Question about Sirius Audio Players & Recorders
Can't get any Sirius channels on any FM frequency stations
I just got a replacement for a Sirius Sportster SP-R2. My old unit lost the lights and was becoming impossible to acquire a signal after I hit a bump. Now, the new SP-R2 I got, the FM frequency doesn't go below 88.1 and it's the same model. My old unit went as low as 87.1 (where I got all stations in clear). I can't find a signal weak enough over 88.1 to tune my Sirius into (all local radio stations knock it out). I don't get any sound from my new unit unless it's on the docking base with speakers. Why doesn't this unit go lower than 88.1 and why can't I the Sirius stations to tune into any FM stations (I went through every frequency 88.1 through 107.9)
SOURCE: sirius sportster sp-tk1, always displays "acquiring signal"
Same problem in RI too. Acquiring signal stays on the screen 24/7. My husband has the same Sportster. When I plug his into my car docking station, it works fine. When I plug mine in, it says "Acquiring signal". Does this mean my radio is dead?
Posted on Jan 06, 2008
  • 20 Answers
Hi guys!! I am a sirius satellite radio employee and unfortunately, when this happens (usually when the receiver is about 2 years old) the radio is pretty much shot. It is a common problem with the older sportster models, but not so much with the newer one. As the receivers are probably more than a year old, they are now out of warranty and the only resolution is to call us at sirius and say you want to cancel the subscription on the radio. When cancellation is imminent, we will offer to send you a replacement (although it will be a different unit not compatible with you current docking stations) at no cost to you. Sometimes an antenna replacement will actually stop the problem, but it will happen again very shortly afterward, and thus it is only a temp fix to a permanent problem. Hope this helps you out!!
Posted on Feb 20, 2008
SOURCE: SIRIUS Sportster "Acquiring Signal"
Let me save you $30.00. A new antenna will not help, nor will cleaning the contacts. I just did both of those and it did not help. I have mine in the freezer right now cooling it down. Sirius told me that I should not leave it in the car because it gets to hot. They told me to buy another unit....
Posted on Aug 12, 2008
Sirius does not stand behind their products, There is no out of warranty repair for their radios,  and they do not offer sites for repair. Seems  like this is a definite problem with this model. Their solution is to buy a new radio,(with all the new-docking,boombox etc) accessories. also they charge $75.00 to change to the new radio.I liked my sportster 1 because of the FM modulator. It just had to be centrally located and all the radios in my home picked it up(no docking) the new radios require $50.00 docking stations for each stereo location and radio location, unless you bring a boombox everywhere, and the sound isn't the same.    I feel there should be a class action lawsuit against Sirius for these reasons and I might look into it. What do all you think?
Posted on Aug 31, 2008
  • 4 Answers
SOURCE: my sirius sportster ( SP-R2 ) satelite radio
did you try going into the menu and increasing the volume output
Posted on Feb 13, 2010
How to change fm seting on model ucb. I am traveling and have been plagued with local stations on 88.1
menu settings, tm channels. in there you select the frequency you want then hit select. then tune your stereo.
the only problem you will have is that as you travel you will end up having a station on any channel you are on. you will have to switch it a lot. there are 2 things you can do. 1 you can get an adapter that plugs from the sirius to the antenna port on the radion and then the cars.antenna in that. when sirius is on it bypassed the antenna on the car and pipes the signal right into the radio. or2 you can do what I did. I do not use am or tm so I completely disconnected the antenna.so I get no fm interference at all.
Jun 21, 2011 | Sirius Radio Communications
In my settings there is no fm transmitter selection available
As far as I know, there is no transmitter in a Sirius Radio. I had an XM, and there was no selection for fm stations. They just figure you can tune the car radio to any fm station, in case you want to listen to fm. Hope this helps, but refer to your manual for details about what the unit can do.
Jun 12, 2010 | Sirius Sportster 5 Satellite Radio...
What fm station do i use in the car
You need to find a clear radio frequency in your area then in the SIRIUS sat radio you will find a FM transmitter frequency adjustment menu. set it to the same as your fm radio and your all set.
Feb 19, 2010 | Audiovox SIR-PNP3 SIRIUS Radio Receiver
Same problems here also, had sp-1 for 4 yrs no probs at all! I even have a brand new antenna, needed to be replaced any way, thought that would fix problem (ACQUIRING SIGNAL) No luck ,why does everything...
Go to XM, I did. But first, call Sirius and ask them to 'refresh' your receiver. Leave unit on channel 1 for 30 minutes and see if problem go away. Make sure to turn off and on with pushbutton on unit - not remote, and do not just diesconnect power..
Dec 28, 2009 | Sirius Satellite Radio Sirius Sportster...
Can't get XM channels
Goto sirius.com. You will need to access you account and find out if your radio is upgradeable for XM channels. You can find that out once you try to add xm to your account.
If it isn't you can get a free or a discounted radio from them to do it by calling customer service up. They do that for existing customers.
Jan 17, 2009 | Sirius Satellite Radio Sirius Sportster...
