Question about Pioneer TS-W2000SPL Car Subwoofer
What is the best amp for a ts-w2000spl - Pioneer TS-W2000SPL Car Subwoofer
  • 96 Answers
Pioner amp
Posted on Jun 07, 2010
  • Jamie Henning Nov 08, 2010
    Pioneer GM-D8500M 1200W Mono Amplifier with 1200 Watts Max. Power, I think this would be a good amp.
I have 2 Pioneer TS-W3002D4 12 In and a Hifonics Brutus BRZ1200.1D D-Class Mono Block what's the best wiring
you need to wire each sub down to 2ohms then wire them together like the one in this pic http://m.seimg.net/product/img/subwoofer_wiring/2_subs_DVC_4_ohm_mono_variation2.jpg witch will give you 1ohm so you will be getting every bit of power that amp has but you should get a bigger amp for thos speakers
Mar 24, 2013 | Car Audio & Video
What would be the best amp for the money to push 4 pioneer 6.5 i door spea kers n in my truck? they are pioneer ts-a1674r. 6.5 '..3-way 300W max and 35W nominal.
i would get me a 400 watt pioneer amp that ran the same ohms as my speakers maybe a 500 watt to much power on 6.5 will pop them dont ever goby max power its to much for them
Mar 04, 2013 | Jl Audio 13W7 Car Subwoofer
Pioneer TS-W304R quick connect issues
its pretty normal for the ohms not to read a perfect 4 if the leads are hard to read off of it might be best to replace them it would not be an expensive thing to do and they definetly wouldnt need to be pushed on to read but i would remove speaker & check it & all wiring first
Feb 19, 2013 | Pioneer TS-WX65A Car Speaker
TS-SWX310 work in 2002 Chevrolet Avalanche
Of course it will fit if you make the hole a bit bigger ,get a proper old time fitter he will make it fit these youngsters are all quickness unit fitters ,no idea how to improvise
Mar 17, 2012 | Pioneer TS-SWX310 Car Subwoofer
Should a 1976 ts185 have spark and run even if you have the battery out?
Yes it should have spark, as long as the ignition switch is turned on. You will have to check the coil & magneto circuit if there is no spark.
Best wishes,
Graeme.
Mar 14, 2011 | 1981 Suzuki TS 185
I cannot find the right way to hook my TS-W304C Subwolfers up to a mono channel amp.
what amp? the speaker wiring depends on the ohmage rating of the amp. if the amp is 2 ohm stable, then you can hook 2 TS-W304C's up to it, both positive leads from the speakers attached to the amp positive, and both negative speaker leads connected to amp negative. this is called parallel wiring, and it reduces the ohmage (resistance) down to 2 ohms. your speakers are 4 ohms, and 2x4 ohm speakers in parallel makes it equal 2 ohms. if your amp is only 4 ohm stable, then you will only be able to hook up one of your speakers to it.
Mar 13, 2011 | Pioneer TS-W304C Car Subwoofer
Whats the best kind of amp to use with two of these in a box
Walmart sells a 760 watt 2 ch amp.....It works well with these type of subs. Or any amp rated @ 150 watts per channel RMS. Start with the low pass filter on and with it hooked up and playing raise amp level until distortion can be heard through subs...then back off a bit...Your level is now set.
Sep 17, 2010 | Pioneer TS-W1201C Car Speaker
What kind amp should be use for ts-w307d2 subwoofer speaker?
Nice sub, i have 2 308d4s in my car. Okay this sub is a dual coil 2 ohm. so to get best bang for your buck you'll want a 2 channel amp and bridge it. Your sub is 400 watts RMS, So you'll want an amp that has the same rating. I'd recommend the pioneer GM-5400t. Then wire your voice coils in parallel, and bridge your amp, you'll get 380 watts RMS, which is perfect for this sub. If you have questions on wiring or anything you can just ask. thanks, i hope this helps
Oct 20, 2009 | Pioneer TS-W307D2 12" 1200 Watt Champion...
Wireing diagrams
Hello stingerman20,
Your Directed D2400 amp is CEA2006 Compliant. It is stable at 1ohm and will produce 1,200 watts into that load. So you want your subs wired as close to 1 ohm as possible.
The only 3500 watt Pioneer Premier series subs I could find were the models number TS-W3002D2 and TS-W3002D4 with dual 2ohm and dual 4ohm voice coils respectively. The wiring options for the D2's result in 0.5ohm (too low), 2 ohms, and 8ohms. Your best option would be the 2ohm configuration which would be voice coils in series and subs in parallel. Options for the D4's result in a 1ohm load and a 4ohm load. Your best option would be the 1ohm configuration which would be voice coils and subs parallel.
To see the wiring options, try Rockford-Fosgate's "wiring wizard".
Select 2 woofers and the appropriate voice coil impedance and quantity and click "search". It'll bring up all of the possible wiring configurations along with the final impedance load.
Hope this helps.
May 11, 2009 | Directed 2400d Car Audio Amplifier
Pioneer TS-W2000SPL Car Subwoofer Logo
83 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
