Question about Samsung RB215LASH
Samsung rs2545sh freezer quit
The freezer side quit working we unloaded it and it defrosted by tiself and started again but will only go down to eleven degrees
  • Samsung Master
  • 4,654 Answers
I hope it is still in warranty for the five year sealed system repair. I am very familiar with your model and you can do some test and try forcing defrost but the biggest problem is someone engineered that model with the defrost heater woven into the evaporator coils. Click Here for RS2545SH Service Manual and Here=>RS2545SH Tech Sheet I want to be optimistic an say it is either the=> Thermal Fuse DA47-00095E or the Defrost Sensor DA32-00006W Stick with me on this and we will find an answer either way. Please rate my solution after I have helped you resolve the problem and communicate with me. I am offering my help to you free. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Posted on Jun 05, 2010
Temprature blinking
Control board has gone bad....
What happens is the defrost is controlled electronically from a circuit board, when this goes bad, the freezer quits defrosting, and freezes the fans that circulate air through the fridge side of things.
To check this, unplug the entire fridge, leave the freezer open, wait for it to defrost a bit, if this causes the fridge to start cooling again when you plug it back in, then its the defrost. You should also see ice crystals on the back of the freezer just under the icemaker.
http://forums.partselect.com/refrigerator-freezer-repair/rerifgerator-side-not-below-54-degrees-6699.html
Jul 07, 2013 | Freezers
Samsung refrigerator model rs2545sh/xaa. Freezer works good, but refer side does get cold.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jun 12, 2011 | Samsung RS2630SH Side by Side Refrigerator
My samsung side by side was working great untill
You have an automatic defrost problem. The refrigerator is not defrosting
Three important parts. It probably is one of these.
Defrost Timer
Defrost thermostat
defrost heater.
The fan is probably fine, but has nothing to do with Defrost
Check the heater continuity and change the heater defrost thermostat
then replace timer if those don't solve it.
Leo Ponder
imufo2@sbcglobal.net
Jul 30, 2010 | Samsung RS2630SH Side by Side Refrigerator
RS2545SH. Fridge side is not cooling. Thanks
I have the same problem....anyone have a fix
Oct 18, 2009 | Samsung Refrigerators
this is a design fault on the appliance normally caused by the failure of the element and built up of ice around the circulating fan (the humming is the fan motor trying to turn ) youll find that if you defrost it it will work for a little while and then ice up again the need to replace a panel inside the fridge modified and a couple of sensors and poss the heater element
Oct 30, 2008 | Samsung RS2630SH Side by Side Refrigerator
Samsung fridge RS2545SH every 7 days freezes fridge coil.
Hey how yo doing? on most refriderator there are two important parts to keeping freezer from freezing over, they are the bimetal thermostat and ice pipe heater. The bimetal therostat is a preset thermostat that ranges from 54degrees farenheit to about 60, when the coils (inside the freezer compartment behind the back panel) reach the preset temp. it closes a circuit and send electricity to the ice pipe heater, to warm the freezer coils preventing from freezing over. if any one of those components fail, your freezer will continue to freeze solid until there is no more space for ice to build on coils decreasing air flow from the evaporator fan blowing air into your fridge.To test you will minor knowledge on using a multimeter.(REMEBER TO UNPLUG REFRIDGERATOR BEFORE SERVICING, IF YOU UNCOMFORTABLE WORKING ON APPLIANCE PLEASE CONTACT A PROFFESIONAL REPAIR SERVICE..) If you'd like to continue please respond.
GOOD LUCK, WORK SAFELY..
Aug 12, 2008 | Samsung RS2630SH Side by Side Refrigerator
Have a 2 year old SAMSUNG RS2545SH Side by Side
Mar 05, 2008 | Samsung RS2630SH Side by Side Refrigerator
Samsung RB215LASH Logo
519 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
