Question about Harman Kardon AVR 45 Receiver
I have an AVR45RDS and the remote only works sparodically
The remote only works every so often and I am not sure why. Is there are method to re-programme the amp so the remote works effectively
  • 757 Answers
Reprogramming will not work. Things to consider about the remote are battery strength, operating distance and integrity of the buttons.
If you are further than 30ft, the remote signal is greatly diminished.
If the remote is working only intermittenly then that is also a symptom of batteries near expiring or possibly leaking.
Lastly, the buttons...dirt and other debris can cover the button contacts inside the remote after many uses. Disassemble the front panel and remove the button pads, then with a soft brush like an artists or a clean makeup brush, swift away any dirt etc. and reassemble.
Posted on Jun 05, 2010
Tip
Why Am I Unable To Program The RCA Remote Control To Operate My Components
Why am I unable to program the RCA remote control to operate a component? Why am I unable to program the RCA remote control to operate a component? If you are unable to program the remote control to operate a component, review the following information:
Compatibility
If none of the programming procedures work, the universal remote control may not be compatible with your components, based on the type of infrared technology and the age of the components. Some RCA universal remote controls will only work with components manufactured after 1990.
Distance
If you are testing the remote control after you have entered a code, you may be too far away from the component or you may not have the remote control aimed directly at the component. Because the remote control uses infrared (IR) technology to communicate with components, there must be an unobstructed path between the remote control and the IR sensor on the component.
Code Entry Methods
If the Direct Code Entry method was used to enter the codes for your brand and the unit is still not functioning properly, try one of the automatic code search methods instead. During automatic code search, the remote searches for the correct code to program.
Modes
For the remote control to know which component you wish to operate, you must put the remote control in the correct mode by pressing the corresponding component button.
Combo Units
To program the remote control to operate combo units, such as TV/VCR’s, TV/DVD’s, or TV/VCR/DVD’s, use the combo codes in the Code List to program the individual corresponding component buttons. Once programmed successfully, the TV button controls the TV functions on your unit, and the DVD or VCR button controls the DVD or VCR functions, respectively. The codes in the combo section should be tried first, using the Direct Code Entry method on the TV and DVD or VCR buttons. If this is unsuccessful, use one of the Code Search methods to program your combo unit.
Batteries
Make sure the batteries are new and properly installed.
on Jun 19, 2009 | RCA DIRECTV Satellite Remote Control
STARTS FINE, PUT IN GEAR GOES DEAD, SPARODIC
First thing to check with a situation like this is to make sure all the ground wires are secure and tight. Ask you mechanic if he did this. If not, he is overlooking a simple, but common cause of intermittent problems.
Sep 19, 2014 | 2001 Cadillac Sts
2002 Chevrolet Cavalier Remotes not working. door locks works in side but not with remote. batterys ok and they are transmiting. just stop work one day.
If you know for sure that the transmitters are transmitting (tested on a key fob tester), and the remotes are the correct ones for your vehicle (haven't been recently replaced with a different part number), then you may need to simply re-synchronize your transmitters to the vehicle. This is different than reprogramming the transmitters, but uses the same method on the remotes.
To resynchronize, Stand within 5 feet of the car, with the remotes. Press and hold the LOCK and UNLOCK buttons on the REMOTE for about 7-10 seconds. If the transmitter was out of sync with the car, the horn will chirp to confirm it is now synchronized. If this method does not work, then the transmitters will have to be programmed to the vehicle, which requires a scan tool to do. Good luck :)
Oct 12, 2013 | Chevrolet Cavalier Cars & Trucks
Quite suddenly it doesn't play. The ipod registers that it's charging, and I've checked the remote control on another Bose system I have and it seems to be ok.
I just had the same problem with mine - turns out the Bose docking stations are comlete and utter **** and if yours keeps working you're one of the lucky few. Mine only had sparodic use over a 3 month period and it stopped producing sound the other day. I took it to a repair shop and they've seen a lot of them with the same problem. The solution - dump it in the bin and get a logitec set of speakers & you'll have better sound. This was proven by attaching the iPod to each system.
Apr 14, 2011 | Bose SoundDock digital music system...
Fuel gauge works sparodically
Believe me its not you fuel gauge. The float sits on the fuel pump thats in the gas tank about a $500.00 job to replace pump w/float.
Sep 24, 2010 | 1999 Chevrolet Silverado 1500
2003 Escalade Keyless Remote not responding
You need to take it an have scan tool method done .
Mar 29, 2017 | 2003 Cadillac Escalade
The resume button working sparodically
Change your cruise control sensor It will correct the problem
Apr 07, 2009 | 2001 Ford Taurus
Harman Kardon AVR 45 Receiver Logo
181 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
