Question about Optics
Scope got knocked over, now nothing can be seen through it
  • 10,865 Answers
Hi most likely the fall jarred the lens out of position. You may have to take it into a camera shop for a repair. J.
Posted on Jun 05, 2010
In Which direction do I knock the front sight out
to the wider side of the dovetail, some models doesnt matter, use a pen and a pice of paper to make two reference lines and measure if your not sure
Jan 04, 2015 | Optics
I have a 2000 VW beatle showing a trouble code P0322 Speed Sensor. I checked with Ohms meter and received correct reading? Car cuts off when hot.
Speed Sensor has nothing to do with the engine cutting off
PO322 is a Generic Code for a Knock Sensor
You need to Google your codes & read up
An OHM Meter won't do anything for you on a Speed
Sensor,need a scan tool or scope
I would say you have an overheating condition to correct
& the knock sensor plays a role, wouldn't you think!
Jul 28, 2013 | Cars & Trucks
HI, Just purchased a nextstar 8 and when I tried to view thru the main eye-piece, nothing. Even tried to look at the full moon, nothing again. Yes, all the lens caps are off but it seems like the focas...
Check the focus knob and make sure the small "set-screw" is tight and the knob is just not spinning around on the shaft.
DID you turn the knob enough to focus? Sometimes it may take 10 - 20 full turns.
Finally the focuser is attached to a "rod" inside the tube that moves the mirror back and forth to focus the scope. It could have come loose from the rod?
Instructions for disassembly are here:
http://www.celestron.com/c3/support3/index.php?_m=knowledgebase&_a=viewarticle&kbarticleid=2220
and here:
http://www.sciencecenter.net/hutech/misc/focuslk/index.htm this just shows how it works.
Oct 24, 2010 | Celestron NexStar 8i (600 x 203mm)...
Hello everybody! I have a Powerseeker 127eq, I mounted correctly after I watched a video on YouTube, but I try to watch the moon for example, nothing is seen, only a halo or something that. A few days...
First you must line up the small "finder" scope with the main tube. Go outside during the day time and get a distant object in the eyepiece-- use the eyepiece with the largest number written on it.
Without moving the scope adjust the crosshairs on the finder scope onto the same distant object. Now you can use the small finder at night to POINT to objects in the sky.
Again put the eyepiece with the largest number written on it into the focuser. DO NOT USE the 2x barlow if you have one. Try the moon again, and turn the focuser knob until the moon is sharp and clear.
Sep 27, 2010 | Celestron PowerSeeker 127 EQ 21049 (750 x...
Bushnell elite 6500 scope mark when looking through
i think you have a fungus growing on the lenses inside of the scope all you can do it have it striped and cleaned then re-gased,,and thats pricy
Jul 23, 2010 | Bushnell Elite 6500 Rifle Scope 2.5 - 16 X...
Bushnell Banner .22 scope with loose part inside.
It would be better to replace the minute you disassemble a scope unless resealed with special equipment it will never function as well nor will it be reliable and for a bushnell by time you payed for shipping to and from a repair place you'd be at cost of new so might as get new one which has newer glass types that are vastly better than 20 yrs ago
Apr 05, 2009 | Bushnell Optics
Miss fire in cylinder #1, 1998 subaru legacy outback
fuel injectors getting ground from pcm?
Oct 29, 2008 | 1998 Subaru Legacy
Knock sensor circuit problem
Well, you have another issue besides a knock sensor problem. A knock sensor code WILL NOT illuminate the check engine light. Check for other codes stored in the ECU. I have seen oxygen sensor issues cause knock sensor issues due to inaccurate fuel delivery resulting in engine ping at all times (causing the ECU to think that the knock sensor is bad because it's reporting ping at all times) - but also had codes for one or more O2 sensors.
Nissan Scope Technician- 10 years with Nissan
Oct 26, 2008 | 2000 Nissan Frontier
Optics Logo
29 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
james laughton
james laughton
Are you an Optic Expert? Answer questions, earn points and help others
