Question about Amana ACD125R 12000 BTU TOUCH/REMOTE ROOM AIR CONDITIONER
How can I set my Amana ACD125R, so it can turn on and off using the timing setting, or how can I get a manual page that explain me how to do the energy saving settings
    President:
  • 1,515 Answers
Hi, you will need to take the numbers from the thermostat and locate a place who sells this type to be able to program it properly. It is very important to put this manual in a safe place, sounds as though the previous owners did not do this. There are so many of these stats on the market today and they all have different way of setting them up. I wish you the best,
Shastalaker7
PS Just to let you know, this unit is a 1 ton unit. 12,000 btu's for each ton of cooling.
Posted on Jun 05, 2010
Amana ACD125R compressor will not turn off without unplugging
If it's a mechanical thermostat, then it's electrical contact points must be closed for some reason. If the thermostat is electronic, then the logic board may be fried. Either way you would have to replace the thermostat.
May 06, 2012 | Refrigerators
Set screen date/time in kodak easy share
Hello There!,
I think I can help you :-)
Here is the link for the user manual
http://gdlp01.c-wss.com/gds/7/0300001857/01/PSA480_CUG_EN.pdf
On page 16 it explains two ways to set date & Time.
1st is when you turn on the power it will ask you to set the time & date, and you can enter it.
2nd way to set time & date, or change it is to press the MENU key, and select "Set Date & Time".
I hope this helps you.
Please also giving me a good rating for offering you help, :-)
Thanks,
Sep 17, 2011 | Canon PowerShot A480 Digital Camera
My bose wave radio 1 somehow switched to military time. There is no clock set button?
Not explicily, but on page 18 of the manual (Bose.com) clock setting is explained...
To set AM/PM (12 hour) or Military (24 hour) time - Press the On/Off button once to turn your Wave radio off.
Press and hold Clock Set, and then press On/Off to switch between AM/PM (12 HR) or military (24 HR) formats
Sep 08, 2011 | Bose Wave Radio
My Bose radio does not have a "Clock Set" or "AM/PM" button. The display now reads military time. How do I set it on AM/PM time?
What model are we talking about? It's probably explained in the manual.
The Wave Radio's manual explains time setting starting at page 16 of its manual, for example.
Bose.com has downloads for its products.
Mar 25, 2011 | Audio Players & Recorders
Where is the reset button on an Amana ASZ14 unit?
I don't think the Amana ASZ14 Heat Pump has a reset switch, but you can still reset it by resetting the power (when it's not running... turn your thermostat OFF first).
To reset the power, locate your circuit breaker box. There should be a double-breaker for the Heat Pump and another double-breaker for the Air Handler. Turn them both off for at least 2-3 minutes. Then flip them back on and turn your thermostat back ON.
You're thermostat may also have a RESET button that you can push. I have to reset mine every time I change the batteries in it.
Here are some more repair tips...
Heat Pump Troubleshooting & Repair:
http://www.hometips.com/repair-fix/heat-pump.html
Heat Pump Troubleshooting Repair
Amana ASZ14 web page:
http://www.amana-hac.com/products/heat-pumps/14-seer-asz14
ASZ14 Heat Pumps
Amana ASZ 14 SEER Technical Manual
(45-page PDF):
http://www.manualslib.com/manual/877256/Amana-Asz-14-Seer.html
Amana ASZ (and ASX) Service Instructions (66-page PDF):
http://www.acdirect.com/media/catalog/files/RS6200006.PDF
Jan 11, 2011 | Amana PTH123B25AJ Heat Pump Air...
NO COLD AIR. CAN I SERVICE MYSELF?
yes you can , but you may need some one that knows what they are doing to help you or it may never work again .. no cold air could mean alot of things , thats all im saying and you wouldnt want to mess up something that could be a quick fix to a service tech....
Aug 11, 2010 | Amana ACD125R 12000 BTU TOUCH/REMOTE ROOM...
Need instruction manuel for amana AP076E
ManualsLib has the manual here: https://www.manualslib.com/manual/5170/Amana-Ap076e.html . Click on the Download button and follow the instructions there if you do not want to go through the manual page by page.
I hope this helps.
Aug 29, 2017 | Amana AP076E Portable Air Conditioner
How do I set the camera to Macro and can I turn
Page 16 of the user manual explains how to set up the camera for the macro mode. If you are using regular macro mode then you would also need to set the flash mode to off if you do not want it to fire automatically (page 15 of the user manual refers how to disable the flash). If you are using the super macro mode then the flash would be set to off by default.
May 02, 2009 | Olympus Stylus 770 SW Digital Camera
I have a proble with setting date & day.
i think it's explained on the first page of your manual. first u turn the crown clockwise in position 3 to set the day (you have to turn it 24 hrs evey time to change one day). When this is done, you can set the date with the crown in position 2 and turn counter clockwise. i hope this answers your question
Feb 03, 2009 | Fossil ME1020 watch
Light turns on Automatically
If you don't have the onwer's manual, it's online here:
http://www.fixya.com/support/p50922-amana_amv5164_1000_watts_microwave_oven/manual-1726/page-5
See page 7 for Control Setup button functions.
Aug 19, 2007 | Amana AMV5164 Microwave Oven
Heating & Cooling Logo
121 people viewed this question
Top Amana Heating & Cooling Experts
Bill Long
Pete Norton
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
