Question about Bosch 1274DVS 3" x 21" Belt Sander
PBS 7 AE belt won't turn and dust won't collecr
Belt won't turn power from wall is good
    New Friend:
I had the same problem. On mine it was because the drive belt had worn out. This is under the black cover on the side. You have to remove three torx screws to remove the cover.
Posted on Jan 05, 2013
Samsung frontload dryer will not spin...drive belt is okay...power is okay...motor does not seem to turn on???
Most likely it is the thermostat. It may also be the motor, but usually you will hear humming of some sort. There is a small thermostat on the blower housing that usually goes bad and presents the situation listed.
Jan 23, 2015 | Samsung Dryers
Blue light but tv won t turn on
Try these troubleshooting steps:
- Try to power on the TV using the button on the TV and not the remote
- Ensure that the power cover is securely connected
- If you are using a power strip connect the TV directly to the wall
- Try a different outlet
- Can the outlet power any other device?
Good luck
Feb 05, 2014 | Sceptre Televison & Video
Toshiba tv/dvd won't turn on
Check the reset button, wall socket where it plugs in, power cord, and if equipped cabinet interlock.
Bypass the on/off switch with a known good one.
Next check the voltage setting device it could be faulty.
It usually is set for 125v.
good luck!!!
Feb 24, 2013 | Toshiba 20a43 20" TV
I have a Bosch Nexxt Dryer 800 series when you try to turn it on, it just makes a click sound, but won't turn on. Any ideas about what's wrong. Thanks Marge
see this causes and fix it. God bless you
Timer The timer is normally not at fault when the dryer won't start. In many situations where timers are replaced they end up being returned. First, check all of the more common components in this troubleshooting guide before replacing the timer. If the dryer won't start, the cause is much more likely to be a thermal fuse or switch. The timer can not be tested, it must be replaced if it is defective.
Main Control Board The main control board is normally not at fault when the dryer won't start. First, check all of the other components in this troubleshooting guide before replacing the main control board. The main control board can not be tested and must be replaced if it is defective. If there are obvious signs of burning or a shorted out component on the board, it should be replaced.
Belt Switch If the dryer won't start, there might be a belt switch that has failed. This is not a common problem and most dryers do not have this switch. If the dryer has a belt switch, the switch shuts off power to the entire dryer if the belt breaks. It is possible that this switch has failed, even if the belt is not broken. It can be checked with an ohm meter or continuity checker. If the dryer works at all, even if all it does is hum, this is not the problem.
Incoming Power Problem If the dryer won't start, check to certain there is electricity to the dryer. For a gas dryer, unplug the dryer from the wall and plug something else into the outlet to see if it's working. For an electric dryer, check the home circuit breaker or fuses. If they are working, check the outlet where the dryer plugs in with a volt meter. There should be between 208 and 240 volts. If there is power to the dryer, check the more common items in this troubleshooting guide.
Thermal Cut Out Fuse Kit Most dryers have several temperature control devices such as a thermal fuse, thermal cut out, high limit fuse or high limit thermostat. Some manufacturers sell the thermal fuse and thermal cut out in a kit. These kits normally solve no-heat problems rather than when the dryer won't start. However, in some models, this kit will solve both problems. Even though this is not the most common part to fail if the dryer won't start, both can be checked using an ohm meter or continuity checker. If they have continuity they are good. If not, they should be replaced.
Drive Belt On most dryers, if the drive belt breaks the motor can still be heard and it will still be blowing air out the exhaust tube, but the drum will not spin. However, in some dryers when the drive belt breaks the tension pulley arm trips a switch which shuts off power to the entire dryer. If the dryer won't start, check to see if the belt is broken. If it is, replace the belt and the dryer should be fine. If the belt is not broken, check the other components that can fail when the dryer won't start.
Drive Motor The dryer drive motor turns the drum and the blower wheel to exhaust the air. If the dryer won't start the motor might be defective. Before replacing the motor, check the thermal fuse, start switch and door switch because all three are more likely the cause. If the dryer won't start and the dryer motor makes a humming noise there might be something caught in the blower wheel, or the drum might be binding. Try removing the belt from the motor and checking the blower wheel for obstructions. The dryer motor can't be tested easily. If the more common components have been checked and it seems the motor itself is defective, it will need to be replaced. It is not serviceable.
Door Switch The door switch is located near the dryer door and is activated when the door is closed. If the door switch fails, the dryer won't start at all. Many types of door switch will make an audible click when they are activated. If the door switch makes a clicking sound when activated it is probably not defective. If it doesn't make a click, it can be checked with an ohm meter or continuity checker. The door switch is relatively easy to replace and is usually not very expensive.
Start Switch The start switch is on the dryer control panel. Depending on the model, either press a button or turn a dial to start the dryer. If the start switch fails the dryer won't start or make any noise. Test the switch with an ohm meter or continuity checker. If the dryer hums when the start switch is activated, or if the motor runs only while activating the start switch, the motor might be defective or something might be binding the drum preventing it from turning freely. If the dryer start switch does not have continuity when it is activated, it will need to be replaced.
Thermal Fuse The thermal fuse helps to prevent a dryer fire by shutting off power to the dryer if it overheats. If the dryer won't start check this fuse first. Test the thermal fuse with an ohm meter or continuity checker. This is the most common part to fail when the dryer won't start. Once the thermal fuse has blown, it has to be replaced. It can not be reset.
Sep 28, 2012 | Bosch Nexxt 800 Dryer
Frigidaire affinity Dryer wont turn on
see this causes and fix it.God bless you
Sep 28, 2012 | Frigidaire GLER642A Electric Dryer
I have an amana dryer,,,it says drying but it won't start,,no sound or nothing....I tried the fuse wires at the bottom direct and still nothing...so I don't think its the fuse...thanks
Sep 28, 2012 | Dryers
Babylock Esante BLN won't turn on. Wall plug
have you checked the power cord to make sure it's inserted correctly
into the machine?
if it is in the machine correctly, the problem could be the on -off switch
or the power cord
it would be a good idea to have the machine checked at a sewing machine
repair shop
Apr 28, 2012 | Baby Lock Sewing Machines
I have a D52GW12 tv. During a storm a couple days ago there must have been a power surge. I have managed to get the TV's power light to blink but it won't turn on. How do I reset the Tv or fix the...
Unplug from the wall and hit the power button on the tv. The light may come on dim then fade out or you hear a click. This means it has built in surge protection. Plug it back into the wall and you should be good to go if nothing burnt up.
Jun 21, 2011 | Televison & Video
Kenmore HE2 Dryer
That model has a belt switch. If the belt is broken then it will not com on.
Oct 30, 2008 | Kenmore 62602 Electric Dryer
Bosch 1274DVS 3" x 21" Belt Sander Logo
188 people viewed this question
Top Bosch Tools & Hardware - Others Experts
Jim Parker
Jim Parker
Awesome12
Are you a Bosch Tool and Hardware - Other Expert? Answer questions, earn points and help others
