MY ricoh Aficio 3224c Keeps flashing no toner for the cyan and it wont print. I had just replaced the black and cyan toner and its still saying to add toner.
  • yan dikshteyn Jun 05, 2010
    need a definite solution
    ok thanks so much
  • 4,737 Answers
First try the "chipping" method. If you have any old cartridge, take the chips from them and replace it on the new cartridge. In most cases, swapping the chip is perfect. If you are till having the same problem even after this, please let me know. Good luck. Thanks for using FixYa.
Posted on Jun 05, 2010
    ok if i swap the chips on the cartridge and the cyan works because the cyan cartridge is brans new, does that mean i have to replace the cyan circuit or sensor which detects the toner bottle??
  • Lebanon Raingam
    Lebanon Raingam Jun 05, 2010
    There is nothing like that, we can use the chip on any one of the cartridges, whether cyan, magenta or yellow, you can swap anytime. This is the problem caused by the contact point. If you want specific answer, I would suggest you to get it repaired from the service center. Here, we have to only supply quick solutions because we cannot physically attend your machine. I hope you understand. I am sorry that I had not given you the specific answer to fix it. I have not more tips from my side.
    Good luck.
  • 2,272 Answers
Seems that the sensors are not recognizing the toner cartridges.Remove the cartridges and clean the metal contacts in the cartridge with with cotton/alcohol.Also where the cartridges are installed in the printer there are some sensors clean that and check out.If still the same problem of cyan cartridge missing then the internal sensor of the printer which detects the cyan circuit needs to be replaced. Thanks.
Solid black image on Ricoh 3235C
Check exposer lamp to see if it comes on first. try printing counter report if same problem. Then could be drum unit or not getting a charge to roller on drum. then board could be bad.
Jan 26, 2014 | Ricoh Aficio Type R1 3228c / 3235c / 3245c...
My ricoh aficio 3228c will not print in color
check your printer preference setting in computer driver you will see default set to black and white. select doc then select printer goto printer preference and select color
Feb 21, 2013 | Ricoh Aficio Type R1 3228c / 3235c / 3245c...
How do I learn how to use the scanner on the gestetner dsc424
You can download the manual from their site:
http://www.gestetnerusa.biz/manuals/gestetner/gestetner_comV4.nsf/DownloadManualPaged5d7.html
Oct 29, 2012 | Ricoh 888482 Cyan Toner For The Aficio...
Ricoh aficio Aficio 3224C used toner bottle -1 is full
On a 3224, the used toner bottle is easily replaceable. To get to it, open the front cover of the copier. In the lower left corner, you will see a white or light gray plastic container which slides straight out -- that is the used toner bottle. You can replace it (if you have a new one) by taking the old one out, putting the black plug in the hole to prevent toner from spilling, throwing it away, and inserting the new bottle. If you don't have a new used toner bottle, you can empty this one out into a large bag or trash can and then reinstall it.
Mar 18, 2011 | Ricoh Aficio CL3500N Laser Printer
Aficio CL1000N Printer: On my Ricoh aficio CL1000N it says add toner Cyan....
If I remember right, the CL1000 won't print if any of the 4 colors are out. You have to replace the cyan toner in order to print, even in black and white.
If you haven't tried already, you can try taking the cyan toner out and shaking it up (just a little bit) to try to get the printer to find the little bit of toner left in the bottle.
May 16, 2010 | Ricoh Aficio CL1000N Printer
Ricoh Aficio CL7300 DT2 Laser Printer Cyan color issues
developer unit not set properly.
push the unit in tight
Mar 16, 2009 | Ricoh Aficio CL7300 DT2 Laser Printer
SC 366 on CL4000DN
cyan problem --check if cyan pcu is set properly or replace cuan pcu(drum)
Feb 05, 2009 | Ricoh CL4000DN Laser Printer
Toner problem
R u using gen OEM toners?
Dec 28, 2007 | Ricoh Aficio AP3800C Laser Printer
85 people viewed this question
k24674
jasbo
jasbo
