Question about Refrigerators
The freezer is working, compressor is on, fan is working but no cold air to the fresh food compartment.
  • Refrigerators Master
  • 43,501 Answers
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
RefrigeratorThe freezer is working, compressor is on, fan is - 2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on Jun 05, 2010
Hotpoint (GE)CTX18GJB not cold enough. Just had serviced - tech replaced defrost timer and defrost terminator. The top located freezer gets cold and can hear the fan running - but still not cold enough...
I agree with the tech. if the refriderator isn't frosting it isn't working,their is only 1fan and its in the freezer,The tech could have missed some frost build up that is blocking the air flow into the fresh food section,if he removed all the frost it could take up to 24 hours to get cold ,it should slowly geta bit colder throughout the day,if by tomorrow its still not working have the tech come back and check for frost build up on the vents for air flow into fresh food compartment.
To reiderate their is two types of refrigerators,one that you have to manually defrost and a automatic defrost type where the defrost system which is comprised of the defrost heater,timer&termination t-stat will automatically melt the frost
Jul 28, 2011 | Refrigerators
Westinghouse RJ532, 530 Litre, Frost Free Fridge/Freezer keeps stopping - if we move the little red dial in the fridge under the air temperature control it starts up again, goes for awhile and then stops....
If the refrigerator was tipped on back or side, even part way, it has to wit upright at least overnight, because of the freon flowing upward.
If you just moved in and it has been sitting and unplugged, then it may be low on freon.
Here are some tips
If you open the fresh food compartment of your fridge (the non-freezer compartment), you will most likely see two different controls. One refers to the refrigerator temperature and the other refers to the freezer. Different manufacturers use different wording, but the idea is the same.
The first thing you need to know in order to understand what these controls really do is that all the cold air in the entire refrigerator is made in the freezer compartment. A portion of that cold air is then blown into the fresh food compartment. How much cold air gets blown in is controlled by the "freezer" control, which is really just an air baffle that opens or closed to let more or less air into the fresh food compartment. The "refrigerator" control is actually a thermostat that feels the temperature inside the fresh food compartment and turns the compressor on and off according to the temperature that the thermostat feels.
Let’s run through an example. Suppose you decide that your ice cream isn’t hard enough. You adjust the "freezer" control to make your freezer colder. What you’re actually doing is restricting the amount of cold air that gets blown from the freezer into the fresh food compartment and so keeping more of the cold air in the freezer. As a result, the freezer will get colder but also the fresh food compartment will tend to get warmer because its cold air supply has been diminished. The "refrigerator" control (the thermostat) will feel this increase in temperature inside the fresh food compartment and will keep the compressor running longer in order to maintain the temperature setting on the "refrigerator" control. So, you can see that any change you make to one control will affect the other.
Many people then wonder, "Well, how do I know what the correct setting on the controls should be?" Since the temperature inside a refrigerator will vary according to lots of external factors such as frequency and duration of door openings, it is impossible to say where your controls should be set all the time in order to maintain a desired temperature in the freezer and fresh food compartments without knowing the actual temperature inside both compartments. For this reason, you should place two thermometers in your refrigerator: one in the fresh food compartment (the big one) and the other in your freezer. The controls should then be adjusted to achieve -10 to +10ºF in the freezer and between 36 and 38ºF in the fresh food compartment.
Keep in mind, too, that it takes 24 hours for any change in the controls to work through the system and reach steady state so don’t look for instantaneous changes in temperature when you make control setting changes. Knowing the actual temperature inside your refrigerator compartments is also a great way to save money on your power bill since you can adjust the controls to avoid running your compressor longer than needed to keep your food cold.
Mar 16, 2008 | Refrigerators
Wont let cold air blow into the refridgetor side
If it isn't due to the fridge contents obstructing the cold air outlet in the fresh food compartment, it's probably an issue with the thermostat in the fresh food compartment or the fan(s) in the freezer compartment.
It may also be the first indication of a failed part in the defrost circuit. If the freezer compartment begins to warm over the next day or so, there may be an issue with the defrost timer, defrost terminator, or heater. Before digging around there tho, make sure the cold air openings in the fresh food compartment are not blocked.
If the fan(s) in the freezer have failed, they won't be able to blow the cold air into the fresh food area. If the thermostat failed, it will never be able to send power to the fan to cool the fresh food compartment.
Depending on your capabilities, this may or may not be a good DIY type job. Sometimes, a warm fridge / freezer is due to a refrigerant leak, and will require a licensed refrigerant tech to make repairs. Working in the tight confines of a fridge can be difficult - especially when testing components with power on.
I hope this helps - good luck!
Oct 21, 2010 | Refrigerators
MY FREEZER WORKS BUT NOT MY FRIDGE WHAT CAN i DO?
Good day,
There was a time when most Kenmore refrigerators were produced by whirlpool, but no more. A model number would help. So the answers are generic.
