Question about Samsung HCN653W 65" Rear Projection Television
WHILE watching tv my set just turned off on its own. when i try to turn it on the only thing that happens is that the timmer light comes on and stays on.
  • prpapa068 Jun 06, 2010
    no nothing happens except the timmer light stays on but when you try to turn it on you can here the sound of it trying to come on.
  • 10,594 Answers
OK, Let me know do you have some experience of tv repair?
What is model number of your tv to provide you helpful info.
Thanks.
Posted on Jun 05, 2010
  • 1 more comment
    my model # is hcn653w i dont have any expiriecce on tvs but i am very handy if you can send me a picture and tell me what to do ,i can do it. thank you..
  • Shahid Electronics
    Shahid Electronics Jun 06, 2010
    Samsung hcn653w is rear projection tv that has 3 picture tubes inside to present color picture on its front screen.
    Do you get sound from tv, if it does not show picture?
    OK, that means tv goes to protection mode to avoid further damage due to some internal problem.
    There are two possibilities for that problem, horizontal deflection section got problem like HV block shorted out, or flyback transformer and horizontal output transistor are defective etc and other reason could be convergence output chips got shorted and causing problem.
    Visual check is needed by tech person because rear projection tv has many circuit boards to be tested to fix the problem.
Magnavox 37MF23ID, would not turn on. Power button only blinks (green light). We have switched power cords and nothing happens. No picture, no sound.
if the power light comes on but the screen stays black, then your TV might be on the wrong input Channel. for example: you switch inputs when you play games or watch dvds vs. watching regular tv. Try to change the input
Dec 27, 2014 | Magnavox Televison & Video
MY ILIVE SOUND BAR KEEPS TURNING OFF WHEN WATCHING TV
I'm having the same problem. I don't think it has anything to do with the Sleep settings, you can play with them all day & the only benefit you may get is forcing it to stay on for 90 min or whatever instead of 15.
(I've tried setting to 00, obviously the first thing that comes to mind is that it's a Sleep Setting issue, but I seriously doubt this. You can't even set the Sleep Setting to 15min anyway)
Instead, I'm pretty sure that the problem exists in the sound bar not recognizing that there is an active signal & is shutting off due to what it sees as inactivity (timing out after use). I've come to this conclusion due to multiple complaints of the same problem.
Some people are reporting that it's not happening when they watch movies, others have tested & said the radio stays on as long as you like, a couple people have posted that theirs works fine & only shuts off when they turn off about 15 minutes after they shut off the audio source, which leads me to think that this is what is going on, the system thinks the audio source (TV, Bluray, etc) is off & no sound is coming through. It must have a funny way of detecting it...
I will try a few tests & if anything works I will pay the results. One person claimed there's stayed on after turning their TV all the way up... I could try this but will have to turn TV speakers off (currently I am running both TV speakers & sound bar). Anyway, I'll keep digging, must be some way to get this to work, I hope...
Jan 20, 2013 | iLive ITP582B Soundbar iPhone Dock
The tv made poping sound & it lost the picture but the sound was ok, their is buzzing sound coming from inside the tv, after about a min. the set turn off & red light stays on. reset tv, same...
This model is prone to a lot of problems to the point where a year or so ago they offered a chassis replacement on an exchange basis.
I would with rear cover removed try to localize first where the sound or buzz is coming from: The ballast? the Light engine? The power supply?
I can help but as I said this model has a LOT of chronic problems.
Steve
Nov 01, 2011 | Mitsubishi WD-52525 52" Rear Projection...
Timmer switch turns on but pump does not start. I have to go out and turn off timmer swith for a few seconds and turn timmer back on and pump usually starts auto matically. Some times when timmer switch...
The flashing re light is trying to tell you what is wrong! It will flash 2 to 9 times and you need to count the flashes and then refer to the troubleshooting chart on page 27 of your owners manual.
To me it sounds like your pump loses it prime some I would suspect a leak on the suction side of the system.
http://www.inyopools.com/manuals/210/IntelliFlow4x160_OM.pdf
Jul 20, 2011 | Pentair 4-Speed 230v IntelliFlo 4x160...
My mitsubishi tv wont come on and green timmer light blinks fast
Try the blinking light repair kit from http://www.tvrepairkits.com/xcart/home.php?cat=2658 . This kit has fuses and capacitors that are designed for your TV.
I hope this helps.
Apr 24, 2010 | Televison & Video
While watching tv it just turned off, we turned it back on but no pictures but there is volume. also to turn it back on we see red light and green light together flashing then it turns off. i just replaced...
MY TV TURNS OFF AFTER WE TURN IT ON IT GOES BACK OFF A FEW TIMES AND THEN STAYS ON. AND WHEN I COME HOME FROM WORK IT STARTS ALL OVER AGAIN, THAT HAPPENED FOR 2 WKS NOW IT JUST GOES OFF YOU ONLY SEE THE GREEN LIGHT ON THE FRONT COME ON(POWER LIGHT) AND IT GOES RIGHT BACK OFF IT WILL NOT STAY ON
Sep 18, 2009 | Toshiba Televison & Video
Tv clicks on and off. timmer light stays lite.
This could be a number of things, but first step might be: check that the power button on the TV is not stuck on, there could be a faulty push button or the button is stuck.
Aug 19, 2009 | Samsung HCL4715W 47" Rear Projection...
My light will come on if I manually turn them on,
timer is sticking
you try working for 6 years strait without a holiday
take timmer to the garage and beat it to death with a hammer then go buy a new 1 from crappy tire or wallmart for 20.00 and have a great day :)
Jul 31, 2009 | Hardware & Accessories
TV wont turn on, makes buzzing noise and shuts off
I have two RCA HD52W59 TV's. I have had one for 3 years and one 4 years. The one I have had for 4 years is giving me the problem. Last week the tv turned off while watching it. It wouldnt come right back on. 10 minutes later we tried and it worked fine. the other night the kids were watching and it turned off and smelled like something burning. I tried turning it right back on and got no power at all. I tried to turn it on two days later and it made a buzzing noise and the green light went out. Never did get a picture, no powering up on the screen. Any ideas? Don't want to spend alot of money. Really loved the TV hope it isnt junk now. Better yet I hope the same thing doesnt happen to the other one I have.
Jan 22, 2009 | RCA HD52W59 HDTV Projection Television
No turn on
try unpluging convergence yoke and try turning on the set if still try looking at green lights and let me know wichone stays on ..
Feb 25, 2008 | Hitachi 43FDX01B TV
Samsung HCN653W 65" Rear Projection Television Logo
80 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
