Question about Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine
Hoshizaki KM-500MAH is making sliver/chip ice. I
Hoshizaki KM-500MAH is making sliver/chip ice. I just took it apart Memorial Day weekend and cleaned it with "Scale-Away" like I have done many times since we purchased it 5 years ago. This is the first time I have had the sliver ice problem. Directions?
Different problem: I replaced the bin control sensor last year as the ice would pile up above the original sensor and was told this would fix the problem; it didn't. Ice still piles up past the sensor. Suggestions?
  • Dennis Boxerman Jun 05, 2010
    If the ice piles up past the sensor, what shuts off the machine? When you say sensor, are you talking about the bin t'stat? Let me know and we can go from there.
  • 146 Answers
Just to let you know you need to use nickel safe ice machine cleaner. and i hate to tell you this but if you are seeing silver chips in your ice your evaporator is shot. even if it is under warranty they will not give a new plate just for the reason of not using nickel safe cleaner. hope this helps you. i have seen this many times as im a service tech. alot of restaurant owners use coffee cleaner and also destroy their plates
Posted on Jun 05, 2010
Hoshizaki ice machine model km 900mwh low side suction line has ice building up on it all the way to the compressor
Is it making ice? Frost on this line is not that uncommon as it is colder than the air around it. Make sure you have good water flow over the evap plates. machine may just need a good chemical cleaning.
Jun 14, 2014 | Hoshizaki Commercial Freezer KM-500MAH
I need UL and NSF certification proof for Hoshizaki KM-900 MAF Ice maker. Can please provide?
http://www.hoshizakiamerica.com/manuals/KM-900M_F_inst.pdf
This is the manual for your machine. Check out the pages that have examples of the nameplate information. It shows that the machine is approved for UL and NSF. Otherwise, I would suggest contacting Hoshizaki directly.
Dec 30, 2010 | Hoshizaki Commercial Freezer KM-500MAH
KM-500-MAE Hoshizaki Problem huge cubes, alarm code three beeps
Might need to clean float switch, or water inlet valve bypassing water. Deep clean Hoshizaki.
Sep 30, 2010 | Hoshizaki Commercial Freezer KM-500MAH
I have got Hoshizaki Ice Machine which makes three beep sound every 2 second continuously. I turned off the machine. It looks it needs to be cleaned. Can anyone help me to resolve this problem so that it...
I am assuming that it has run two consecutive cycles. I would first clean the machine inside and out. it should drop ice once cleaned, if not then open up the control box and find out which lights are flashing. I am almost certain that once it is cleaned it will drop ice.
Jul 21, 2010 | Hoshizaki Commercial Freezer KM-500MAH
KM-500MAH won't go into harvest mode
The float switch controls the harvest cycle.
Apr 22, 2009 | Hoshizaki Commercial Freezer KM-500MAH
Water leaking onto ice and outside panel on Hoshizaki KM-500MAE
Remove the cover where the persons finger is and check to make sure that it is not covered with ice. Sounds like your machine iced oup and you will need to clean the coils and possibly replace the thermostat
Feb 12, 2009 | Hoshizaki Commercial Freezer KM-500MAH
Hoshizaki ice machine with constant beeping every 2 seconds
turn it off and on and check the drain line and see if its draining water. some times the check valve needs taken apart and cleaned. the problems corespond to water related problems. usually because its taking too long to freeze. good luck
Dec 27, 2008 | Hoshizaki Commercial Freezer KM-500MAH
Hoshizaki KM-500MAH not making ice
Look at water solenoid valve when the unit is running in ice mode. Check to see if the water is shuting off completely. If the water valve does not close properly it will keep adding a little bit warm water to the ice a slow down the ice production.
Sep 21, 2007 | Hoshizaki Commercial Freezer KM-500MAH
Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine Logo
487 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
