Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
My kenmore oven model 790 does not get hot.It is connected to a double breaker with red, black, white and ground cables. it on and when i try to bake or broil it does not get even warm. It is new and a i bought it on ebay. please help.
    President:
  • 1,561 Answers
If your oven won't get up to temperature, it is likely that either the thermostat needs to be adjusted or one of the elements has gone bad. Both fixes take little more than a screwdriver and a few minutes of your time
Place an oven thermometer inside the oven and shut the door.
Turn on the oven, set it for 350°F (180°C) and let it heat for 30 minutes.
Check the thermometer. Most thermostats are accurate to within 25°F (14°C). If yours is off by more than 50°F (28°C), the thermostat is bad and you will need to have a professional replace it. If your thermostat is off by less than 50°F (28°C), adjust the thermostat.
Locate the adjustment screw. On some thermostats, the adjustment screw is on the back of the thermostat knob; on others it's inside the thermostat shaft.
Posted on Jun 05, 2010
  • 3 more comments
  • mannyfc21660 Jun 05, 2010
    THE OVEN WAS NEVER USED AND IT DOES NOT GET WARM AT ALL
  • Sulaimon Jimoh Olayemi Jun 05, 2010
    The process still continue with the below procedure.
    o make a temperature adjustment on the back of a knob, remove the knob
    and loosen the retaining screws on the back, using a Phillips
    screwdriver. Turn the center disk toward "Hotter" or "Raise" to increase
    the temperature, or toward "Cooler" or "Lower" to decrease the
    temperature. Tighten the screws, reinstall the knob and test the oven.
    Readjust the knob if necessary.
    To make a temperature adjustment inside the shaft, remove the knob and
    slip a thin flathead screwdriver into the knob until it engages the
    adjustment screw in the bottom. Turn the screwdriver clockwise to raise
    the temperature, counterclockwise to lower it. Each quarter-turn will
    move the temperature about 25°F (14°C). When you're
    done, reinstall the knob and test the oven. Readjust the temperature if
    necessary.
    Identify the bad element. Set the oven to broil and check the upper
    element. Then turn it to bake and check the lower one. Both elements
    should turn bright orange if they're operating correctly. If one is
    cold, it needs to be replaced. If they both seem to heat up, look for
    signs that one is damaged. It may appear to be melted in one spot, or
    one spot may not turn as bright a color as other parts.
    If you cannot carry the above troubleshooting on your, i strongly advice you get someone who can or perhaps, since you said the oven is new, you can return it with the complain and order for replacement.
    Take care.
    I strongly advice you return the oven with your complain that the oven never get hot or warm, with this, the unit will be replaced because many atimes, there are some ovens with factory problem, so it is advice you return it and order for replacement of the unit from ebay.
    Take care.
    THIS OVEN IS ALL DIGITAL, THERE NO KNOBS TO TAKE OUT AND ADJUS THE TEMPERATURE.
    Take
    care.
JTP56 Electric Double Oven Dead after self-clean. Power Pigtail comes into back of top control enclosure in flex conduit. The three red,black,white conductors are spliced to 2 molex connectors. I am...
I doubt there is a fuse on the pigtail, it sounds like your black wire is grounded somewhere. Check black to red, if you get 120 or close to it, your black is shorted to ground.
Jun 07, 2011 | GE Profile JTP56 Electric Double Oven
I am instling a whirlpool accubake double oven, my house wiring is 3 wire (black,black,coper) the instructions say coonect red to red, black to black and white and neutral to coper. If neither of my house...
Doesn't matter....hook one black to the black and the other black to the red....copper to the green,white, and/or ground...whatever you have...
then you are good to go...
heatman101
Apr 30, 2011 | Whirlpool Ovens
My newly installed Frigidaire wall oven, model FGEW3065KF fails to heat up except for the convection element. Broiler element makes no heat at all and bake element is uncertain because it is hidden. Before...
I think I can help you but i am a bit confused with the panel box and the junction box. If you want to reply explain the circuit in a bit more detail from the switchboard where the fuse is to the back of the oven. It would also be a good idea to have a voltmeter or test lamps handy. Does the double pole breaker do the Active and Neutral or is it 2 phases going through the breaker. Did the wiring used to be for a full range and now there is only the new oven in its place.
Feb 11, 2011 | Ovens
My Kenmore oven, model 790, displays and beeps the F10 Fault
June 8, 2010
Same thing happened to mine this morning....cut the circuit breaker for a hour....open oven and let it cool....
mine stopped, finally. Dont know if its a long term fix yet.. but at least it stopped the beeping.
May 06, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Connecting wiring into oven
The house wiring was not up to code so the white wire was not supposed to connect to the white terminal on the stove. Instead the white wire connected to the red, the black to the black and bare ground wire connected to the white terminal thus providing ground and two termianls with 110 each.
Sep 30, 2009 | Maytag CWE5800A Electric Double Oven
I have a maytag double oven cwe5100acb that has a black/white/red and a ground wire(s). Where it will be install the wires are black/white and ground. I cannot figure out what wire connects to what. Any...
black= 120 volts to ground
red =the other phase of 120 volts to ground
white=neutral
green/bare = ground
you seem to have a 120 volt wiring. you will need to change this wire to the panel from the existing, to # 6/3+ground you will need a 40 amp double pole breaker. THIS VOLTAGE/AMERAGE WILL KILL! If you are not an electician I would recomend hiring one, as, if done wrong the wiring can cause a fire or worse.
Aug 08, 2009 | Ovens
Admiral Clean-O-Matic oven: Power cord black red white ground?
Your terminal block has been by-passed .
Hook your black cord wire to the black screw on the terminal block.
Hook your white wire to the white screw on the terminal block. Hook the bare ground to the exterior ground screw.
The 2 wires that are wire-nutted together will have to hook to the red wire on the cord.(they originally went to the third connection on the terminal).
You will probably have to cut and strip the red cord wire and attach it with the 2 wire-nutted connections.
May 24, 2009 | Ovens
4 wires to 3
You need to purchase an oven appliance cord that will fit your outlet. the cord will have directions on how to hook it up under your circumstances. If you want more information get back, I will help you.
May 17, 2009 | Magic Chef 9522 Electric Double Oven
What coloured wires go where on the main oven thermostat
If you are speaking of the 240v connection to hook up the oven to the electrical source, then white is the neutral(white to white), black is one of the 240v hot wires(black to black), and red is the other 240v hot wire(red to red).
Finally there is a bare or green color ground wire that goes to the bare or green wire form your source.
normally, the two outside wires on a terminal strip are the hot wires and the middle onif the neutral(white). It does not matter which wire(red or black) goes to what hot terminal at the appliance.
If you are talking about the internal wiring, I can get you a schematic of that.
Mar 13, 2008 | Ovens
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
176 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