STATIC/INTERFERENCE
&R=11812445&C=17577363&K=NBy0rr?h=2mv3s7&r=11812445 Your SIRIUS radio contains an FM transmitter that allows it to operate wirelessly through your car FM radio. We have determined that the output of this transmitter exceeds the limits established by the Federal Communications Commission (FCC). As a result, the unit may interfere with the performance of radios operating in areas adjacent to your radio. There are no health or safety concerns associated with this issue.
  • If you listen to your SIRIUS radio wirelessly through your vehicle's FM radio, then please review the solutions listed below and select the one that works best for you. SIRIUS will provide you the best solution at no cost.
  • If you use your SIRIUS radio only when docked in a boombox, or directly connected to your car radio or home stereo using audio cables or a cassette tape adapter, then no interference can occur and no further action is required, provided you have turned off your FM transmitter. To turn off the FM transmitter, first press the MENU button. Use the channel up/down buttons to highlight “FM Transmitter” and push the SELECT button. Use the channel up/down buttons to highlight the "FM On/Off" menu item and then press the SELECT button. Use the up/down buttons to highlight "FM Off" and press the SELECT button. To exit the "FM On/Off" menu, press the MENU button. Use the same procedure to turn off the FM transmitter if you use Solution 1 or Solution 2 below..
Solution 1 - Direct Wired Audio Connection: If your vehicle radio has a “LINE IN” or “AUX IN” jack, you can use a stereo cable to connect directly to your SIRIUS radio. This solution is the easiest to install and provides the best audio performance. Many newer vehicles provide the required audio input jack. It will normally be found on or near the front faceplate of your vehicle’s radio.
Solution 2 - Cassette Tape Adapter
: If your vehicle has a cassette tape player, you can use a cassette adapter that allows you to play your SIRIUS radio through the cassette portion of your vehicle radio. The adapter slips into your vehicle radio as easily as a cassette tape and provides better performance than a wireless connection. fcc_a_2.jpg
Solution 3 - FM Extender Cable Kit: An FM extender cable will provide a special transmitter antenna that allows you to obtain the best audio performance through your vehicle’s FM radio. This solution is easy to self-install, but does require that an easy-to-hide wire be run in your vehicle so the transmitter antenna can be placed in close proximity to your vehicle’s radio antenna. Using this FM Extender Cable Kit, you will continue to use your SIRIUS radio exactly the same way as you do currently. fcc_a_3.jpg
Solution 4 - FM Direct Adapter with Professional Installation: An FM Direct Adapter provides a wired connection between your SIRIUS radio and your vehicle’s radio. You will continue to listen to your SIRIUS radio through the FM tuner of your car radio, but the FM Direct Adapter eliminates the outside static and interference you sometimes experience when using a wireless FM connection. This solution usually requires professional installation. We will provide a certificate redeemable for installation at an installation center in your area.
Please go to www.sirius.com/optimize and select the solution that works best for you. If you have any questions, please call 1-(877) 635-5130. Detailed instructions will be included with your solution.
You will improve the performance of your SIRIUS radio and reduce the potential for interfering with adjacent radios if you properly tune your FM transmitter. Please see the FM Transmitter Set-Up Tips below for more information.
We are sorry for this inconvenience. We are confident these solutions will allow you to continue to enjoy the great music, news, sports and entertainment that only SIRIUS Satellite Radio can offer with no impact on your radio’s performance.
Sincerely,
SIRIUS SATELLITE RADIO
To tune your FM transmitter turn off your SIRIUS radio and tune through the FM channels on your vehicle’s radio to locate an FM channel (except 87.7/87.9) that is not broadcasting in your area. If you use an FM channel that is being used by a local broadcaster, it will interfere with the performance of your SIRIUS radio. Once you have located an FM channel that is not being used for broadcasting in your area, save it as a preset on your vehicle radio. This will become your SIRIUS preset. If you’re not sure which FM channels are not being used in your home or travel cities, you can go to www.sirius.com/fmchannel and search for an FM channel based on zip code.
Turn on your SIRIUS radio. In the SETTINGS or MENU on your SIRIUS radio, locate the “FM Frequency” adjustments. Set the channel number on your SIRIUS radio to match the SIRIUS preset on your vehicle radio. Refer to your user guide for detailed instructions on how to do this. The FM transmitter in your SIRIUS radio is automatically set to FM channel 88.1. This may not be the best channel in your area.
Jul 08, 2008 | Sirius Starmate ST2 Satellite Radio...
Feb 07, 2008 | Sirius Satellite Radio Sirius Sportster...
Sirius sportster sp-tk1, always displays "acquiring signal"
Dec 03, 2007 | Sirius Satellite Radio Sirius Sportster...
Sirius Sportster
Look at the bottom of your unit, you'll notice the round port next to the slot? It get's jammed up inside the unit if you pressed to hard setting it into the cradle at some point. Not easy to fix, unfortunatley.
Oct 22, 2007 | Sirius Satellite Radio Sirius Sportster...
71 people viewed this question
Top Sirius Audio Players & Recorders Experts
John
John
Steve
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
