Question about Rheem 80 GAL ELEC TALL Water Heater 6YR SC 82V802
Black paticles in water
Rheem Professional 80 used with recirculating water system. Now about ten years old, but the problem started about five years ago or so. Why do I get lots of black particles in the outlets from this heater? They come out at all outlets on the recirculating system. I have flushed and flushed the tank and tons of black particles keep coming out. There seems to be no end to them. The cold water faucets have no such particles. There are no rubber - stainless hoses in the system and I've inspected the rotor in the recirculate pump - no issues there.
  • 593 Answers
Check your particles with a magnet. If they stick your tank is rusting out and it may still have some warranty left, 5 -to 10 years is about right for a warranty issue. Any why check the particles with a magnet. Any way it is time to replace the heater. Sorry.
Posted on Jun 05, 2010
Water leak from top of hot water tank ?
Fix overflow system coz it is not working properly.
Jan 27, 2015 | Rheem Richmond 50 Gal LP Gas 6 Year Tall...
I have an 80 gallon Rheem Hot water heater #81V80D A. In the last 5 days it stopped heating water after 6PM. I have hot water all day, but none at night. What do you suggest?
1) I bet the water heater has hot water, but hot does not arrive at tap because of bad faucet cartridge or bad recirculation system check valve
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#crossover
2) When cold water arrives at tap, go check if water heater has hot water. Then do the crossover test. Then add comment and say what you discover
3) Electric water heaters can be repaired by homeowner using generic off-the-shelf parts from local hardware store.
Feb 18, 2013 | Rheem Water Heaters
Energy factor rating
Rheem 50 gallon Pro52-2 has EF .95, which makes it ordinary 240Volt 4500 watt non-simultaneous electric water heater that produces about 21 gallons hot water per hour, with 67 gallon first hour delivery.
Recommend 80 gallon per hour first hour for oversized bathtub.
http://bostonheatingsupply.com/Rheem/Rheem%20Residential%20Electric/Professional/Rheem_ResidentialElectric_Professional%20Spec%20Sheet.pdf
Maintain electric water heater and it will last indefinitely.
http://waterheatertimer.org/How-to-maintain-water-heater.html
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Anode rod is located on top in separate port.
Anode keeps tank from rusting.
Year of Rheem water heater manufacture shows 3rd and 4th digit of serial number.
Nov 25, 2012 | Water Heaters
I have a rheem classic series super quiet 80 furnace. when the panel that covers up the control board is removed is there a reset button or sequence that mut be performed so the system will once again run.
no just repalce all the covers and then cycle to power to the unit and it should take off and go...be aware that the t-stat could take five minutes or so to recycle and star the unit also..
heatman101
Aug 11, 2010 | Rheem Paloma PTG-74PVN / RTG-74PVN...
I have a hot water circulator when i turn on the cold water hot water comes out for about 30 seconds before the cold water will come out. What could be causing this?
This is could be because the system is set up to use the cold water line as the return to the HWH.
Hot water recirculation systems generally consist of a pump, an integrated electronic controller, and a zone valve. When the activation button is pushed, or when another type of control turns the system on, the pump starts recirculating cooled water that's been sitting in the hot water line and sends it back to the water heater through the cold water line.
If you would like..Google "hot water re-circulation theory"...it further explains this senario.
HTH,
Mike....
Dec 01, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
I have a Rheem 41v50n (about 10 years old)and the pilot light went out and will not re-light. Gas comes out when I hold the botton down, but it goes out again when I let go. Any simple fixes, or should I...
The thermocouple just needs to be replaced. Can be bought for around ten bucks at many hardware store or heating supply house. Simple installation. Takes about ten minutes to install. They come in different lentghs, see how long yours is before you buy, so you get the right one.
Nov 12, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Rheem tankless water heater gives error code, flashes 80. Also what do I use to seal the exterior of the vent? Should the vent outside smell like gas?
check to make sure that your flue pipes are together if the have not been put together properly it will not start, it has to pull in cold air while exhaust is forced out,, if it isn't right it will pul exahust thru the cold air intake and shut sown or not start at all,, you might want to call who ever installed it,they are supposed to warraty it for 1 year on labor at a min, to be able to install them thru the company,, rheem,, they are supposed to be quilaifeid and have a card that states they took the class to have the knowledge to do so.
Jun 01, 2009 | Rheem EcoSense by 4.2 GPM Tankless Water...
When I run the hot water on my tankless LPG water heater the water will run hot for a few minutes and then shut down even though the hot water tap is still open. This means hot and cold water cycling...
There's a little device that is like a pressure switch that starts heating when is senses water flow. This is what happens when it starts to go bad. You will need to call out a professional and have it serviced and the part repaired or more probably, replaced.
Apr 09, 2009 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
Rheem 80 GAL ELEC TALL Water Heater 6YR SC 82V802 Logo
143 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
