Question about Equator 20 in. CD 400 Compact Dishwasher
Soap dispenser need to know where the soap dispenser is all i see is a trough that says detergent on one side and the othe side is a dispenser which manual online says its for a rinseing agent
There is a screw cap on the back wall of the dishwasher,unscrew the cap and place your rinse agent in there.I groove on the door is for your dishwasher powder
Posted on Jul 22, 2008
The soap dispenser only closes after several tries. At the end of the cycle, the soap is wet and stuck in the open dispenser
May want to try liquid detergent instead. Sometimes using too much detergent will prevent the dispenser from opening and then the soap turns into a wet glob in the dispenser.
Mar 15, 2016 | Dishwashers
Silly question - where do you add the detergent?
Often you will find the detergent dispenser very close to the dispenser for the softener. Mine is a separate container within the same "pullout" drawer that holds fabric softener. If you still are not sure, then find the model number of your washer and google it with the term, "user manual". Most are available online as a PDF
Nov 22, 2013 | Maytag Neptune MLE2000A Front Load Stacked...
Ge potscrubber 700 dishwasher - the soap dispenser cover is locked and will not open. I have run the dishwasher several times and tried to force it but it will not budge. any suggestions?
Soap dispenser cover will not open until front knob is at 4:30 or 5 o'clock. Turn knob to 5 o'clock and jiggle dispenser cover. If cover still does not open, is detergent caked such that door won't open? If yes, remove caked detergent. If no, disconnect power at breaker. GE repair manual says to remove screws for inner door panel and inspect detergent dispenser mechanism with lever and trip lever for broken or binding parts.
Oct 13, 2013 | GE Dishwashers
Soap wont dispense from detergent tank
go to the page from black and decker and see the video for troubleshooting and help. or get support online via chat of phone.
God bless you
Jul 23, 2012 | Vacuums
Soap dispenser sticks shut
Detergent cup, itself The detergent cup itself can become clogged with old dried detergent that prevents it from opening. Sometimes just cleaning the cup takes care of the problem. If not, you probably need to replace the entire cup assembly
try cleaning it out with hot soapy water make sur its releasing freely ..Hope this helps if not let me know
Nov 20, 2009 | Kenmore Dishwashers
When I fill up both soap dispensers, only one is empty after the wash. The cover never releases the other soap. It says fill both and then cover the right side. But after the dishes are washed - the...
The electric solenoid that opens the dispenser has failed. It is possible to replace it but you will probably have to disassemble the door to do it. An alternative might be to use a detergent tablet only in the open cup. It will partially dissolve during the pre-wash and what remains to dissolve in the main wash may be enough to get the dishes clean. Try this if the cost of replacing the solenoid is too high.
Aug 25, 2009 | Dishwashers
Dishwasher's detergent reservoir clogged
I have the same problem...I think I mixed the soap types (Enzyme based with Bleach based). The manual clearly says not to do this.
What I did was brought out my trusty wet-vac and sucked it out while using HOT water to break up the crusty mess. I am going to fill the dispenser with water and add soap the old way until I see the "low soap" light go on.
I'll keep you posted if this happens.
Oct 08, 2008 | Dishwashers
SOAP DISPENSING
The soap dispenser is intended for both liquid and powder detergents. If you have a problem with mildew, then you may need to clean it occasionally with bleach water.
Aug 07, 2008 | Hotpoint WMA50 Front Load Washer
Front Load Washing Machine
Filling laundry detergent and/or additive
dispensers
Dispenser I: (RIGHT SIDE)
Detergent for soaking agent.
Dispenser II: (LEFT SIDE)
Detergent for wash, stain remover.
Dispenser 2: (MIDDLE)
Cleaning product, e.g. fabric softener, fabric
conditioner (do not fill above the lower edge of the
insert 1).
Dec 29, 2007 | Washing Machines
Could SOAP DISPENSER be caked with soap???
POWDERED DETERGENTS GET CLOGGED ALOT IN THOSE DISPENSERS. I ADVISE CUSTOMERS TO FILL THERE WASHER AND ADD SOAP WHEN IT STARTS TO AGITATE WHEN USING MORE THAN A 1/2 CUP OF POWDER ... THEN ADD YOUR CLOTHES ... THE WASHER HAS A SAFTEY SWITCH WILL STOP MOST WASHERS WHEN AGITATING OR IN SPIN CYCLE,SO YOU CAN LOAD CLOTHES ... OTHER THAN THAT ... ALL YOU CAN DO IS KEEP THAT DISPENSER FLUSHED OUT WITH HOT WATER AFTER EVERY WASH. JUST POUR HOT WAYER TROUGH IT ... IF THE WATER BACKS UP (EVEN WITH A SLOW POURING) THE DISPENSER IS PLUGGED AND NEEDS TO BE FLUSHED OUT WITH A HOSE. GOOD LUCK AND STAY DRY !!!
Apr 29, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Equator 20 in. CD 400 Compact Dishwasher Logo
132 people viewed this question
Top Equator Dishwashers Experts
Paul Carew
Jaye t rock
Are you an Equator Dishwasher Expert? Answer questions, earn points and help others
