Question about Samsung SF-565P All-In-One Laser Printer
What should be the settings to be able to receive fax messages?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 91 Answers
There is a button on the opperation pannal that say fax/reseve if the light is on it wil receve automaticly
Posted on Jun 09, 2010
Fax machine is able to receive faxes, but not able to send them. There is a "No Response" message every time I try to send a document.
Hi, i think your fax machine works fine, A "no response" message indicates that the receiver should accept your fax by hitting on the start button (normally its a green button) for you to able to send a fax or if no one in your friends location is receiving it. In this case you might as well set your fax machine to auto receive fax, defends on your fax machine's model. i hope this helps.
Aug 04, 2011 | Office Equipment & Supplies
My faxes will not receive because of communication errors
Scenario 1
In the HP Solution Center, click Settings, point to Fax Settings & Setup,
and then click Fax Setup Wizard.
After you have connected the phone cord to the port labeled 1-LINE, run the
fax test again to make sure it passes and the HP All-in-One is ready for faxing.
Try to send or receive a test fax.
Make sure you use the phone cord that came with the HP All-in-One. If you
do not use the supplied phone cord to connect from the telephone wall jack
to the HP All-in-One, you might not be able to send or receive faxes. After
you plug in the phone cord that came with the HP All-in-One, run the fax test
again.
If you are using a phone splitter, this can cause faxing problems. (A splitter is
a two-cord connector that plugs into a telephone wall jack.) Try removing the
splitter and connecting the HP All-in-One directly to the telephone wall jack.
Scenario 2
If you are not using a distinctive ring service, check to make sure that the
Distinctive Ring feature on the HP All-in-One is set to All Rings. For
information, see Change the answer ring pattern for distinctive ringing.
? If Auto Answer is set to Off, you will need to receive faxes manually;
otherwise, the HP All-in-One will not receive the fax. For information on
receiving faxes manually, see Receive a fax manually.
? If you have a voice mail service at the same phone number you use for fax
calls, you must receive faxes manually, not automatically. This means that
you must be available to respond in person to incoming fax calls. For
information on setting up the HP All-in-One when you have a voice mail
service, see Fax setup. For information on receiving faxes manually, see
? If you have a computer dial-up modem on the same phone line with the
HP All-in-One, check to make sure that the software that came with your
modem is not set to receive faxes automatically. Modems that are set up to
receive faxes automatically take over the phone line to receive all incoming
faxes, which prevents the HP All-in-One from receiving fax calls.
124
HP Officejet 6300 All-in-One series
User Guide
Note Some digital answering machines might not retain the
recorded silence at the end of your outgoing message. Play back
your outgoing message to check.
If the HP All-in-One shares the same phone line with other types of phone
equipment, such as an answering machine, a computer dial-up modem, or a
multi-port switch box, the fax signal level might be reduced. The signal level
can also be reduced if you use a splitter or connect extra cables to extend
the length of your phone. A reduced fax signal can cause problems during
fax reception.
To find out if other equipment is causing a problem, disconnect everything
except the HP All-in-One from the phone line, and then try to receive a fax. If
you can receive faxes successfully without the other equipment, one or more
pieces of the other equipment is causing problems; try adding them back one
at a time and receiving a fax each time, until you identify which equipment is
causing the problem.
If you have a special ring pattern for your fax phone number (using a
distinctive ring service through your telephone company), make sure that the
125
If you have an answering machine on the same phone line with the HP All-in-
One, you might have one of the following problems:
- Your answering machine might not be set up properly with the HP All-in-
One.
- Your outgoing message might be too long or too loud to allow the HP All-
in-One to detect fax tones, and the sending fax machine might
disconnect.
- Your answering machine might not have enough quiet time after your
outgoing message to allow the HP All-in-One to detect fax tones. This
problem is most common with digital answering machines.
The following actions might help solve these problems:
- When you have an answering machine on the same phone line you use
for fax calls, try connecting the answering machine directly to the HP All-
in-One as described in Fax setup.
- Make sure the HP All-in-One is set to receive faxes automatically. For
information on setting up the HP All-in-One to receive faxes
automatically, see Set the answer mode.
- Make sure the Rings to Answer setting is set to a greater number of
rings than the answering machine. For more information, see Set the
number of rings before answering.
- Disconnect the answering machine and then try receiving a fax. If faxing
is successful without the answering machine, the answering machine
might be causing the problem.
