Question about 2wire (2701HG-B) Wireless Router
No wifi wifi appears on the signals but it says unable to join 2wire467
    Guru:
  • 868 Answers
Check your 2wire router if the mac address filterins is turned on and if it is your either get your computers mac address and input in the 2wire router settigns or remove the 2wire router mac address filtering option...
^_^
Posted on Jun 05, 2010
No wifi on my tv
If everything else is working then it must be the WIFI module on the tv. Now you should be able to use a USB device to update the firmware on the tv if yu have already done so just to see if that works
Jul 04, 2016 | Samsung 55" Class 1080p 120Hz Slim LED...
IPhone 4s is unable to scan/connect/join wifi network. Please help?
Hey there could you be more specific, are you saying thst it won't connect to any wifi network or just already saved ones?
Dec 19, 2013 | Cell Phones
I phone 5
What Type/Brand of router ?????
Apple's iPhone is a multimedia connectivity tool.
As such, the iPhone employs a sophisticated system to keep you connected to the web via WiFi signals so that you can stay up to date with email, mapping and media.
To use the iPhone's WiFi feature just follow these steps.
Tap a network.
If you have not yet used your iPhone's WiFi or if you're in a new WiFi area, the iPhone will show you a list of available networks.
Tap the network that you want to connect to in order to connect.
If there is a password required a little lock icon appears.
Enter the password to connect to locked networks and continue to surf the web.
Monitor your signal.
As you use your iPhone, especially if you're moving around, you should take a look at the signal strength of the connection.
The strength is indicated by a small, black broadcast symbol that stacks arches, or rounded bars, on top of one another.
The more bars there are the better the signal.
Make connecting to WiFi automatic or manual.
The iPhone is equipped to automatically search for available networks and connect you to one.
If you do not want the phone to search for networks, select the "WiFi" option on the phone's menu.
Then select either the on or off option of the "Ask To Join Networks."
Turning this option off requires that you find networks manually.
Forget a network.
Once you connect to a WiFi network once the iPhone automatically remembers the network and connects you to it at a later opportunity.
To forget a network so you don't get automatically connected choose the "WiFi" option on the menu.
Then tap the right arrow button next to one of the networks that the iPhone already remembers. Then tap "Forget This Network" to erase the phone's memory of the network.
Troubleshoot Wi-Fi Connection Problems on an iPhone
If you experience Wi-Fi connectivity issues on your iPhone, you may need to reset the Wi-Fi connection.
Your connectivity issues could be caused by the wrong password if you are having trouble logging into the Wi-Fi network or from a problem in your iPhone's settings.
By resetting the Wi-Fi connection, you are clearing out the previous settings created when you first connected to the network.
Tap the Settings icon on the iPhone's home screen, and tap the Wi-Fi tab.
Swipe the switch on the Wi-Fi tab to ensure Wi-Fi is enabled on your iPhone.
Tap the blue arrow button on the network tab you are connected to in the network list, and tap "Forget this Network."
Tap the "Forget Network" button that appears on the pop-up menu to confirm the action.
Tap the Wi-Fi Networks tab in the upper-left corner to return to the previous screen, and tap the network's tab in the network list to re-join it.
Press the Home button on the iPhone, and tap the Safari icon on the home screen to test the Wi-Fi connection.
Tap the blue arrow icon on the network's tab if the connectivity problem persists, and tap the "Renew Lease" button at the bottom of the network's window.
Tap the "Renew Lease" button on the pop-up box to confirm the action.
Tap the Home button on the iPhone, and tap the Safari icon on the home screen to test the network connection.
Nov 11, 2013 | Computers & Internet
My iphones and tablet are unable to join on my belkin wi fi why
Go ahead and do some investigating. Does connecting via wired LAN brings any results? Could it be that you're having 2.4GHz interference? Try switching your WiFi channel or moving your router away from large metal objects. If that doesn't work try connecting to your wireless network holding a device close to the antenna, inches away. Does this work? If so, your antenna or WiFi signal amplifier circuit could be dead. You can open your router up and do some further investigating with a multimeter, but if you suspect a hardware failure, it's probably best to not bother opening it up and checking up on your warranty options. Even if that doesn't work out, it's not like routers are super expensive these days.
Feb 22, 2013 | Belkin Surf N300 Wireless N Router
I have tried to set my playstation 3 online keeps asking for wep key what is this and were do i find it
Your PS3 is most likely trying to join a WiFi (Wireless) network. Sometimes WiFi networks have passwords to keep people out. The PS3 is asking for a WEP key because it is asking for the password so it can join that WiFi network and get online. Try to find your WEP key for your router. If it is not your router then you will be unable to join that network since it is secured.
Jun 18, 2011 | Sony Playstation 3 (PS3) Console
Have connected my tablet to the wifi but unable to connect to the internet, please can u help
1. go to settings of your Tablet
2. click on Wifi
3.loo for the ON button
4 it will search nearby wireless networks around your place5
5. if you have a wireless router in your place then select by clicking it and press on Join button
6.it will ask you a network key....
enter networkkey (password access)
7. if have finnished, it will appear beside Wifi - the name of the network you picked.
enjoy wireless network...
PS: incase of trouble try resatrting your tablet and the wireless router network if you have.
Shutting down or rebbooting IPad, press and hold the small button switch on top of the ipad by 3-5 seconds
then theresa red arrow appearing and follow to where it want you to slide....
wait few minutes when it shutting down and it will be on sooner.... goodluck
Jan 17, 2011 | Computers & Internet
Trying to connect my iPhone 4 to my WGT624 v3 router. My iPhone is detecting the network, but i'm getting the message "unable to join the network" .
Hi chaps,
I did two things to resolve this issue
1. Downgrade the router to a lower version.If your router is Netgear WGT624 v3 use this link to downgrade your router
http://www.davejackson.com/life/cant-access-wifi-with-ios-6-on-iphone-with-netge ar-wgt624v3-fix/
(this help to avoid getting a errro message "Unable to join network")
2. Reconfigure you Wifi network by going to setting ---->under choose a network---> others-----> Enter your SSID name (seen at the back of your router) ----->under the security tab selet the same encyrption standard as that of your router which you can see when you log in to the router (usually router IP 192.168.1.1) ---->setup ------>wireless setting----> security option. This one helps you to join your home wifi as soon as you enter your home.
Dec 29, 2010 | NetGear WGT624 Wireless Router
Ipod touch won't connect to my wifi
things to check again:
1- if DHCP enabled 2- which type of security encryption is used, if WEP change to WPA, use numbers instead of mixed characters for wifi password 3- if MAC filtering is on on the router 4- if signal strength is good
hope that any one of the above solves your problem
Mar 06, 2010 | D-Link Xtreme N DIR-655 Wireless Router
I try to join my network no lock nothing it will have full bars perfect signal and yet it says 'Unable to join the network ''linksys''. word for word
Your WiFi router may be configured to not allow your iPod Touch to connect to it. This is done by specifying a list of "MAC addresses" that can connect to the router.
Feb 08, 2010 | Apple iPod touch
2wire (2701HG-B) Wireless Router Logo
236 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
