Question about LG LMVM2085SW 1100 Watts Microwave Oven
Power went off
Started coooking popcorn and power went off and will not come back on.
  • LG Master
  • 8,404 Answers
Check the fuse on the floor of the oven near the power cord inlet.
Posted on Jun 05, 2010
Serial number 112Km00462. If overheated and power goes off .....is it safe to use when power comes back on?
The magnetron thermal protector probably shut the oven down. Magnetrons don't like it when their load impedance is too low (empty oven or popcorn) and they get quite warm. Operating an oven empty also shortens the life of the magnetron.
Aug 01, 2016 | In Microwave Ovens
KitchenAid microwave went totally dead
i suggest you go to wal mart and purchase another one after you check your power outlet with another item before you do replace it or try plugging it in else wjere if none of the suggested things i have said works, i suspect its dead, i know of no one who repairs the things,, due to there usually throw away cheap made to start with,, good luck..
Aug 06, 2012 | KitchenAid Microwave Ovens
I have a daewoo countertop microwave/convection oven and I can't pop popcorn. It pops only half of the popcorn and burns what it pops. What's the deal?
Check the power setting it may be too high and are you useing microwave popcorn?you generally can not use standard popcorn in a microwave.The power setting required is on the bag of microwave popcorn
Dec 29, 2009 | Daewoo KOR-63D5 Convection/Microwave Oven
Microwave burns popcorn. what part is defective?
If the microwave functions normally while cooking everything else, but is only burning popcorn, there is no component problem that will cause this. You cannot adjust or replace any internal component to make it not burn popcorn. All power levels and program options are contolled by the consumer at the control panel. Refer to your owner;s manual for their recommendations.
If the oven is equipped with a popcorn feature button, it is programmed for a recommended power level and time. This is an ESTIMATED program feature. The manufacturers of both the oven and the popcorn will also give directions that tell you to turn the oven off when the popping slows to about a pop every 2 seconds. Failure to do so can result in burning.
If the microwave does not come with a popcorn feature button, the manufacturers of the popcorn have directions on the outside of the box that tell you what POWER LEVEL and TIME to set the oven on for the desired result. Again, the you still have to listen as the bag pops to ensure it does not burn.
In addition, on some microwave ovens, there is a feature that allows you to select the SIZE of the popcorn bag. Some popcorn manufacturers have smaller snack size bags that don't take as long to pop. You have to select the appropriate size to get the correct program option.
In any case, you never are to place popcorn in a microwave oven and walk away from it. All these program features are ESTIMATIONS based on manufacturers testing and recommendations for the best results. All microwave ovens are different and operate at different power levels. Your best judge is to listen as it pops.
I hope this helps you.
Dec 23, 2009 | GE XL1800 1100 Watts Microwave Oven
Microwave started making slightly louder noise now will not heat
either the h.v. diode or the h.v. capacitor are open and replaced they build the hi voltage needed by the magnetron tube assembly
Oct 07, 2009 | Whirlpool MH7140XF Microwave Oven
Can't pop popcorn well
It's 850 Watts, 0.9 cu ft.
That's enough for popcorn, but a magnetron does lose power once it starts to age.
The figure I've heard is an average life expectancy of 2000 hours for a magnetron.
Two "Band-Aid" suggestions for better exposure and more even heating:
1. Place the popcorn bag on top of an upside-down paper plate.
2. Place the bag off-center instead of dead center. Placing food in the center of the turntable is not as efficient as placing it off-center.
Dec 12, 2008 | Welbilt MR95TW Microwave Oven
Oven turns off
You are running the risk of damaging the Magnatron by doing this.
Check the packets you are using, you will have to reduce your power output.
This is because microwaves act by being absorbed by water. There is very little in popcorn and in fat. Once this has been evaporated, the microwave energy builds up (as it is still being produced - but not absorbed), and ends up cooking the magnatron itself.
I have seen countless posts on here after cooking popcorn!
More fun on the hob anyway - and cheaper to buy in bulk!
Jun 21, 2008 | Magic Chef MCD1311ST Microwave Oven
Emerson Microwave
Did you unplug it for several minutes and them plug it back in?
If that dosn't resolve your problem, it sounds to me like the microprocessor controller board has failed and will need to be replaced.
Please let me know if I can be of further assistance to you.
- Jim
Feb 13, 2008 | Microwave Ovens
Magic chef microwave shuts down
We had the same problem with our brand new Magic Chef. Before going through the trouble of taking it back I called Home Depot. After talking to a Home Depot Rep I am told that the overheat sensor is under the glass plate directly beneath the popcorn bag. Popcorn gets very hot and the heat of the popcorn causes the sensor to shut the machine down. I would imagine this would be the same for a baked potato.
Very poor design.
I was told to put a microwave safe plate down and put the popcorn bag on it. This should help to reduce the heat and not trip the sensor.
A safety sensor is great, but not if it keeps tripping the machine and shutting down!
Sep 02, 2007 | Microwave Ovens
LG LMVM2085SW 1100 Watts Microwave Oven Logo
43 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Greg Cann
Greg Cann
Devabhakthuni...
Devabhakthuni...
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
