Question about Mitsubishi CS-40507 40" TV
Have Mitsubishi 40" CRT TV. Will not turn on since thunderstorm.
I have a Mitsubishi 40'' CRT TV. It's older but it's a great TV. After a recent thunderstorm a couple of items, all connected to verizon fios, developed a few problems. the day after the storm I tried to turn this TV on and nothing happened. No flash , no sound, no crackling, nothing. So it's either time to burry it or maybe there's some fuse or reset switch on the inside that would solve my problem. Does anyone know if fuses or a reset switch might be inside this 300lb beauty. I'll also take any other suggestions as to what may have happened and how it might be fixed. Thanks for listening and I look forward to any help.
  • Mitsubishi Master
  • 3,828 Answers
Without a surge protector could have spiked the
Tvs circuity boards
without the TV having any defaults or life from the screen
doubt if a digital desk top unit to tune it would help
Posted on Apr 10, 2017
5 Suggested Answers
SOURCE: mitsubishi ws-65515 tv green light blinks constantly after power failure.
Posted on Jan 19, 2009
  • 69 Answers
SOURCE: My Mitsubishi ws-65819 won't power up. When I use
Unplug it ,leave it unplugged for at least an hour.
now slowly plug back in , if you notice a small spark coming
from the plug when you plug it in that's normal
which means most likely the regulator or output tran is out.
is about 150.00 200.00 normal cost. no more.
If the plug doesn't spark at all when you plug it in slowly
could be a Fuse :>
Posted on Jun 28, 2009
  • 17 Answers
SOURCE: model CS- 40307 40 inch Mitsubishi TV will not turn on
continue to push power button until light turns green. verie rate of push and hold
Posted on Jul 15, 2009
  • 21 Answers
SOURCE: Mitsubishi Diamond TV power went out TV wont turn back on.
the regular problem is the convergence kit,
Posted on Jan 20, 2010
Schematics cs 40505
Alas, your great TV has had a power supply failure.
Mar 10, 2014 | Mitsubishi Televison & Video
Tv mitsubishi
Older 35" and 40" Mits have RGB driver IC's on signal board that go line 13 pin part # AN5862.....replace both...test with
heat & cold technique........... OR CRT is bad..................T.
Jan 15, 2008 | Mitsubishi CS-40707 40" TV
1996 mitsubishi 40" tv has a black screen and
no pic at all usiually means the the heater element in the picture tube it self is burned out. Also there could be a problem with the internal power supply that gives electricity to the heater element. These are all thing the cunsumer cant fix. You either need to trust ONLY a certified Mitsubishi TV repair man, or replace the TV.
I know it's not great news, but if this advice helps, please give me a good rating.
Jun 30, 2011 | Mitsubishi CS-40505 TV
Model CS- 40307 40 inch Mitsubishi TV will not turn on
Jul 15, 2009 | Mitsubishi WS-65819 TV
Black screen
use your remote then turn off the text messege of your tv.the black screen that you seen is for the messege but since their is no message written in the box ,that's why you see a black box.
Jan 26, 2009 | Mitsubishi CS-40307 40" TV
I have a mitsubishi cs-40307 that never powered back on.
try to check the horizontal output transistor if it is good,check up the power regulator
Jan 10, 2009 | Mitsubishi CS-40307 40" TV
surge can come in thru antenna circuit ck outlet with lamp. otherwise need tech.
Dec 02, 2008 | Mitsubishi CS-40707 40" TV
Mitsubishi tv locked in parent lock mode after thunderstorm
i don't have the same model but there are ways to override the lock like on mine you held the q.v. button on the remote and tapped 9 repeatedly
Sep 28, 2008 | Philips Magnavox 20MS3442 20" TV
APEX TV won't turn on
My APEX TV doesn't come on when the power switch is pressed.
Jul 20, 2008 | Apex Digital PF2025 20" TV
1995 Mitsubishi 40" Television - Worth Repairing?
there are bad solder connections on the vertical deflection IC resolder them and you will be fine
Mar 13, 2008 | Mitsubishi CS-40503 TV
Televison & Video Logo
151 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
