Question about Dryers
I cannot remove the dryer drum so that I can replacr the bearing, how do I get it out??
    President:
  • 1,554 Answers
Dryers usually do not have bearings but rather have rollers or glides. The dryer becomes noisy when the rollers or damaged get worn and must be replaced to address the noise problem. Furthermore, disassembly procedures vary by make and model; this requires you to indicate the make and the exact model number for specific and precise tear down steps. You don't have to accept or reject and rate this post to add information or post your comments and further questions.
Posted on Jun 05, 2010
My kenmore 87872800 dryer wont spin. everything else is working but drum wont spin.
Left the top of the dryer top, check to see if the belt isn't broke or loose, if that is in tact try turning the drum by hand to see if it turns easily. if not, the bearing in the back of the drum needs replaced. this is easy to replace, remove the drum by removing the dryer top and then remove the belt, and the drum slides up out of the machine. replace the bearing then reassemble dryer.
Jun 16, 2011 | Dryers
Dryer squeaks when clothes are drying
Squeaking can mean bearings going bad or the pulleys needing some oil on them. The pulleys can usually be accessed from the rear of the dryer. The bearings are a different story, you would need to remove outer casing of the dryer to remove the drum to get the bearings behind the drum. I would recommend trying to oil the motor and idler pulleys and if that doesn't fix the problem if your handy you can try to replace the bearings. Its a big job, the bearings are behind the drum and are screwed in from the inside of the drum. In order to remove the drum the casing of the dryer had to be removed, usually the front and the top (the top will sometimes tip back on hinges). After that the drum should slide out with the bearing assembly attached. Installation is the same as removal. {Note: If you find it to be too much trouble, I would just leave it squeak, other than being annoying it won't hurt anything. Also, some dryers have a compartment in the back where you can see the bearing assembly, maybe you can spray some WD-40 in there and see if it stops squeaking. The time you really need to replace the bearings is if your drum is loose, as the bearings have gone bad, not just squeaky}
May 12, 2010 | Dryers
The dryer drum will not turn, even manually with the belt removed
Sounds like something became wedged against the drum. Maybe a bearing?
Feb 20, 2010 | Frigidaire GLEQ2152ES Electric Dryer
How do I replace bearings on the drum roller for the Amana electric dryer?
remove front cover then top cover remove belt around drum remove 3 or 4 screws inside drum that holds bearing onto drum, repl bearing and mount and reverse procedure
Sep 27, 2009 | Amana DLE330RAW Electric Dryer
Clothes getting caught between drum and front of dryer
Hello Friend, This problem is real common in Hotpoint/GE dryers. Your solution is simple. You need to replace the front drum bearing and glider pads. It's actually pretty simple to do. Just remove front of dryer cabinet. After removal just look at backside of dryer front around the inner door. You will see where the dryer drum has turned and wore a hole in the plastic piece above the dryer door. This piece is called the front drum bearing. Just unsnap this piece and snap in a new one. Be sure to replace the little plastic glide pads onto the top of the drum bearing before re-installing the dryer cabinet front. The front drum bearing and glider pads are sold seperately so make sure you have everything you need before you begin. This should solve your problem. Happy to help, Tim. Thanks.
Jun 29, 2009 | Hotpoint NVL333EY Electric Dryer
My dryer catches a piece of clothes in the drum edge and has ruined quite a few clothes, leaving them with black-brown marks. When I look at the drum seating using a mirror I can see that it's not...
Hello Friend, This problem is real common in GE dryers. Your solution is simple. You need to replace the front drum bearing and glider pads. It's actually pretty simple to do. Just remove front of dryer cabinet. After removal just look at backside of dryer front around the inner door. You will see where the dryer drum has turned and wore a hole in the plastic piece above the dryer door. This piece is called the front drum bearing. Just unsnap this piece and snap in a new one. Be sure to replace the little plastic glide pads onto the top of the drum bearing before re-installing the dryer cabinet front. The front drum bearing and glider pads are sold seperately so make sure you have everything you need before you begin. This should solve your problem. Happy to help, Tim. Thanks.
Jun 29, 2009 | GE DBSR453EBWW Electric Dryer
Iam hearing scraping sounds from my dryer.
Hello Friend, Your solution is simple. You need to replace the front drum bearing and glider pads. It's actually pretty simple to do. Just remove front of dryer cabinet. After removal just look at backside of dryer front around the inner door. You will see where the dryer drum has turned and wore a hole in the plastic piece above the dryer door. This piece is called the front drum bearing. Just unsnap this piece and snap in a new one. Be sure to replace the little plastic glide pads onto the top of the drum bearing before re-installing the dryer cabinet front. The front drum bearing and glider pads are sold seperately so make sure you have everything you need before you begin. This should solve your problem. Happy to help, Tim.
Jun 25, 2009 | GE DBSR453EBWW Electric Dryer
How do you put a drum bearing toghether for dryer
inside of dryer on right use allen wrench to remove old bearing. lift on tub to insert new bearing.
Jun 20, 2009 | Fisher and Paykel DG05 Gas Dryer
How do I replace bearing on a CTD00 Hotpoint tumble dryer
front bearing on drum felt bearing the whole front has to be removed from machine .. if felt back bearing same applies .. if the plastic drum bearing guides this can be done by removing side panel .... always disconnect from mains before attempting any repair
Jun 11, 2009 | Hotpoint NWXR473EV Dryer
How to replace the bearing on the drum of a fisher&paykel dryer ED56
top load dryer?? open top right end of drum remove toex screw and cover brass bearing slides out.. front load pry up top srews top inside front lift front out remove belt lift drum out bearing in back on rear wall
Apr 24, 2008 | Dryers
Dryers Logo
23 people viewed this question
Top Dryers Experts
