0l11djscamij510i-4-0.jpg
Feb 07, 2018 | GE Refrigerators
A clicking sound was coming from behind my fridge and the temp display was not working. digital display. the light in the fridge comes on but the fridge is not working What could it be?
You have a bad main control board , located on the back of the refrig , behind an 8" X 10" panel . Part number WR55X10942 . This control board , usually clicks when the compressor tries to start , or when the compressor cooling fan tries to start . It also controls the display .
Sep 24, 2009 | GE Profile PDS20MFS Bottom Freezer...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
