Question about Bryant 463AAC008BA Air Conditioner
Reset button on bryant air conditioners - Bryant 463AAC008BA Air Conditioner
  • 113 Answers
SOURCE: air conditioner unit will not come on ,no reset button
some have a reset on the plug
Posted on Apr 27, 2009
co7196
  • 3433 Answers
SOURCE: Bryant Legacy Air Conditioner doesn't blow out cold air
Unplug the unit with all controls off, then plug back in and wait 5 minutes before turning on switct at unit. Good luck
Posted on May 27, 2009
  • 674 Answers
SOURCE: 561CJ060-a bryant air conditioner two control wires disconnected
Sorry if I am answering this 2x. If it is just A/C then the red and white probably go to the coil for the contactor that cuts on the fan and compressor. If it is a heat pump then they probably go to a circuit board. Red to R terminal and White to W1 terminal. Let me know what you find.
Posted on May 03, 2010
Testimonial: "great help. unfortunately there is something else wrong with this item. Thanks. Mike"
  • 949 Answers
SOURCE: Our Bryant air conditioner that
These symptoms usually indicate a problem with the drain. If the drain for the evaporator is restricted it may leak, if it leaks enough it will activate a float switch that turns off the air cooling unit.
The first thing you need to do is locate the evaporator, depending on where you live and what type of home you have it will be in the basement or the attic most likely. There will be a pan under the cooling coils, if in that pan there is water then your drain for the cooling coils is plugged. Look above that pan for another drain line that is the one you need to clean out.
In the pan that has the water you will find some type of float or water switch that is keeping the A/C from coming on.
Send me a message here if you have questions.
Posted on May 29, 2010
TX_AC_Man
  • 107 Answers
SOURCE: noisy scroll pump in Bryant air conditioner when
this noise is 100% normal and follows the turning on or off of most scroll compressors in all brands
Posted on Aug 19, 2010
Testimonial: "TX_AC_Man gave a short, clear answer to my question. I am indebted to him. "
Where is reset button on bryant model 661CJX030000AEAA
Reset? Button. Turn the breaker off for 1 minute then back on.
May 31, 2016 | Bryant Heating & Cooling
Blower on my model 517E Bryant air conditioner will not shut off
if you are talking about indoor blower a relay contacts are stuck in.
Mar 02, 2013 | Bryant 462AJC021BA Air Conditioner
Code 33 - changed filter need to reset - how??????
Should reset by shutting off power to furnace and then back on With a Bryant if you turn power off and then on, if the thermostat is calling for heat when power is restored blower will run for couple minutes before trying to fire furnace. This is normal
Jan 23, 2011 | Bryant Heating & Cooling
Do bryant condensing units have a reset button? We can't get the unit to kick on. All power is correct and fan starts inside, but can't get condensing unit to kick on.
Most Bryant units do not have a reset button but could have a low pressure or high pressure switch for a safety to protect the compressor. Verify power from the thermostat to the contactor by following the thermostat wires all the way to contactor inside of electrical compartment... TURN POWER OFF BEFORE OPENING.... If power is to contactor and contactor is pulled in then you would need to look at the capacitor of which is a canister about 6 inshes tall with wire terminals on top.. this part should be flat on the top and if it is rounded then thats your problem.. if not then contact a local company to troubleshoot and make necessary repairs.
Sep 01, 2010 | Bryant 463AAC008BA Air Conditioner
I have a Bryant model 597CN048-D that quit working suddenly. All circuit breakers recycled. Any suggestions? Also what is the tonnage for this model?
That is a 4 ton unit...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Jul 07, 2010 | Bryant 463AAC008BA Air Conditioner
Where do i reset the ac unit?
You've given hardly any information to go on. The only resets on air conditioners are the gfci on the plug of a window a/c.
Jun 20, 2010 | Bryant 463AAC008BA Air Conditioner
Heat pump Bryant model 541DJ024 Is there a reset switch. The fan comes on but no cold air coming out after power surge/outage 3 days ago.
their is sometimes a high psi switch that has a manual reset. it is red with a red rubber button. it is usualy lokated in th outdoor unit. in most areas it is code that their is a disconnect within 10 ft of the unit most of the time they have fuses in them. open the disconnect and their is a plastic sheild that needs removed sometimes.
Jun 13, 2009 | Bryant 463AAC008BA Air Conditioner
May 27, 2009 | Bryant 462AJC021BA Air Conditioner
Bryant A/C issue
IF it has one its usually but not always close to the 2 copper lines on the outdoor unit. BUT not all units have a high pressure reset. LOOK inside the outdoor section for a bare looking copper "wire", It will atach to the smaller copper line comming off thecompressor. If you dont see one it dosnt have one.
If you find it trace it down to the other end and usually has a piece simmlar to a battery sometimes no bigger than a golf ball and the button is usually pointed toward the outside on the other end.
2nd question as far as Im able to tell the fuses (and again it may not require fuses as long as it has a breaker or other means of protection) will be in a usually gr\ay box usually attached to the wall. Trace the wires comming into the unit back to the power source.  And generally the box you find on the wall ois where the fuses are. Now this box is only a disconnect and its reason for being is so hyou can remove power from the oudoor section and work on it sepperately. IT MAY NOT HAVE FUSES AND STILL BE APPROPERATE FOR YOUR TYPE OF INSTALLATION as ameans f disconnecting.
Jul 17, 2008 | Bryant 463AAC008BA Air Conditioner
Heating & Cooling Logo
1,058 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Dan Webster
Dan Webster
Bill Long
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
