Question about ViewSonic Graphic VG2021m LCD Monitor
No Back light
Replaced C204 and CE101 They were bulged and leaking
  • 11,361 Answers
Try reading more here: http://www.badcaps.net/forum/showthread.php?t=7803
http://s807.photobucket.com/albums/yy352/budm/Viewsonic%20VG2021/
Did you replace all the caps in the secondary DC side with low ESR caps such as PANASONIC FM or FC series from DIGIKEY? The fuse next to the cap is OK?
Posted on Jun 06, 2010
Konica minolta c350 error code c204
C 204 Tray 2 feeder up/down abnormality.Check the M9 paper feed tray 2 lift up motor connector for proper connection,the PS15 paper feed tray 2 upper limit sensor actuator,the motor coupling.
Jul 27, 2014 | Konica Minolta bizhub Office Equipment &...
What part needs to be replaced when the monitor switches off after being turned on?
you must need to check first weather the cause is bad power inverter board for screen back light or a leak like bulged capacitors in the power supply board.
Oct 15, 2012 | HP W2338H Monitor
If carbrain C168 Can do benz E211 AND C204 and S221 AND JEEB ?
Carbrain C168 will be better in both the German cars and the Japanese cars.from1996-2008 car can do.for information,suggest you followling the website below.
http://www.xcardiag.com/wholesale/high-quality-profi-wifi-obd2-oem-carbrain-c168-scanner-update-by-email-23.html
Mar 15, 2012 | Cell Phones
Acer screen is completely black
There are more than one version of this model.
http://s807.photobucket.com/albums/yy352/budm/ACER/ACER%20AL2017%20Abd/
http://s807.photobucket.com/albums/yy352/budm/ACER/ACER%20AL2017%20BMD/
You need to look for bad caps with bulging/leaking tops, blown fuses, shorted MOSFET, etc.
Please read my guide to understand more:
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Sep 03, 2011 | Acer AL2017 20" LCD Monitor
The tv goes to turn on then the green light come up then flashes then the red light comes on then the green agin it does this a few time then turns off at no time is there a picture or sound. thanks
Probably some bad capacitors in the power supply or inverter/RF circuitry for the back-lights.
look for electrolytics with the top bubbled up on them, or bulging plug at the bottom or leaking electrolyte...these caps all need to be replaced.
Feb 28, 2011 | LG 50PG20 50 in. Plasma HDTV
View sonic lcd power problem
Check the DC filter caps first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Aug 03, 2010 | ViewSonic VA1912wb Monitor
I plugged in my toshiba DLP projector one day and I heard a pop
Sounds like a blown capacitor...they age...leak..and bulge..
and then blow out...
Check (visually) all the capacitors on your power supply board...
if they are fat, bulging or leaking...they should be replaced.
Jul 11, 2010 | Toshiba TDP-S8 Multimedia Projector
I pushed the button next to the power button now i have no screen, i pu7shed the button again but to no avail, please help
Common failure is the caps in the inverter/power board, look for caps with bulging tops, see example of failed VIEWSONIC monitor due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Feb 23, 2010 | ViewSonic VA1912wb Monitor
Hello only on screen
On the power supply board I replaced CAP C226 as per another poster and the problem is solved. It is a 470 uF, 35 VDC capacitor. Bought one at Radio Shack for <$1.50 USD. Radio Shack part number is: 272.1030.
Jul 19, 2009 | RCA DRC8335
ViewSonic Graphic VG2021m LCD Monitor Logo
206 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
