Question about Toshiba Satellite A135-S4527 Notebook
I changed my vavle cover gaskets and spark flugs but now its back fireing from the carb with a flame am ading gas to start it making a pop pop sound but left this like ground wire that goes to the screw and i dont know where must of pulled it off from the right side of the block could that be a reason
  • Zaraki Jun 05, 2010
    What is the year, make, model, and engine size of your vehicle?
  • 10,319 Answers
You have two spark plug wires going to the wrong plugs..
that will cause a popping noise
Posted on Jun 05, 2010
Why does a flame come out of the carburetor when I try to start it
Hard to answer this not enough information..one thing I can say is your carb the is flooding the cylinder with excess gas..and when the spark ignites it is sending the burning gas back into the intake and back through the carb where the air gas mixture comes in...timing could be a problem where the intake valve is still open on the fireing stroke..another could be the internal float stuck in the carb...this allows gas to leak back into the cylinders and intake manifold..before doing anything..need to check a few things out..some of these newer carbs have an electric valve on the bottom of the carb. Is there to keep the gas from leaking out on the ground when the float is stuck..however it does allow the gas to leak back and into your engine..and cylinder..and when you try and start it will throw flames back through the carb...but it also may fill you engine crankcase with gas...and damaging the engine sofirst thing check your oil for gas smell and on the stick..drain it if it does..pull your plug and cover the end so it can't spark..and turn the motor over if the cylinders have gas they will Blow it out.."" The reason to cover the sparkplug end" .
NOTE....this is an ongoing problem with this engine type so after you follow the ustructions,,,if not already on the gas line get a inline gas shut off valve and put it on the gas line and make sure it is OFF when you are done mowing or when the engine us not running..This will happen again if not done...change the filter and oil and you are good to go..By the way I know this fro my own experience with these new carp leak protectors..pass the word....if this is not the problem carb will need to be rebuilt..or renewed.....good luck.
Oct 01, 2014 | Craftsman Snow Blower 26 In. 208CC...
Enith carburetor diagram
Nobody has messed around with the ignition timing in any way?
If it has stood for a long time(i.e years..) the fuel may have degraded to the point that it\'s useless.
The carbs will smell of fuel, but are you sure that fuel is being pumped to them in sufficient quantity? Try disconnecting a fuel line, crank the engine a few revolutions to see if fuel is pumped out.
Try gravity feeding the carbs. Use a can of fuel connected to the carbs, held above the engine. Get somebody to crank the engine and see if it fires up. If the engine fires up, suspect the fuel pump.. or fuel lines.
An air leak can also cause non-starting. The usual cause is the inlet manifold gasket. Any air leaking through the gasket can cause your non-starting problem. Go back and check that no dirt has been picked up by the gasket before you fitted it/it hasn\'t been ripped. Check that the inlet manifold has been correctly tightened.
It doesn\'t sound as though you have much of a problem .. more of a \'niggle\'.
The link is for Zenith carburettors:
Zenith carburetor Google Search
Aug 20, 2014 | Cars & Trucks
Generator back firing from inlet manafold
Your symptoms are from running lean. Foam air filters put debris in carb jets. Check all the carb passageways and jets. Always start with a new plug.
Nov 29, 2013 | Electrical Supplies
Stx46 cranks or fires but will not start
sounds like timing is off or no fuel getting into the manifold . remove and check main jet or for fuel in the bowl.
Jun 16, 2013 | John Deere Garden
I have a 24hp briggs els have to prime carb with gas to start when cold
check the anti back fire valve on the bottom of the carb it might b e stuck partially closed
Apr 10, 2012 | Garden
Carb popping at high accelaration
hi this could be a timing fault, it sounds like the valves are opening at the wrong time, making the fuel build up in the pots and of course when it does spark that's when you get the big bang, the built up fuel burning , try checking your timing as you actually might be 180dgs out on the distributor not the engine....hope that helps
Mar 20, 2010 | 1989 GMC Sierra
84 s15 2.8l misfire, popping carb, and gas and coolant in oil
Wow, sounds like head gasket &/or timing problem. First thing you need to do is a pressure test on cooling system to see if head gasket gone, then I'd do a compression test as well. Have you pulled any spark plugs to see what they look like?
Aug 03, 2009 | 1985 Chevrolet S-10
Briggs and Stratton 6.5 hp won't start- not sure gas is getting to the spark plug, just overhauled the carb, changed oil and new spark plug
First you could make sure you have spark. Take the plug out and then plug it into the black wire. Set the end of the spark plug near the frame of the lawn mower. Pull the cord one time to see if there is an arc from the plug to the mower. If you have spark, I would put the plug back in. Before putting the plug back in I would spray a little bit of starting fluid. See if it will fire up with the starting fluid in there. If you have a true good spark, it should fire up. This may be enough to get some gas going in there as long as you have the lines hooked up correctly.
Aug 03, 2009 | Craftsman Garden
Honda gx 340 will not start
does it have a new Spark plug I have seen them fire and still be bad
Jun 30, 2009 | Air Tools & Compressors
My gas Craftsman Ez Fire 25cc 17 inch weed eater wont start!
The carb must be cleaned. take the carb off put it on a work bench and pull it apart layer by layer... be careful as there is a spring that will jump out. pull all of the gaskets off and clean behind them. make sure all of the passages are clean. Use brake cleaner from the auto parts store! do not use carb and choke cleaner as the gaskets will instantly expand and be useless. there is also a brass cylinder in the carb you need to remove it and clean it well. There should be a very small hole in the center. put it back together and you should be good to go
Jun 13, 2009 | Craftsman 25cc Gas Line Trimmer
Toshiba Satellite A135-S4527 Notebook Logo
27 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