1. The defrost system failed. Tell-tail signs included frost building up on rear panel of freezer comportment. The system is made up of three parts, and is the most common cause for your problem.
Look here for an idea on how the system functions..
http://www.appliance411.com/faq/howdefrostworks.shtml
2. The fan motor in the freezer compartment failed, not discharging cold air to the fridge compartment. You should be able to hear the fan running, when you open the freezer door.
3. Lights not going out when the fresh food compartment door is closed.
4. On some versions, if the freezer control is set too old, it will deny the fresh food compartment enough air to cool.
5. On other styles the control for the fresh food compartment is pneumatic (opens and closes to allow more or less air in as needed). This control can fail shut, not allowing any cold air to enter the fresh food compartment.
Nov 28, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
The refrigerator is not cooling, but the freezer
it may be a bad timer(timer can be anywhere,inside or out by compressor or behind toe kick it has 5-6 wires and a 1/4 inch hole with a flat screw head in it. use flat screw driver,turn it until it clicks...it will turn one way only...that should put in defrost and in 30 minutes or less the timer should turn compressor back on if not replace timer...when it is in defrost se if element works if not ...check element with meter...also termination switch...open above 32degreeFclose under 32
Aug 29, 2009 | Refrigerators
My side by side freezer is working fridge wont get cold,compressor is working.
There is a panel, or door if you will, that separates the freezer and fresh food compartments. The freezer temp control determines how much cold air is allowed to escape into the fresh food compartment by opening or closing this panel.
If the panel is restricted from moving (stuck closed, for example), the freezer will get VERY cold while the fresh food compartment will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is restricting air flow from the freezer to the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require a service technician to check and repair these components.
Hope this was helpful. Good Luck.
Aug 29, 2009 | Frigidaire FRS26R4A Side by Side...
Freezer extremly cold, some frost on items. The fridge is also too cold, freezing food in the bottom crisper bin. Kenmore Elite side by side model # 5320902. We have the temperatures set higher to...
The compressor is cycled on/off by the fresh food temperature setting. The freezer setting controls a panel, or door if you will, that allows cold air to be blown into the freezer.
Since both compartments are getting too cold, the most likely culprit is the fresh food thermostat control, since it controls the compressor cycle. Try setting it to a higher setting, even if it's above normal. Use a manual thermometer to check the temperature of the fresh food compartment and compare it to the control setting. The readings should be the same or very nearly the same.
I assume your refrigerator is controlled by a solid state controller (i.e. a printed circuit board). Some of these allow for calibration of the thermostat to coincide with the actual temperature of the fresh food compartment. That would most likely have to be done by a service technician unless you have expertise in the field.
If calibration is not an option, if you can live with the thermostat setting not reflecting the actual temperature, a free fix is to simply set it higher than you actually want it to be, recognizing that the actual temperature is 'X' degrees lower than the thermostat setting.
The freezer compartment temperature will be similarly affected, and can be controlled by the freezer temp setting, which is actually nothing more than setting the position of the panel which allows or restricts air from being blown into the fresh food compartment from the freezer. Again, the compressor is cycled on and off by the thermostat in the FRESH FOOD compartment which gets its cold air from the freezer compartment.
Working fridge, warm freezer.
The fresh food compartment is cooled by air being blown from the freezer compartment into the fresh food compartment.
In your case, the door must be stuck all the way open, allowing all the cold air to be diverted into the fresh food compartment. The compressor cycle is controlled by the thermostat in the fresh food compartment and thus 'short cycles' because the fresh food compartment acheives normal temperature while the freezer is relativel warm.
If the panel is restricted from moving (stuck in the extreme open position, for example), the fresh food compartment will get VERY cold while the freezer will be warm.
Try thoroughly defrosting the refrigerator. Possibly an accumulation of ice is preventing the panel from moving and/or is diverting all the cold air from the freezer into the fresh food compartment. It's a free fix and may solve your problem altogether.
If that doesn't help, or helps only temporarily, you may have a problem with panel/door/flap itself or the linkage that connects it to the control mechanism. Unless you're skilled in appliance repair, checking and repairing these components will require the help of a service technician
Aug 28, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Left door open while cleaning out refrigerator and top unit shut off freezer is still on what should I do
Aug 27, 2009 | Sub-Zero 650 / O Bottom Freezer...
My freezer works but the refrigerator doesn't. It
The fan that blows cold air from the freezer to the fresh food compartment is probably the culprit. There is also a mechanical 'door' that is controlled by the fresh food temperature dial that may be stuck closed or the linkage broken. The way it works is: The wider the door is open, the more cold air (from the freezer) is allowed to blow into fresh food compartment.
Turn both temperature dials all the way up and open the freezer compartment. Do you hear a fan running? If not, the fan is most likely bad. If you do hear the fan, there's probably a problem with the door or the linkage that connects it to the control dial.
Hope this helps.
Jun 10, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
101 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
