Question about Sewing Machines
Globe sewing machine 390 need instructions on how to thread the machine
SOURCE: threading a sewing machine
What do you mean you are unable to pull the bobbin thread through, elaboration would help solve the problem...
I suspect I'm having the same problem with you if it's anything to do with the top thread looping around in the bobbin holder.
Damn machine!
Posted on Feb 26, 2008
SOURCE: thread keeps snapping on NEW Euro Pro 32-Stitch sewing machine
I also have the same sewing machine. The machine is not very user friendly and the instruction manual doesn't really illustrate the right way to thread the machine. For the bobbin, make sure you thread it through the two tiny holes in the small rectangular metal piece in the bobbin case. I had to use a dental floss threader and tweezers to thread the bobbin correctly, if you can believe it! As for the upper thread, follow the directions EXACTLY as illustrated in the manual. Don't miss the little loop underneath the machine or the tension will be wrong.
Also, use extra strong thread. I used a professional quality break-resistant thread from Germany for both the bobbin and top thread, and the machine works okay.
Posted on May 19, 2008
  • 323 Answers
SOURCE: instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
Posted on Jun 05, 2008
Michaelle
  • 65 Answers
SOURCE: need help to thread our sewing machine.
you really must get a manual for this machine.
You can find manuals online for a small price.
At one time some sites had them for free, but I haven't been able to find many recently. sewusa.com has some older ones for free. but not many. you could try the kenmore site as well, if not I'd try to search on dogpile.com (sewing machine manuals)
Just so you know, your manual is the MOST important tool for any sewing machine, and its worth a couple of bucks to get it.
Posted on Jan 24, 2009
  • 240 Answers
SOURCE: How do I thread my Singer 7422?
I suggest you do a search on youtube on how to thread a sewing machine and choose a video showing a similar machine as there are really only about 3 basic types of machine as regards the threading.
Some of these instruction videos are very good and you will find it much easier than explanations. However-the important thing is that the thread must go between the tension discs by your tension regulator and do make sure you have a good need le in the machine, inserted correctly.
Posted on Jun 22, 2009
Thread globe 877 sewing machine
Remove the top thread from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Verify the thread path is correct.
Set the top tension to the midway point and then tweak it so the top and bobbin threads meet in the middle of the fabric.
Jul 28, 2017 | Sewing Machines
How can I set the right tension on an overlocker globe lock m-34?
The right tension on an overlocker will vary depending on the result that you want. The standard tension for just a plain 4-thread overlock stitch would generally have all the thread tensions set at the halfway mark between the high and lower number. From that point, you may need to tighten or loosen each thread tension to get all the threads to stitch evenly.
Probably the best advice would be consult your owner's manual. It should have instructions on adjusting the tensions and what to look for.
Another suggestion would be to search YouTube for a video that shows how to adjust overlocker tension.
Nov 14, 2015 | Sewing Machines
Globe electronic 390 zigs once then continues as straight stich. Can hear click inside machine as if button is turning off, yet button remains depressed.
there may be a problem with the gear or cam that makes the zig zag stitch, it would be a good idea to have the machine checked
Mar 16, 2014 | Sewing Machines
Need an operating manual for a globe electronic 937 sewing machine
contact sewusa.com,, they have threading diagrams & if they don't have the one
you need email them or call them about the machine, & see what they can tell you
also sewvacdoctor.com
Jan 30, 2012 | Sewing Machines
I cannot remove light cover on ceiling fan to replace globe
There are usually small screws around the outside of the globe that screw into a recess on the globe with a rubber ring around it to keep the screws from hitting the glass.
Dec 31, 2009 | Sewing Machines
Singer Sewing M/c Model mon ami II deluxe 390
I've been looking high and low to see if I could find you one for free, but I can not.
You'll have to contact Singer to get a replacement instruction manual. They cost around $10.
I'm sorry I couldn't find you one for free.
Hope this helps. =)
Oct 20, 2009 | Singer Featherweight 132Q Mechanical...
6022 necchi sewing machine
There is a site that has instructions with how to thread the machine properly. Click here for the www.sewusa.com threading section
Nov 03, 2007 | Necchi 3537 Mechanical Sewing Machine
Sewing Machines Logo
174 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
