Question about Apple iPod touch
My ipod 32G touch onsly shows apple logo on the black screen. will not do anything when plugged in. I have tried to reset, return to factory settings and nothing works.
    President:
  • 1,285 Answers
Ipod help is near
  1. http://www.everymac.com/systems/apple/consumer_electronics/ipod_faq/ipod-troubleshooting-wont-turn-on-appear-hung-sad.html
Posted on Jun 05, 2010
My ipod touch 8 gb screen has went complettely white and will not do anything. What do I do?
Hi webfoot1304...
White Screen of Death
This is probably caused by not allowing the firmware update to finish the installation before disconnecting the iPod.
Try these steps.
Reset the iPod:
1.Turn the Hold switch on, then back to off.
2.Press and hold the Menu and Select buttons for 10 seconds (until the Apple logo appears).
3.You may need to repeat the reset several times.
If the reset doesn't help, then put the iPod into forced disk mode.
Put iPod into Disk Mode:
Apple suggests that you ensure your iPod is charged before following
the next step. How exactly you check a charge on an iPod screen that
is completely white has yet to be revealed. But hey, give it a shot
anyway. Plug the iPod into a high-powered USB port, let it sit for 2 hours, then disconnect it. If you have a wall charger, plug in the iPod, then follow these steps while it is still plugged in.
2.Press and hold the Menu and Select buttons until the Apple logo appears
3.Immediately switch your figures to press and hold the Select and the Play/Pause buttons until "Disk Mode" appears at the top.
For a lot of people, this solves the problem. Connect the iPod to the computer and (assuming it shows up) reset the iPod again to get it out of Disk Mode.
If at this point you still have the white screen,
restore the iPod using the restore function in iTunes under the Summary tab (this will erase everything on the iPod and put it at factory
settings).
Don't disconnect or eject the iPod until the store is totally done.
After you think it's done, wait another five minutes.
Please take time to rate Me
Aug 23, 2011 | Apple Audio Players & Recorders
My apple ipod 32G does not turn on.
Seems like your iPod has frozen.
Try a soft reset first:
1. Press and hold theSleep/Wake button on the top of the unit until a red slider appears
2. Drag the slider.
3. Press and hold theSleep/Wake button until the Apple logo appears.
If a soft reset doesn't work, try a hard reset:
Press and hold both the Sleep/Wake button and the Home button for about ten seconds, until the Apple logo appears.
Mar 06, 2011 | Apple iPod touch
My ipod touch is on but it won't go past the screen with the apple logo its like its frozen or something
1: PLUG YOUR IPOD INTO YOUR COMPUTER!!!
2: HOLD THE "HOLD" AND THE "MENU" BUTTON UNTIL THE TOUCH'S SCREEN GOES BLACK AND SHOWS THE APPLE LOGO AGAIN THEN RELEASE THE BUTTONS!!!
3: WAIT ABOUT 5-15 MINUTES!!!
4: YOUR COMPUTER WILL MAKE A "CHIME" SOUND AND THEN THE IPOD WILL SHOW THE LOCKED SCREEN WITH THE BATTERY LOGO.
Let me know, if the problem persists.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 14, 2010 | Apple iPod touch
Ipod touch 32g new - works really slowly when plugged into laptop but freezes when disconnected and shows picture of apple and does nothing
When the Apple Logo is stuck
If this happens, put the iPod into Disk Mode through the diagnostic menu. Then connect the iPod to your computer and update or restore the iPod. Sometimes you can get away with just updating the iPod, so try that first, but usually you have to restore the iPod . As always make backups of your music files, because the restore procedure will eliminate them.
Good Luck,I hope this helps Please rate me, Thanks
Dec 26, 2009 | Apple iPod touch
Ipod touch 32g new - setting it up it works very slowly when connected to laptop - but when disconnected freezes and shows picture of apple ?? set it up wrong? or need to return it?
Try this solution first, if it doesn't work then I would return it. ----------------------------------------------------------------------------- When the Apple Logo is stuck
If this happens, put the iPod into Disk Mode through the diagnostic menu. Then connect the iPod to your computer and update or restore the iPod. Sometimes you can get away with just updating the iPod, so try that first, but usually you have to restore the iPod . As always make backups of your music files,because the restore procedure will eliminate them.
Good Luck, I hope this helps Please rate me, Thanks
My ipod touch wont work
If iPod touch won't turn on, or if the display freezes or doesn't respond
  • iPod touch may need charging. See "Charging the Battery" in the iPod touch Features Guide.
  • Press and hold the Home button for at least six seconds, until the application you were using quits.
  • If that doesn't work, turn off iPod touch and turn it on again. Press and hold the Sleep/Wake button on top of iPod touch for a few seconds until a red slider appears, and then drag the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  • If that doesn't work, reset iPod touch. Press and hold both the Sleep/Wake button and the Home button for at least ten seconds, until the Apple logo appears.
If iPod touch continues to freeze or not respond after you reset it
  • Reset iPod touch settings. From the Home screen choose Settings > General > Reset > Reset All Settings. All your preferences are reset, but your data and media are left untouched.
  • If that doesn't work, erase all content on iPod touch. From the Home screen choose Settings > General > Reset > "Erase All Content and Settings." All your preferences are reset, and all your data and media are removed from iPod touch.
To reset the iPhone or iPod Touch, press and hold down the Sleep/Wake button and the Home button simultaneously at the same time for at least ten seconds, then the LCD display will clear and the Apple logo appears on the black background. When Apple logo appears, reset is done.
Sep 22, 2009 | Apple iPod touch
Apple icon always on new ipod touch and session could not start
if that happened, then yes. then you could just buy a new one. but trust me, that's probably a defective ipod.
Apr 03, 2009 | Apple iPod touch
ITouch screen locked and showing iTunes logo
try to plug the itouch into a charger/computer.
its probably dead.
Feb 25, 2009 | Apple iPod touch
Ipod touch frozen on Itune connection
Per the first Google result for "reset ipod touch", http://www.mydigitallife.info/2007/10/04/how-to-reset-iphone-and-ipod-touch-hard-reset-or-reboot/ says:
"Press and hold down the Sleep/Wake button and the Home button simultaneously at the same time for at least ten seconds, then the LCD display will clear and the Apple logo appears on the black background. When Apple logo appears, reset is done"
Nov 22, 2008 | Apple iPod touch
Apple iPod touch Logo
214 people viewed this question
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
