I have tried different default ring tones for incoming calls and all seems to be giving distorted sound; is it some softwre fix or should I change the speaker?
Most mobile handsets have the feature of: A) while the phone is ringing, use the up & down volume buttons to alter loudness of the ring B) while ur talking on the phone, do the same to alter listening volumne.
Is the volume up? Download Zedge, look for a decent ring tone and set it as default ring tone. Try now. If it still doesn't work, go to settings, volume and make sure that is all the way up.
If you are facing the problem with some incoming calls it is an indication that you have set different ring tones for different users or incoming calls.
Very simply reset your mobile to a default setting by going to setting, restore factory setting and every thing shall be back to normal.
Strange. I would try resetting your iPhone. Hold down the home and power buttons until it powers off. It should start up automatically but if not just press the power button. This has worked for me in the past when my iPhone has acted strangely. Don't worry about a reset or hard reboot. You won't lose any data or settings.
Here some solutions for your problem + a link to the user manual.
**Selecting the Ring Tone and Volume Your phone has five different ringer tone/volume combinations you can choose from. To select the ringer: 1) With the phone in standby, press [vol/ / ] or [vol/ / ]. 2) The phone will sound the different ring tones at different volumes. To turn the ringer off, select RINGER OFF. 3) When the phone sounds the ring tone and volume you wish to use, press [end].
**Temporarily Mute Ringer If the handset is off the base while an incoming call is ringing, simply press [end] to mute the incoming ring. The ringer will sound with the next incoming call. Note: You can only mute the handset ringer if the handset is off the base when the phone starts ringing. Adjusting the Earpiece.
**Here is also a link to the phone manual http://www.uniden.com/pdf/EXI4561om.pdf
The answer mode determines whether the HP Fax answers incoming calls or not.
Different answer modes are :
* Fax
The HP Fax will automatically answer all incoming calls using the Rings to Answer setting. This is the default setting.
* FaxTel (unit with handset model only)
The HP Fax automatically answers all incoming calls using the Rings to Answer setting. If the call is a fax call, the HP Fax will receive the fax. If the call is a voice call, the HP Fax will create a special ring to indicate it is a voice call. The incoming voice call will need to be answered using the attached handset.
NOTE: If the HP Fax determines the call is a voice call, only the HP Fax will ring with the special ring tone. The other phones on the same phone line will not ring at all. You will not be able to pick up the voice call using the other phones.
* Tel
The HP Fax will not automatically answer calls. Faxes will need to be received manually.
* AnswerMachine
The HP Fax will monitor the line when an incoming call is answered by a person or by the answering machine. If the HP Fax detects fax tones on the line, it will receive the fax.
User profiles This is used to set up the different ways of incoming call prompts in various situations. Use the up/down key to choose this option and click the left functional key to enter. There are many modes of setting available and the default setting is the general mode. To switch to a new user profile, use the direction key to select the target mode and click “OK” to enter. Then select “activate” and click “OK” to confirm. Your phone will give an “activated” prompt, indicating that the user profile is active. The “headset” mode does not require activation; your phone will automatically switch to the “headset” mode if a headset is connected to your phone, and back to the previous mode when unplugged. You can also customize each user profile setting for your preference, the following operations are available: (1) Ring tone settings: Incoming calls: Enter “user profile”, select “personal setting”, and set up the ring tone. Power on: set up the music for power on. Power off: set up the music for power off. Message: set up the message ring tone when a new message arrives. You can also download ring tones online. (2) Volume This allows you to set up the volume for ring tones and keypad tones. There are 7 grades available. Enter this function and use the up/down key for testing and adjusting. (3) Alert type This is used to set up the alert type for incoming calls. Please select the suitable alert types in different situations.
The cadence is different, but you can change all the other rings to a different tone. On a 76xx phone, press PROG and the CO button twice. Press your navigator button up (or down) until you hear the tone you like, then press enter to save.
Select Menu > Settings > sound settings > incoming call > ring tone (now press the i button at the center) and select Default Ringtones. You can select the ringtone here.
Please note, this is for the SGH-U600 model. If you have a different model, please post back with the correct model number.
If you find this solution useful, kindly rate this solution as "Fixya". Thanks.
Thanks, that is exactely what is happening; I will change the speaker.
