Question about Compaq Presario X6000 Notebook
My X6000 show vertical strips all along in the LCD screen. What could be the problem?
  • ahcorral Jun 08, 2010
    This is a consistent problem and it is getting worse. When I leave it ON for a long time I find more lines in the screen.
    Scholar:
  • 113 Answers
It could possibly be the video driver for the machine.
It could also be a loose connection between the screen and the motherboard.
Is this a consistent problem?
If not, when do the lines appear and for how long?
Posted on Jun 05, 2010
  • Angelo Valentino Montalbano
    There is a very good chance that you will need to buy a new screen to replace that one. From what you have wrote it seems that the screen is simply just going bad.
    Search for
    Compaq Presario X6000 Series 17 WXGA+ Glossy 1 CCFL laptop LCD
    screen
    That's the screen for your laptop model if you choose to replace it.
  • 10,319 Answers
The matrix screen is going out and will continue to grow worse if kept using it
Vertical stripes
Your LCD panel motherboard has gone dud. You need a new LCD panel...but probably a new tv!
Mar 09, 2014 | LG 47LS4500 47" 1080p LED-LCD TV - 16:9 -...
My 46in led/lcd tv has a vertical black strip 5in wide
could be the format board or the panel, check out http://www.shopjimmy.com/ and order the format board first.
Sep 06, 2012 | Insignia "- 46"" Class / LCD / 1080p /...
Vertical strip of flashing horizontal lines on Acer Aspire 7551G screen
More than likely it's the lcd screen and will have to be replaced. I could be the video card, but most likely the lcd screen especially when you can put pressure on the screen and cause changes. To isolate the problem try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the laptop. If the Borrowed monitor displays ok, then the problem is with your lcd screen and the video card is ok. If the Borrowed monitor displays the same as your lcd screen then the problem is with your video card inside the computer.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
Once you narrow it down to the lcd screen as being the problem you might try taking the lcd screen apart to reseat the lcd cable on the back at the top of the lcd. Just unplug it and plug it back into the connector. You can also try doing the same where the lcd cable plugs into the motherboard. Just pull it out and put it back.
May 31, 2012 | Computers & Internet
White screen with vertical and horizontal display problem
This the problem related with LCD. Horizontal and vertical line occur, the cause of LCD data strip disconnected. If you are able to open the LCD bezel and back cover then look display data strip that is connect with LCD. if you need more then hit me mail,I'll be online on fixya.
Aug 06, 2011 | Dell Inspiron 5000 Notebook
The display shows a one-inch vertical white (non-pixel) strip
Your computer needs repair.
Its an issue with the LCD screen.
Oct 30, 2010 | Computers & Internet
Vertical strip on the screen
You have failing T-CON board which is part of the LCD panel assembly, it will get worst with more lines, new panel will be needed. You can try reseating the ribbon cable on the T-CON board.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Jun 16, 2010 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Can I get a presario to boot vga output only?
Yes you can go ahead and use an external moniter to use your notebook but reformating would not help. try to go to HP.COM nad get the graphis driver and bios updated still if its the same you need to contact HP and they would take it for repair, however if it is not in warranty then they would charge you, for repair,since the graphics card is always embedded with the motherboard it will not be possible to replace it on your own. you can also check the repair prices in local stores.
Apr 13, 2010 | Compaq Presario X6000 Notebook
4"STRIP OF LIGHT ON LEFT SIDE OF SCREEN (VERTICAL)
No ur LCD Screen is damage got hit by somethings.It not worth it to repair if the LCD Screen is damage.It cost about the same to replaced LCD screen as to buy a new tv.
Feb 12, 2010 | Televison & Video
Lg plasma screen half not showing lines
There is x driver board at the bottom of the set that needs to be replaced along with its x sustain. a realatively complex project.
Jun 25, 2008 | LG 37LP1D 37 in. LCD Television
Philips LCD model 26TA1000, vertical lines and blank white screen with no picture
it would be easier to find it stripped from a damaged set on ebay.
I see several there but need the part number to search
of course you may purchase that and find it to be the lcd driver.hopefully not.
Feb 17, 2008 | Televison & Video
Compaq Presario X6000 Notebook Logo
164 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
