Question about Xerox Phaser 8500/DN Printer
Error code 09,038,46:21303
It displays error code 09,038,46:21303. I have removed the black ink, but the error is still there. Any solutions.
    President:
  • 2,072 Answers
When you service a Phaser 8500 or 8550 printer for:
· a persistent Ink Out message
· 9,035.43 Cyan Ink Stick Count Fault
· 9,036.44 Magenta Ink Stick Count Fault
· 9,037.45 Yellow Ink Stick Count Fault
· 9,038.46 Black Ink Stick Count Fault
Test the Ink Out Sensors for proper operation.
Inspect the Ink Sticks.
Posted on Apr 10, 2008
  • 1 more comment
  • Rick Kasper Apr 10, 2008
    Testing the Ink Out Sensors
    Use this procedure to test if an Ink Out Sensor?s flag works correctly.
    1. Remove ink sticks from the ink loader?s channels.
    2. Place the printer in Diagnostics Mode by:
    Customer method
    a. While error code displayed, press UP arrow and OK key.
    b. Scroll to Troubleshooting: Service Tools: Enter Diagnostic Mode. (Printer restarts).
    c. Select test 82: Monitor Sensors. Press OK.
    d. Scroll to 01: Exit Diagnostics and press OK to return to customer mode.
    3. Insert the clean eraser end of a pencil thru the lowermost oval slot. (The eraser end of a pencil closely simulates the bottom rail shape of a Xerox ink stick.)
    Slide the pencil down the white channel guide until the sensor is tripped. A sensor change is displayed on the control panel. When the flag is depressed, the front panel will read <color> Ink Present H. When released, the reading will change to L. The test will only display a reading when a sensor change occurs. If a flag is stuck, no sensor reading will be displayed on the front panel.
    1. If the sensors are not working properly, follow standard service procedures and replace the ink loader assembly.
    2. If the ink out sensors work correctly, identify the ink stick(s) being used in the printer.
    If Genuine Xerox Phaser 8500/8550 Ink Sticks are being used, check for defects in the ink sticks and replace. If no defects are found, replace the ink loader assembly.
    · If Phaser 8400 Ink Sticks are being used, they will not properly actuate the ink loader sensors. Do not use Phaser 8400 ink sticks in a Phaser 8500 or 8550 printer.
    · If non-Xerox ink is being used, the shapes of these sticks are different than genuine Xerox Phaser 8500/8550 ink and may not properly actuate the ink loader sensor(s). Remove all non-Xerox ink and re-load with genuine Xerox Phaser 8500/8550 ink and check sensor operation. If proper function returns to the printer, the false error message was caused by the use of non-Xerox ink. If the false error message continues, replace the ink loader assembly.
    Note: Xerox is not financially responsible for the incorrect operation of its products caused by the use of non-Xerox ink.
2 Suggested Answers
  • 7 Answers
SOURCE: System Error code 09 038 46 24363
09,03x
35 = Cyan
36 = Magenta
37 = Yellow
38 = Black
The error indicates an ink stick was jammed. You have to clear the ISC (ink stick count) error.
Turn off the printer.
Turn on the printer.
As soon as you see XEROX start moving across the display hold down the back and help buttons until you see "beginning service mode" on the display.
Release the buttons, it will now come up in the service mode.
Scroll down to the function menu, hit ok, scoll to clear isc faault, hit ok.
Hit the back button to get back to the first menu then exit diagnostics, hit ok when it asks if you want to restart in customer mode.
Posted on Jun 10, 2009
I have a HP C5180, receiving error message 0xc18a0206 Ink System Has Failed. I have replaced all cartridges, unplugged power supply and USB cable for reset and am still receiving error message. Help! ...
Issue An 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Mar 09, 2011 | HP Photosmart C5180 All-In-One InkJet...
Correct loading of ink cartridges. Error E2
When a printer error occurs, the Alarm lamp is lit orange. The number displayed on the LED indicates the type of error that has occurred. Check the error code displayed on the LED and take the appropriate action to correct the error.
E and number (error code) are alternately displayed on the LED of MP210 series.
Error E, 2:
Cause: The machine is out of paper. / Paper does not feed.
Solution: Reload the paper correctly and press the Black or Color button.
This sounds like to simple a solution. Make sure this is the correct error code and it is not followed by another number. If problem persists check that you have removed the protecftive material from the FINE cartridge holder. Unplug the machine from the power source for several minutes. Power up. Hopefully this corrects the problem.
If not, try checking the status of your ink cartridges:
1 Open the printer properties dialog box from Control Panel.
2 Click View Printer Status on the Maintenance sheet.
To confirm the FINE Cartridge information, click the Ink Details menu.
This my give further clues to any problem.
Trust this is helpful. :)
Dec 08, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
Ink system failed
Jan 27, 2010 | HP Photosmart C5180 All-In-One InkJet...
Xerox error code 09,038.46:350??
Hi. The error code you are referencing is referring to Black Ink Stick Count Failure.
  1. Make sure you are using Phaser 8500 ink sticks
  2. Make sure the ink sticks slide properly
  3. Remove any broken or partial ink sticks from the ink-loading bin
If the fault code is still displayed you will need to contact support to schedule a service call.
Please check out the online support at www.xerox.com\support
Oct 24, 2009 | Xerox Phaser 8500/DN Printer
Ink System Failure HP C5180
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Wait two minutes.
Jan 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
Ink system failure
Solution
Wait two minutes.
Dec 03, 2008 | HP Photosmart 8250 InkJet Printer
Ink system failed. unable to print. error: oxc18a0201
Wait two minutes.
Thanks
Aug 01, 2008 | Office Equipment & Supplies
Error message #Oxc19a0013----Ink system has failed
Solution
Wait two minutes.
Jul 19, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart d7368
Solution
Wait two minutes.
Jul 16, 2008 | HP Photosmart 3210 Printer
Ink system failure
If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer. Please let me know if the issue is not resolve so that i can check for a possible solution for that. Thank you so much. adonscott
Jul 01, 2008 | HP Photosmart C5180 All-In-One InkJet...
Xerox Phaser  8500/DN Printer Logo
2,522 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
