Question about Refrigerators
Hello I have a GE Profile refrigerator Model#PFS22SISBSS. About 9 months ago, I replaced the main board with the newer wr55x10942 part. It started working well and did so for several months until just recently it stopped cooling as well as it used to. Fridge temp=38 dergrees; Freezer=23 degrees and it is working all the time with a loud buzzing sound coming from behind (somewhere between the bottom of the fridge and the mother board. Has the motherboard gone bad again, or is it the compressor?...or something else. Thanks for your help. Sincerely, Phillip Velinov
  • 1 more comment
  • velinovi Jun 05, 2010
    It is not so much the sound that bothers me, but more so the refrigerator's inability to cool down both the fridge, but even more so the freezer to the specified temperature. I disconnected, cooled, and reconnected the main board, which was rather hot. In about an hour and a half the freezer dropped down the temp. by 2 degrees (it is 23 degrees now) and fridge by 4 degrees (39 now). Thanks for your advice and solution.
  • velinovi Jun 09, 2010
    The temperature of the refrigerator is being held either at the programmed 37 deg. or it goes down below to 35, but the freezer's temp is still between 10 and 15 deg F with a programmed 0. The compressor when first kicking in is rather loud (loud buzzing sound) at some point it becomes quiet as it is supposed to and cools better. I took out the main board and replaced it about 9 months ago. With us gone in the last month the temp in house has gone up to 80-85 degrees. When I checked the main board it was hot. I unplugged it and let it cool down, then plugged it back in. The buzzing started again but later it started working normally as described above for the first time. In the course of the last 3 days the freezer has been able to drop from 24 to 10-15 degrees, which is not great but is something. The coils are clean, there is nothing touching the compressor that would make the loud noise. I also don't want to change the start relay and capacitor unless I am absolutely sure that this is the problem. Please, let me know what you think. Thanks
    Please, before you answer my question read all the information I have given in the previous entries. Yes, the refrigerator part is cooling well-it is right on the programmed temp (37 deg F or +/- 2 deg). The freezer, however, is very slow to cool all the way to 0 deg F. It has taken 7 days after our arrival (the cold air in the house was turned on then)for the freezer to drop the temp. from 23 deg F to 12 deg F. There is loud buzzing, which sometimes goes away while the compressor is working. If this is a compressor problem, is there anything I can do without replacing the whole compressor? Is it not possible, that the unit simply overheated during a month of hot weather and no air-conditioning in the house, and it is taking time for it start working normally? Is it the relay and capacitor? Is it the main board? So far, I have had 3 experts answer my question, and have gotten 3 different answers, and YET THIS IS THE SAME REFRIGERATOR WITH THE SAME PROBLEM. Thank you for reading the previous remarks and for your input.
    Sincerely,
    Phillip Velinov
    317-730-6799
  • 2,272 Answers
If you hear a buzzing noise from the compressor area then its not always that compressor is faulty and needs to be replaced.There are many other possibilities That has to be checked before ruling out the compressor faulty.
Beside the compressor there is a relay.its a compressor relay.Relay many a times gets cracked due to over heat and makes noise.Also if you remove the relay out and shake you hear a rattling noise from the relay if its faulty.cracked.The other cause can be the fan on the compressor.Its can compressor fan.If the fan motor is gone weak then it can make the buzzing noise.as the motor is gone weak so it requires more power to spin the fan and this noise can occur.The other thing to check is the Defrost timer.There is a defrost timer beside the compressor and compressor relay.Its a white color box.If this timer is not spinning or spinning very slowly.Then this can be the noise of capacitor in the timer.the timer is the part which sets the compressor to start and stop.While in defrosting mode the compressor fan starts running and while in frost mode the compressor fan stops.So get this three things checked first.All the things can be checked with meter.If they checks out ok.Then yes the fault can be in the compressor.As the board is replaced 9 months ago.So board going bad in such a less time is bit rear but still cannot be ignored.
This will help.
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Posted on Jun 09, 2010
  • 5,081 Answers
Buzzing sound is always involved with the compressor. Check the compressor first before replacing it. If is faulty please do replace it.Is the refrigerator cooling well and working ok? If not then it must be surely compressor.
