We bought a new computer and are trying to connect the printer but it won't respond.
  • 4,102 Answers
is the printer plugged into computer via usb port or normal paralel port in back of computer check its in the right place and check the cable is in printer properly and also computer then the best way to see if its recognised is goto start bottom left then acess control panel on left hand side change it to classic view just under where it says control panel it might all ready be classic view if it is then select add hardware then dont click have disk then the computer will scan for all hardware connected to it when its finished scroll down list and see if your printer is listed if it is click it.
it will then ask if you have disk if you do insert it and click ok if you dont then uncheck the box have disk then your computer will scan for correct drivers for the printer ok
Make sure printer is plugged in and on whilst doing this ok then you should find you have no problems.
let me know how you get on then ill get back to you ok
Posted on Apr 09, 2008
Printer not printing
fitting a new computer requires a driver for the printer installed on the new printer
it is the pc that controls the printer , not the other way round
Aug 18, 2016 | Canon PIXMA iP1600 Printer
Why does my canon mg5420 say "printer not responding"
Whenever I hear of a "not responding" problem in the same sentence as "Wi-Fi" I question the wireless connection. I'm sure you've done the tests, but just to go over them; Is the printer working - can you get a test print out of it locally (setup)? Is the computer actually "talking" to the printer (Check network settings and local connections)? And, can you connect directly to the printer using a USB lead - and get a print? I would be tempted to tell the computer to find a new printer, in order to double check.
Jun 29, 2014 | Canon PIXMA MG5420 Inkjet Photo All-in-One
My scanner is plugged in but when I try to scan a document it says my scanner is not responding
If it is your first time using your printer, then you need to install the driver for it to work.
If you have used your printer without any problem before then, there are two possible reasons why your printer/scanner is having that issue:
1. Connection error
2. Driver problem
First thing's first. Restart your computer and your printer. there are times that computers and printers just need a restart for it to work. Yes, it's strange but it's how things work with machines. They need rebooting to work smoothly.
If rebooting your computer and printer won't fix the problem. Here are the things that you can do.
1. Connection error:
a. Turn off your printer and turn it back on. Try scanning, if no go.. proceed to step b.
b. Unplug your printer from your computer and unplug it's power cord and press and hold the printer's power button to 5-8 seconds to completely drain the power. Plug it back in to the wall outlet leaving the connection between your computer and the printer still unplugged. wait until your printer completely turns on. Plug it to your computer and do the scanning process.
If all steps above don't work, then you need to check the driver.
Uinstall the driver of your computer by going to the control panel. After uinstalling it, then reinstall it by using the dvd that came with your printer. Follow the on-screen instructions and try scanning. It should work.
If it doesn't, please reply to this thread.
Thank you for using
Carlo Adrian
Nov 14, 2012 | Dell Photo 926 All-in-One Printer
Printer not responding
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Mar 27, 2012 | Lexmark X3650 Printer
My Kodak all in one printer won't respond to my computer comands. It won't connect to my wireless internet at all. It was working fine, then one day it just stopped responding. What do I do?...
This used to happen all the time when I had one. The best thing to do is to completely uninstall the printer and all it's added programs from your computer.
Switch off the computer and let cool down (have a cup of coffee) Now reboot the computer and then reinstall the printer and follow instructions to connect via Wi Fi
If this works make sure auto update is switched OFF as every time mine was updated your problem occurred. So much for Degreed wonders who try to justify their existence and completely mess up a perfectly sound working system when they don't know what they are doing, shame they never seem to have a brain or any logic.
Jan 19, 2018 | Kodak ESP5250 All-In-One InkJet Printer
My cannon pixma MP150 just won,t print or do anything, it is connected to the computer alright & the computer says that it is connected but it just won,t print or scan, can you please suggest anything...
probably you need to download the driver for windows 7 in the canon website.( if this doesnt solve your problem check the led and display of your printer. if the led blinks alternately in orange and green it means that your printer needs to be brought to an authorized service center for resetting and diagnostic.
Feb 13, 2010 | Canon Office Equipment & Supplies
My canon MP610 printer is not responding after replacing ink
Try switch of computer and printer if not in printer list of printers. Unplug usb cable and start computer without computer connected. Them switch off computer again and plug in usb cable and then restart and after started switch on printer and Windows should find printer as a new connection and then you may need your driver disc to reset up.
Mar 17, 2009 | Canon PIXMA MP610 InkJet Printer
53 people viewed this question