- Reconnect the answering machine and record your outgoing message
again. Record a message that is approximately 10 seconds in duration.
Speak slowly and at a low volume when recording your message. Leave
at least 5 seconds of silence at the end of the voice message. There
should be no background noise when recording this silent time. Try to
receive a fax again.
Scenario 3
The HP All-in-One might be dialing too fast or too soon. You might need to
insert some pauses in the number sequence. For example, if you need to
access an outside line before dialing the phone number, insert a pause
following the access number. If your number is 95555555, and 9 accesses
an outside line, you might insert pauses as follows: 9-555-5555. To enter a
pause in the fax number you are typing, press Redial/Pause, or press the
Space (#) button repeatedly, until a dash (-) appears on the display.
You can also send the fax using monitor dialing. This enables you to listen to
the phone line as you dial. You can set the pace of your dialing and respond
to prompts as you dial. For more information, see Send a fax using monitor
dialing.
? The number you entered when sending the fax is not in the proper format or
the receiving fax machine is having problems. To check this, try calling the
fax number from a telephone and listen for fax tones. If you cannot hear fax
tones, the receiving fax machine might not be turned on or connected, or a
voice mail service could be interfering with the recipient's phone line. You
can also ask the recipient to check the receiving fax machine for any
problems
Dec 03, 2010 | HP Officejet J3680 Multifunction Printer...
Can't receive fax's......how do you set it up to receive...thank you
again.
Scenario 2
124
User Guide
fax reception.
125
One.
disconnect.
Scenario 3
dialing.
problems
Dec 03, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Sends faxes fine, but will not receive. Message "FAD" on screen
Could the message be reading "TAD"? If you have an answering machine hooked up anywhere on the same line as the fax, you need to refer to page 16 of your manual. Set your answering machine to 2 rings and de-activate the toll saver mode. If you have a dedicated fax line without the TAD, set your fax recieving mode to fax only by pressing the MODE button under the LCD display untill fax only isindicated
Jul 07, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Fax connection
To send a fax, you will have to configure the settings. here are the steps you can follow;
Remote Fax Options;
You can only use one remote fax option at a time:
Fax Forwarding—OR—Paging—OR—Fax Storage—OR—PC FAX Receive—OR—Off.
You can change your selection at any time (Menu/Set, 2, 5, 1).
Setting up Fax Forwarding
When you select Fax Forward, your MFC stores the received fax in the memory. The MFC will then dial the fax number you’ve programmed and forwards the fax message.
  1. Press "Menu/Set, 2, 5, 1".
  2. Press ▲ or ▼ to select "Fax Forward". Press "Menu/Set". The LCD will ask you to enter the fax number to which faxes will be forwarded.
  3. Enter the forwarding number (up to 20 digits). Press "Menu/Set".
  4. Press ▲ or ▼ to select "Backup Print:On or Backup Print:Off". Press "Menu/Set".
If you select "Backup Print:On", the MFC will also print the fax at your MFC so you will have a copy if there is a power failure before it is forwarded.
5. Press "Stop/Exit".
Programming your pager number When Paging is selected, your MFC dials the pager number you’ve
programmed, and then dials your Personal Identification Number (PIN). This activates your pager so you will know that you have a fax
message in the memory.
1. Press Menu/Set, 2, 5, 1.
2. Press ▲ or ▼ to select Paging.
3 . Enter your pager phone number
followed by # # (up to 20 digits). Press Menu/Set.
Do not include the area code if it is the same as that of your MFC. For example, press 1 8 0 0 5 5 5 1 2 3 4 # #.
4. If your pager needs a PIN, enter the PIN, press #, press Redial/Pause, enter your fax number followed by # #. Press Menu/Set. (For example, press 1 2 3 4 5 # Redial/Pause 1 8 0 0 5 5 5
1 2 1 2 # #) —OR— If you do not need a PIN, press Redial/Pause, enter your fax number followed by # #. Press Menu/Set. (For example, press Redial/Pause 1 8 0 0 5 5 5 1 2 1 2 # #)
5. Press Stop/Exit.
■ You cannot change a Paging number or PIN remotely.
■ If you have set Paging, a backup copy of the received fax will
automatically be printed at the MFC.
Setting Fax Storage
If you select Fax Storage, your MFC stores the received fax in the
memory. You will be able to retrieve fax messages from another
location using the Remote Retrieval commands.