  • Refrigerators Master
  • 43,501 Answers
It sounds to me like you have another different problem now... the compressor may or may not be going bad, but it at least is not starting properly every time. This may cause it to owrk till it shuts off and then need a few tries to start again, and that is the buzzing sound you are hearing...changing the start relay and capacitor may help or eliminate to problem, at least for a while...
You can read more about this in a tip that I wrote....
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
Refrigerator Troubleshooting Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
heatman101
Posted on Jun 05, 2010
    President:
  • 1,561 Answers
The problem is no the mother board, the problem is from the compressor, follow the below procedure and solution to resolve the problem.
This can be annoying. Unit noises are, sometimes, normal, but most are signs of very serious issues. Any type of knocking, or pinging, will indicate that there are serious issue that concern the compressors internal seal, and structure. Normally, these noises will be located at the actual compressor area. Here are some other common noises that will occur overtime. These are , generally, repairable and pose no serious threat to the unit.
Lets start with the common hissing and popping. Hissing and popping is normal on frost free refrigerators, it is the defrost heater, in this case. I would check these following areas to address any other abnormal noises. The next issue will deal with proper leveling of the unit.
If the level of the unit is not adjusted to proper specs, this will create an unstable operating condition, causing many noises to emit from the units structure. inspect the unit for proper level. adjust if needed. Secondly will be the drain pan. Once removed for cleaning, the pan must be replaced in position correctly. If not, the pan will rattle against the compressor, causing a rattle.Simply reposition the tray if this is the case. The third possible issue will be the condenser fan. The condenser fan is located behind the refrigerator. It may be necessary to remove an access panel to reach it. This fan has a shroud or cover, and if the fan blade becomes warped, it will rub against the shroud, causing noise. This fan blade is whole,and it can be removed and replaced if this is the case. Ok, the fourth problem spot will be the evaporator fan.
The evaporator fan is located at the back of the freezer. It may be necessary to remove obstructions such as the contents of the freezer, freezer shelves, ice maker and the rear inside panel of the freezer, as well. The rear panel may be held in place by retainer clips or screws. Remove the screws or depress the retainer clips with a small flat-head screwdriver. Check the fan for warped blades. if the blades are warped or mis-aligned, replace it. This fan also is protected by a shroud as well, and it will make noise if the fan blade is damaged.
Now. The last area of concern will be the compressor mounts. This is the most common spot for noise overtime. The compressor sits on rubber mountings. Those rubber mountings are designed to absorb vibration from the compressor. As the mountings age, or depreciate, they can become very hard(Dry rot), or disintegrate. When this happens, the compressor vibration is transmitted to the refrigerator structure and it can cause noise.The compressor is located in the rear. It may be necessary to remove an access panel to expose the compressor. Once exposed, remove the screw or retaining clip of just one of the compressor mounts.Using a pry bar, lift up the compressor enough to slip out the rubber mount. Inspect the mount for deterioration. The rubber should be firm but not rigid. If the mount is crumbling or hard, it should be replaced. If you can do this alone, i suggest you get someone who can do it for you.
Take care.
  • 1 more comment
    What about the inability of the freezer to cool down to 0 degrees F? Can that issue be related in any way to the buzzing sound? If yes, then that will narrow down your answer. In such a case, which of the scenarios described by you might actually be the problem? Thanks
  • Sulaimon Jimoh Olayemi Jun 05, 2010
    Yes, the noise can result in your refrigerator not getting cold. Inspect the gasket for dirt or debris that could prevent
    it from
    sealing. If you find any, remove the large debris, then wash the gasket,
    using a scrub brush and warm, soapy water.
    Check the gasket for
    cracks or tears that can let cold air escape. If
    you find any, replace the gasket.
    Check for coil problems. The
    compressor can overheat due to dust
    buildup on condenser coils. If so, vacuum the coils.
    Take care.
    This are the related problem with your
    refrigerator, troubleshoot with the above to solve the problem of your
    refrigerator not cooling.
    Take care.
GE frig not cooling, both refrig and freezer. started with ice/water dispenser not working.
