How to connect my realistic 7 bands equalizer to my amps .
  • 17,130 Answers
Since you have not mentioned the amplifier I am not aware if the amp does have an preamp input and output. In case you have these then the output of the preamp of the main amp must be connected to the input of the equaliser and the output of the equaliser must go to the input of the main amplifier. The sources can be connected to the amplifer according to the selected device.If your amp does not have the preamp input/output then connect the source to the input of the equaliser and the output of the equaliser to the aux of the main amplifier.Now set your amp's bass and treble to mid point and set yout equaliser accordingly. Hope this helps. Good day
Posted on Jul 21, 2010
How to hook up a pioneer 7 band gr 470 equalizer to a Kenwood kr-v6030 receiver
Connect one pair of RCA cables between the receiver and equalizer. Connect one pair of cables to the pre-amp output channels on the receiver and the other end of the cable to the left and right channel inputs on the equalizer. You will usually find these channels on the rear of the equalizer.
May 09, 2016 | Pioneer Audio Players & Recorders
How to hook up a 7 band pioneer equalizer great 470 to a Kenwood kr-v6030 receiver
Connecting an Equalizer to a Receiver Before beginning, purchase RCA cables. In order to run the signal from a stereo receiver to the graphic equalizer and then on to the amplifier, two sets of RCA cables are needed. These are basic cables used to connect auxiliary components like record players and CD players. The length of the RCA cables should be about the same length as the distance between the receiver and equalizer.
1. Connect Graphic the Equalizer to the Receiver
The first step in this setup is to connect the graphic equalizer (EQ) to the receiver. Most receivers will have preamp-in and preamp-out connections. Some have tape monitor connections. It's preferable to connect the EQ to the preamp-in or preamp-out because the tape monitor won't allow for connection to the amplifier as well.
2. Connect the RCA Cables
The first set of RCA cables should connect the receiver and equalizer. Connect one pair to the preamp output channels and the other end to the left and right input channels on the EQ. These are on the back side of the equalizer. Usually, the colors will correspond to the RCA plugs. That means connect the red plug to the red jack and the white plug to the white jack. Then connect the second pair of RCA cables between the receiver and the amp. Match the colors in the same way.
3. Connect the Amp to the Receiver
Now the amp can be connected to the receiver via RCA cables in the amp inputs on the receiver. This will create a loop from the receiver through the EQ and amp and back to the receiver so that all three units are connected.
4. Test Graphic Equalizer
Turn on the receiver, amp and equalizer. Once they are powered up, try controlling the sound with the equalizer knobs. They should fine tune the music according to your preferences. It's easy to change the frequency response or tone of the music with the equalizer knobs.
Hi i just got a ava1202 boss eq it didnt have instructions this eq has rca inputs and high level speaker inputs can i use this eq with out an amp can smeone plz help me thnk u
Yes you can use the equalizer without an amplifier. That is what the high level speaker inputs are for. You simply take the positive and negative from a speaker and hook it up to the positive and negative high level speaker inputs on the equalizer.
Jun 04, 2011 | Boss AVA-1404 7-Band Car Equalizer
How do I connect a Realistic Home Equalizer to a Stereo Home Receiver?
record out to -----------equalizer in-------------equalizer out-----------------to tape in
Sep 13, 2009 | Audio Players & Recorders
Realistic 31-2010 - Need manual
equalizer easy to connect and operate-------.
line out from mixer to equalizer in------equalizer out to amplifier in.
make all control to middle position and adjust the tone of music very slowly and until you find the fine music for you.
Mar 21, 2009 | Audio Players & Recorders
Optimus 7 band equalizer model # 12-1969
I need to know what the wire are coming out the back of the optimus seven band stereo frequency equalizer/booster
Jul 07, 2008 | Car Audio & Video
296 people viewed this question
 Grubhead
Grubhead
