Question about HP Photosmart 3210 Printer
Line when copying and scanning - HP Photosmart 3210 Printer
    President:
  • 3,085 Answers
Lift the lid and clean the glass surfaces
Posted on Jun 11, 2010
  • 10,319 Answers
The print head needs major cleaning.
it must be removed and cleaned with denatured alcohol
Posted on Jun 05, 2010
How do I get rid of the black line when I scan or make copy's
I had a professional to clean the scanner and copy machine. The line was gone. He had special tools to clean the machine parts.. Hope that helps.
Jul 17, 2014 | Brother MFC 8950DW
Vertical black line on scans or copies;
Hello James,
Please click Vertical Bands Lines or Streaks in Copies Faxes or Scans to access the troubleshooting steps that should resolve the issue.
Mar 03, 2014 | HP Officejet Pro L7680 All-In-One Printer
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
Scanning/copying problem (Lexmark 6500 series x6575)
please just you scan the object to resuleasion in and dp is 600 to 12oo select and you scane object and aply print is dark is ok.
Sep 17, 2009 | Lexmark X5150 All-In-One InkJet Printer
HP OfficeJet J5780 Vertical Black Line Prints when copying or scaning only. Cleaned rollers and changed black ink cartrigde. Still problem.
Have you tried cleaning the document feeders Scan Glass? (small glass under doc feeder ~ 1" by 9") Most times there is dirt spot on this glass, causing a shadow on scans and copies.
Try copying from the large glass by lifting doc feeder / platen cover and manually placing original. If no line copying or scanning manually from large glass, then small scan glass is deffenitely the culprit. Hope this helps.
Sep 07, 2009 | HP Officejet 5780 Printer
Very crisp vertical grey line appears (glass clean)
I have the exact same problem. It was there since I first bought the MFC-7840W.
Vertical line appears in scans using the automatic document feeder (ADF).
Vertical line does not appear when scanning single page (placing it directly on the glass -- i.e. not using the ADF).
Cleaning the glass strip for the ADF (or the white pressure bar overhead) does not solve the problem.
The problem does not occur with copies using the ADF (using the COPY button which is basically a scan and print). This would suggest that dust and dirt is not to blame because that would also appear on the copies.
But since I believe a copy is basically a scan plus print, they should be using the same electronics -- a hardware problem on the scan would likely appear on a copy also -- there is some difference between how they accomplish this.
It's definitely not a software issue since it occurs on all versions of Windows and Mac OS X (and multiple computers). It also does not matter whether I "push" the scan to the computer by using the scan button on the MFC... or "pull" the scan from the MFC using the Brother Control Center software.
Aug 12, 2009 | Office Equipment & Supplies
Scan and copy lines
using PRT screen and menu find clen function and try if this feature will fix the issuw.
Change the cartridge if no results.
Jan 30, 2009 | HP LaserJet 3050 All-In-One Printer
Two black vertical lines appear on copy, pdf, and scan results
  1. Unplug the power cord and the phone line from the wall.
  2. Open the control panel.
  3. Pull the roller lever forward, and then lift the white roller out of the All-In-One.
  4. Note: The scan lens is located under the white roller.
  5. Use a clean, lint-free cloth dampened with water to wipe the white roller and the scan lens.
  6. Reinstall the white roller.
  7. Reconnect the power cord and the phone line.
  8. And then try to copy if get the dame line then its the hardware problem in the printer you must need to replace the scanner unit in the printer ..
Good luck..
Sep 01, 2008 | Lexmark X4270 All-in-One Multifunction...
Dell 1600n and vertucal line while scanning
Any difference between using the document feeder and just the flat bed?
Nov 05, 2007 | Dell 1600n All-In-One Laser Printer
HP Photosmart 3210 Printer Logo
60 people viewed this question
Seeker5211
Seeker5211