WR55X10942 Main Control Board This sounds like motherboard failure. I am not sure what your model number is but that will be important should you have someone to help repair your refrigerator. These problems are common on the Artica Profile Models. I will be here to help you repair if you should choose, Thanks Sea Breeze
Apr 24, 2013 | GE Refrigerators
GE model Pfs22miwww. Condenser fan and compressor not running. Tested start cal it is ok. Changed ontology board. Condenser fan now running. Still no compressor
Have you changed out the WR55X10942 Motherboard? Here is a link to test points on the motherboard HERE and here is a service manual HERE I don't mind helping answer your questions so feel free to contact me, Thanks Sea Breeze
Mar 22, 2013 | GE G.e Refrigerator Wr55x10942 Motherboard...
Problem with defrost heater on GE side by side
Not really (shored out) Gidget Jordan,
Although I have experienced a high failure rate o the defrost thermostats... if they conduct at freezing and open near room temperature... they are good (designed to protect the soft plastic refrigerator interiors).
The third and final element of your DEFROST system
is the power board... (costly but easiest to change).
Amazon com wr55x10942
Unavailable at appliancepartspros
GE WR55X10942 Main Control Board AppliancePartsPros com
Sears
Refrigerator Electronic Control Board Part Number WR55X10942 Sears...
These parts are all pretty much the same quality...
Let the VIDEOS & price be your guide...
Carnac the Magnificent
Apr 21, 2017 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a freezer on top GE profile arctic fridge. It heated up for 24 hour then went back down and is now hovering at 7 freezer and 42 fridge. What is wrong?
This is a common problem with the GE Artica and Profile. The mother board=> WR55X10942 Main Control Board Compressor start components and condenser or evaporator fans must also be considered in the diagnostics. If you would like to do this yourself let me know and I will be glad to help you go throgh with the testing, Thanks Sea Breeze
7_10_2012_2_44_57_am.jpgWR55X10942 Main Control Board
Jul 09, 2012 | GE Profile Arctica Stainless Steel Top...
PFS22SISBSS CLICKING AND NOT COOLING
Hi this is the main control board, part # WR55X10942, this should fix your problem.
Thanks for using fixya.com, if this has helped please rate my answer. Thanks!
Mar 30, 2011 | GE PFS22SISSS Stainless Steel French Door...
GE profile PFS22SISBSS running hot and making a clicking noise for several days
the computer board is bad part number WR55X10942,it's on the back outside wall of the machine
Oct 20, 2010 | GE Profile PSW26P Stainless Steel Side by...
I have a ge profile fridge model # PDS22SHRBRSS needing help
Yes, you have to cut the wiring as the instructions stated. Not all the models have to have wiring cut, so read carefully to see if yours is one that needs to have the wiring cut. If it is not, then you have another problem, and you will have to let us know what the origional problem was before you replaced the board. If your model requires cutting, you may have damaged the main board by not doing this. Unplug the refer and follow the instructions carefully and test to see if it works. Good luck, Appliance Specialists.
Feb 04, 2010 | GE Profile Stainless Bottom-Freezer...
I am replacing a defective GE refrigerator main board (WR55X10416) in my GDS20SBSASS GE fridge with the newer WR5510942 main board. I have read elsewhere that a wire on this board may need to be cut,...
You should have included instructions that came with this board and the serial# is what dictates if a wire is cut or not on the main board. there also might be a wire on the harness that plugs into the wall that needs to be cut although I have yet to find one.
The provided link has pics of the instructions. just check your serial # to verify and follow the directions
GE WR55X10942 WR55X10656 Refrigerator Main Control Motherboard CB10942
cb10942-wr55x10656-wr55x10942-refrigerator-main-control-board-ge-pliqakvp0l11djscamij510i-4-0.jpg
Feb 07, 2018 | GE Refrigerators
I have a GE Profile,model PFS22SISBSS,3 years
Possible main pcb failure failure which would cause everything to cut out and restart . Is the compressor or back of the appliance hot ?? Do all the control lights go out when the compressor cuts out ??
Feb 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Icemaker not working, freezer not getting cold enough....
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Jan 18, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
200 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
