Hoover top loader 750lc about 8 years old
Clothes and water in machine but machine will not spin dry to pump out water can anyone tell me how to pump out the water? is there a
manual switch somewhere.? I dont have the manual
  • Washing Mach... Master
  • 713 Answers
Hi just read your posting.Now the only way to drain your machine if it is not draining is to do it by hand with a small pot or bucket. Do you hear a small click when you close the lid slowly?If you do then that is the lid switch.It will not drain if your lid switch is not activating.Did you wash a big load before the problem started?Also could be a faulty or jammed drain pump.I can guide you throe the removal of the pump to see if it is the problem if you have some tools available.Please reply after you have tested the lid switch and I can guide you throe the rest of the repair if needed.
Posted on Jun 05, 2010
  • musojo Feb 14, 2011
    I've just read your response to this problem and am having a similar problem. I had just put in a large load of towels and when the machine had completed its cycle, I found it was still full of water. The machine will spin but the water won't run out. I would like to remove the drain pump to check what the problem may be but can't find where you have rescribed the process of doing this. Can you help me? Many thanks Jo.
  • Anahulu
    Anahulu Mar 15, 2014
    I have the same problem as a musojo ...how do you remove the drain pump???and fix it???
I have a Hoover 750LC and it makes a wrrrring sound when it drains and it only drains alit bit of water at a time can anyone help me
Yes...Yes..Yes..I can help you! You have a bad Drain Pump. Order a New Replacement and install it. Problem with water...Gone! Washer is a Once again Happy Machine...chugging along
Mar 15, 2014 | Washing Machines
My Hoover 700 LA Top loading washer does not spin dry clothes after the was cycle ? The drum does not spin fast enough for the clothes to dry out as before.
Just got Hoover 700 la manual top loader 2. hand...it is taking maximum amount of water on low arrange, and takes an hour on delicates. it also spin dries very strongly, just ruined my clothes..what you would suggest folks..
cheers aysh
Jul 06, 2012 | Washing Machines
Hi, My Hoover 600MB top loading washing machine is approx 8 years old. Recently it has occassionally not fully spun out - clothes still wet at end of cycle. Now it also often doesn't agitate - just...
Have a look for coins etc stuck in the drain pump or the tub outlet hoses especially where they fit onto the tub. If a coin or other foreign material blocks the water flow when draining , these machines wont spin properly.
Jul 26, 2011 | Hoover Washing Machines
My Hoover 500M top loader is very noisy on the spin cycle intermittanly. It sounds like a faulty or dry bearing, maybe when the water pump is emptying the bowl. The noise stops as soon as the spin cycle...
First I would bench check the water pump and see if it is operational or not. If it is then I would check the transmission. When it is in the spin cycle it switches to the high speed, so if you hear the grinding only in the spin cycle it could be the high speed gear.
Do you have any indication of a transmission leak? Fluid on the floor or on the transmission?
Jun 22, 2011 | Hoover Washing Machines
My GE top load washer is about 5 months old. It fills up and runs through the agitation cycle but then stops at the end spin cycle. The clothes just sit in the water. I checked the hose for kinks and...
I have had this problem with two of my previous washers a top loader and front loader.Each time it was a faulty pump that drains the water from the tub after the wash cycle is complete. If the water does not drain from the tub the machine will not go to the spin cycle. Both of my washers were 5 or 6 years old when this occurred. If the washer is only 5 months old it should be under the manufactures warranty. Good Luck.
Nov 12, 2010 | General Electric WBB2090G Top Load Washer
Hoover hpe 236. water not draining, stops mid cycle, lights flash
Have you checked the pump filter, and or that the pump is actually working. if it spins o/k with no water in, then I would suspect a draining problem.
If filter clean and pump o/k, then it could be a control module fault. if this were the case, then it would probably be wiser to purchase a new washer.
Hope this is of some help to you.
Jan 16, 2010 | Hoover Washing Machines
Have GE GJSR2130 or
is this machine top loader or front loader
Mar 15, 2008 | Washing Machines
Crosley Front Load Washing Machine
FL is a flood condition fault, too much water in unit. i would turn off water supply and try to spin water out. select spin button, should put 8 min on timer try startin that water should pump out then if not you got somethin stuck in pump (lint likely)
Feb 22, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing machine spin cycle
chances are the pump may have something in it or the drain line is kinked a little front loader machines have a clean out on the pump that you can get to buy taking the lower front panel off.top loaders you have to pull access cover in the rear and pull hose off and check for blockage also check belt tension and quality of belt
Dec 16, 2007 | Maytag MAV7600 Top Load Washer
Hoover750l
Please help
My Hoover 750 L Top Loader leaves a lot of fluff when I wash my dark clothes. I have been looking for a filter on it but no success. Any one have an answer please.
Sep 07, 2007 | Hoover Nextra HNF 3167 Top Load Washer
Washing Machines Logo
220 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