1 Press Menu/Set, 2, 5, 1.
2 Press ▲ or ▼ to select
Fax Storage.
Press Menu/Set.
3 Press Stop/Exit.
Setting PC Fax Receive
If you select PC Fax Receive, your MFC will temporarily store your
received fax messages in its memory, and then automatically send
the faxes to the PC. You can then use your PC to view and store
these faxes.
PC Fax Receive.
Press Menu/Set.
3 Press ▲ or ▼ to select
Backup Print:On or
Backup Print:Off.
Press Menu/Set.
4 Press Stop/Exit.
If you have turned on Fax Storage, a backup copy will
  • Before you can set up PC Fax Receive you must install the
MFL-Pro Suite software on your PC, make sure your PC is connected and turned on. (For details, see Using Brother PC-FAX software on page 5-1 in Software User’s Guide on
the CD-ROM.)
  • If you select Backup Print:On, the MFC will also print the fax at your MFC so you will have a copy if there is a power failure before it is sent to the PC.
■ If you get an error message and the MFC cannot print the faxes in memory, you can use this setting to transfer your faxes to your PC.
Turning off Remote Fax Options If you set the Remote Fax Options to Off and there are faxes in your MFC’s memory, the LCD will give you two options.
  • If you press 1, all unprinted faxes will be printed and erased
before the setting turns off. If a backup copy has already been
printed it will not be printed again.
  • If you press 2, the memory will not be erased and the setting will be unchanged.
Setting your Remote Access Code
The remote access code lets you access the Remote Retrieval features when you are away from your MFC. Before you use the remote access and retrieval features, you have to set up your own code. The default code is inactive code (--- ).
  1. Press Menu/Set, 2, 5, 2.
  2. Enter a three-digit code using numbers 0-9 or . Press Menu/Set. (The preset ‘ ’ cannot be changed.)
  3. Press Stop/Exit. Do not use the same code which is set in your Fax Receive Code ( 51) or Telephone Answer Code (#51). You can change your code at any time by entering a new one.
  4. If you want to make your code inactive, press Stop/Exit in Step 2 to restore the inactive setting (--- *).
May 05, 2009 | Brother MFC 7420 All-In-One Laser Printer
We can send faxes but we can not receive faxes. The fax machine that sends the fax tell it that our line is busy. Is that a machine problem or a phone line problem?
Problem lies in your Receive Mode setting. If you don't have a dedicated phone line for the fax machine, you need to set it up for either Manual where you answer every call or Fax/Tel whereby the Fax machine determines if the incoming call is a fax or phone call. Instructions per Intellifax 4100 Manual.
Select a Receive Mode
Choose the mode that best suits your needs by pressing the Mode button
repeatedly until the FAX and FAX/TEL lights show the setting you want to use.
Manual
You must answer every call yourself.
The Brother machine must be started manually
to receive faxes.
Fax
For use with a dedicated fax line.
Every call is answered as a fax.
Fax/Tel
For receiving fax and voice calls on one line.
The FAX answers every call and receives a fax or
double rings for you to pick up a voice call.
TAD
For use with an answering device.
The TAD answers every call and stores voice messages.
Fax messages are printed.
Apr 20, 2009 | Brother IntelliFAX 4100 Laser Fax
Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Nov 24, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Receiving Problem
Do you have a DSL or any other digital phone line?
Are you set to "AUTO RECEIVE" ?
Call the fax machine from a regular phone and listen for fax tones.
Sep 29, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Can not receive fax
Make sure the fax is set to receive automatically. The receive mode must be set to one of the following modes: Fax Only, Fax/Tel Auto Sw, or Ans Machine. If it is set for Answering Machine, be sure the machine is connected to the fax, turned on, and contains a recorded outgoing message.
If you need further assistance, please post back. Otherwise, thank you for using and rating FixYa!
Jun 24, 2008 | Canon FAX-JX200
Receiving fax
Hi trbrewer -
Had similar problem (setup for 2 rings, picked up after 8).
Problem was: receiving mode was set to "ans/fax". Once set to
"fax" all was OK.
to set "fax" mode: see page9.4 of manual
Good luck !!
Dec 17, 2007 | Samsung CLX 3160fn All-In-One Printer
Samsung SF-565P All-In-One Laser Printer Logo
57 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
