Question about IBM ThinkPad T23 Notebook
The computer will not boot up. I have changed the c-mos battery. I can here the dvd boot up bue nothing else no hard drive activity light.
  • 2 more comments
  • A Miller Jun 05, 2010
    Cmos is not your trouble ...
  • ac7bi Jun 05, 2010
    What might be the problem? You are correct the c-mos battery was not the problem.
    More info. The computer was working well for years ,then it started to take longer and longer to boot up. then finelly it just won't boot up all I get is a black screen , I can hear what seems to be the cooling fan running and I hers some sound from the area of the dvd but nothing else happens. I hope this helps.
    Ok thanks for your help. I swapped out the RAM an it made no differance. I guess I will have to retire this unit.
    Thanks again Willie.
  • IBM Master
  • 8,404 Answers
Slow computer is caused by a build up of junk and stuff running in the back ground.
Get CClean from http://www.piriform.com/ccleaner/download to start to fix this problem ...
UNload stuff you dont use ... clear it fromthe startup menu
CMOS is not involved in this problem in any fashion
Posted on Jun 05, 2010
    Scholar:
  • 113 Answers
If it has more than one piece of RAM try booting after taking one out and swapping them out. Other than that there is a good chance the motherboard is bad.
Would appreciate if you would add more detail.
  • 144 Answers
Basically,there is also a "beep" code,the problem persisting occors to be your motherboard.This can happen sometimes if the unit has been knocked and the motherboard or a piece of hardware is damaged or the motherboard is too old and needs replacing.- hope this peice of info was helpfull.
Zkhan
Posted on Jul 03, 2010
    Genius:
  • 1,354 Answers
Hi
frist chack your C-mos battery
then try try agane hope fully it will work
My acer pc is not booting properly
there maybe faulty installed hardware on your PC. remove those hardware like sound & video card (if any), PCI modem, CD/DVD ROM, etc. turn on your PC without those hardware & if/ there's nothings change?..it means that there is no wrong with your PC's hardware. turn the PC off, re insert IDE & power supplies cable of your hard disk drive to make it sure that the HDD is properly connected & being detect by the system. remove the memory card and clean or wipe the connector surface of the RAM with tissue paper. (change new memory card if needed). check the mother board C-MOS 3 volts battery if it is volts sufficiently .turn your desktop on & wait for good results.( Reformatting your OS is also recommended.)GOOD LUCK!
Jul 09, 2014 | Acer X193W LCD Monitor
What is the fault when the battery light flashes orange (suspect dead batt), also the unit will not boot, nothing from the screen, and the blue power and Wifi lights are illuminated?
1. Suspect dead battery- Your battery might be dead. just replace your battery.
2. Cd-drive spin but cannot run
- solutions is -
1. Please check if the support DVD has been damaged
2. Please check if the external optical DVD drive can work normally
3. Please unplug other USB devices
4. Please disable [Boot Booster] in BIOS
4.1 Start the system and press on bootup to show the POST screen. Press again to enter the BIOS setup.
4.2 Set Boot Booster to [Disabled]
4.3 Press to save the configuration and restart Eee PC.
Alos with other solutions,
ASUSTeK Computer Inc Support Troubleshooting EEE PC 1000HE
Jan 19, 2014 | ASUS Eee PC 1000HE Netbook
When i start my laptop it goes to a screen an says enter boot disk an press any key..but i dont have a disk...
Sounds like your system is booting from somewhere other than the hard drive or you have a music cd or movie dvd in the DvD/CD drive when you booted the laptop. If so, remove the music cd or movie dvd and reboot.
You want it to boot from the hard drive.
Turn the computer off and press the power button to reboot it. Notice the screen and watch for which key it says to hit to change the Boot Order or Boot Sequence. You have to hit that key when you see the message otherwise it will be to late and you will need to start over. Select the Hard Drive and let it boot up. This is a temporary change and only good for this boot cycle. You'll have to do it each time you boot or you can make it permanent.
To set your boot order or boot sequence permanently reboot the computer and look at the screen to hit the key it says to get into the Bios or System Setup. Hit that key when you see the message or it will be too late and you will have to restart it. When you get into the Bios or System Setup tab over to the Boot Order or Boot Sequence. The normal boot order should be the DvD/CD drive 1st, the Hard Drive 2nd. With this setting you have to make sure nothing is in the DvD/CD drive when you boot the system or it will try to read it as a system disk and give you an error if it can't boot from it. If there is nothing in the DvD/CD drive it moves to the next boot device which is the Hard Drive. This setting is the best because it will allow you to use a Repair Disk or Operating System Disk to fix your computer when the hard drive has issues.
May 20, 2012 | Computers & Internet
My computer (3.0 GHz Pentium 4 with Asus P4P800-E Deluxe mobo) will boot to the POST screen, and it successfully identifies all of my hardware (memory, hard disk, DVD-ROM drive, etc.), but then won't...
Checked your RAM chips? Remove them and boot up and see if it will beep. If you have another DVD drive, swap it and try again. The board battery rarely goes, and only change it when it is not keeping the date/time etc, it won't help in outputting video.
Sep 10, 2011 | ASUS P4P800-E Deluxe Motherboard
Hp dv5020us won't boot. upon power up I get some brief hard drive activity and fan noise. No blinking LED error codes. Caps and/or Num lock LED's do not light. Power LED will glow and HD...
step one, big battery out? skipped that?
step 2, a good power pack , that means 19vdc on those 2 pins.
bingo BIOS screen now work ,yes?
step 3, try an external VGA screen at the P15 VGA jack there
screens work now (BIOS first) yes/no?
remove DVD, drive
and all USB devices
there booting with only 1 memory stick. (got more?, try each 1 by 1)
black screens of *****'.
the lack of flash codes, Implies Power pack is dead. or CPU overheated, and selfshuts down. that fan going dead tells
me the power park is dead.
http://pcdied.com/#black-screens
May 01, 2017 | HP Pavilion dv5020us Notebook
PXE E61: media test failure, check cable PXE-MOF: exiting broadcom pxe ROM. no bootable device - insert boot disk and press any key
try to check if your hardisk is plugged properly, i had encountered it before. same response i got from the computer. "insert boot disk and press any key"
May 03, 2010 | Computers & Internet
Computer randomly fails to boot
how many video cards do you have installed?
Nov 14, 2008 | E-Machines eMachines Desktop PC
Power to laptop , but hard drive activity light
possibly a bad processor.I built two that did the same thing,,,already replaced processor in one and it works fine now
Apr 11, 2008 | Toshiba Satellite A55-S106 Notebook
No splash screen, no activity just lights (evo N610c) Plz help.
turn on your computer and do nothing,, when it seems the computer stop running key in fn+f4.
Dec 30, 2007 | Compaq Evo N610C Notebook
I have a Boot Problem with my INTEL P4 3.0Ghz. 800Mhz FSB,1M L2 Cache, Socket 478 CPU
I have experienced something similar with my new Core2Duo processor and a fairly new Socket 775 processor. Troubleshooting it led me to believe the CPU simply wasn't compatible with the motherboard. Although it's a shot in the dark, I suggest that you try out some of the following: - Did you try pulling out the graphics card to see if you got it to POST then? The graphics card or the monitor may need replacing. - Did you remove the RAM? - Are you sure all cables are attached properly? - Try to take out the CPU, talk to a friend with a socket 478 motherboard and replace his CPU with your CPU. Does it work now? If yes, motherboard needs to be replaced.
Nov 12, 2006 | Intel P4 Prescott CPU 2.8A Ghz W/1MB CACHE...
IBM ThinkPad T23 Notebook Logo
93 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
