Question about LG 47 in. Flat-Panel LCD HDTV
How do I change the resolution on a 47 inch LG LCD TV so that my samsung Blu ray show s correctly?
  • 10,594 Answers
Connect your bluray in HDMI input of your tv to get maximum picture resolution of bluray.
Plug HDMI cable in HDMI Out at rear of bluray player and hook it in HDMI Input of tv, turn On tv then bluray, select HDMI Input in tv with its remote and tv will show you bluray logo screen, put disc in bluray and play it by pressing play button. HDMI is proper input port to give maximum resolution 1080 picture in tv.
Component Video (red-green-blue RCA jacks) and Composite Video (yellow RCA jack) are low resolution connection setup.
Hope these info will help you.
Thanks.
Posted on Jun 05, 2010
  • 1 more comment
  • dahickmans Jun 05, 2010
    That is how the system is currently connected. But it doesnt seem to show as clearly as I have seen it in stores. It's a very clear picture but not the blu-ray I've seen. That is why I thought the tv may not be set to 1080P? Is that possible?
  • Shahid Electronics
    Shahid Electronics Jun 05, 2010
    HDMI connection is intelligent setup and adjust itself for picture resolution as per source video.
    Please check bluray menu if it is set on bit lower resolution, change it to HD mode.
    I dont see a different post.
Blu-ray player mode not supported
Is your TV 1080p? If the Blu-Ray is putting out 1080p and your TV only supports 720p/1080i then you will get a message like this. Try changing your settings to 720p while it is connected to a TV that does display correctly, then move it back to the 47 in LCD.
Jul 08, 2012 | Insignia NS-LCD47HD-09 47 in. LCD TV
I want ot change my LG television Model 47LH40 to 1080p using my LG remote
1080p video resolution can only be achieved by a Blu-ray Disc. Satellite TV, broadcast TV, cable TV do not actually send out 1080p resolution. So unless you are using a Blu-ray movie, you will not be viewing 1080p. Your HDTV has a NATIVE screen resolution and the TV will SCALE all incoming video to its native resolution. Most people cannot tell the difference between 720p and 1080i. 1080p signal sources are slightly sharper. But if you have a HDTV that is 1080p capable and you give it a 1080p source (Blu-ray Disc) and use a HDMI cable to connect, you will get 1080p, you do not have to change the HDTV as it will automatically display 1080p.
Mar 25, 2011 | LG Televison & Video
I have a VL470M and am trying to connect a LGBD570 Blu-Ray through HDMI. It works fine through the composite input, but the HDMI says "no signal". Am I doing something wrong?
There are two possible issues. 1) The resolutions are mismatched. (output of the player and input of the TV) 2) the player can not confirm that the TV supports HDCP over the HDMI connection. Only 3 of the 4 HDMI ports are HDCP (high def copy protection) compatible.
Try a different HDMI port and make sure that you have the input set to the correct HDMI port. (There is an input button on the side of the TV as well as on the remote.)
The easiest things to check are turn off the Blu-Ray player and then turn it on again. Then press the Home button and navigate to the Setup Menu. Select Display and press the right arrow button, then select Resolution and press Enter. Then set the desired resolution and press Enter to confirm the selection. (Your TV should support 1080p from the Blu-ray player.) Then turn off the player since changing the resolution can lead to video issues.
I hope this helps.
(the manuals for the TV and the blu-ray player are available on line: http://www.vizio.com/vl470m.html and http://www.lg.com/us/tv-audio-video/video/LG-blu-ray-dvd-player-BD570.jsp Click on Support on either site.
Nov 13, 2010 | Televison & Video
I have an LG 47" TV (47LG50) that I bought a year and a half ago. It worked great up until now. I have three seperate HDMI ports (PS3, Cable and Blu-Ray.) It all off a sudden says "no signal" to all...
Tries reset the tv and cable box,by unplug,replug both devices about an hour later.Let the cable boot up and update it softwares.Goto tv Menu goto PICTURE,go down to reset.The Tuner board it reseting to the Factory setting.The HDMI hubs,should all works now.Not than,the tv Tuner board have problems,must be change.Tries Shopjimmy.com,Ebay.com to buy a refurbish a Tuner board for the replacement.
Jul 15, 2010 | LG 47LG50 47 in. LCD HDTV
Invalid format error with P1600 blu-ray and LG LCD TV 42"
It may be a firmware issue if hdmi works with other items such as playstation.
If no hdmi the main Pcb hdmi ports are bad and the main Pcb would have to be replaced.
Consumers cannot upgrade the firmware so a shop would be the only option.
Jan 17, 2010 | LG 42LC2D 42 in. LCD HDTV
I want the best picture from my 50" LG plasma tv, and I just replaced my 47" LCD LG tv with this plasma and I am not impressed at all compared to my LCD. I guess my question is what a are the best picture...
to C_LATKA:
Hi, I recently bought a 47" LCD LG the latest model and I read that you had purchased it previously and I wanted to know how you found the quality of picture on the LCD? At the moment ours is a bit blurry. I hope it was worth buying. Do you think we just need to tune the picture quality?
Jan 07, 2010 | LG 50PX5D 50 in. Plasma HDTV
Cant figure out to hook up keeps saying no signal with hdmi cable to tv and blu ray put in
What kind of TV are you hooking the dvd player up to ? You may have to go into the TVs menu and set the input to the proper resolution or input style to see a picture. The dvd outputs a 1080i and if the TV is set to 720p it may not show a picture, the dvd output can also be changed to match the TV.
Sep 06, 2009 | Samsung BD-P2500 Blu-Ray Player
Ps3 not playing blu ray on my samsung LCD
Change the frame rate on your tv to 60hd, that should solve it. Basically, your tv might be set to theater mode which is playing 24hd..
May 14, 2008 | Sony Playstation 3 (PS3) Console
LG 47 in. Flat-Panel LCD HDTV Logo
267 people viewed this question
