Question about Philips 32PT6441/37 32" TV
No sound in my 27 in philips tv.
Can you buy a new sound board if it is cracked
5 Suggested Answers
Slinteriors
  • 8617 Answers
SOURCE: I have a philips 9p6044. where can I buy convergence ic's and a
its far more likely that you need a new Vertical output IC. The convergence ICs wouldnt prevent the picture. When you have audio but no video it is often meaning vertical failure. Try replaceing the vertical IC
Posted on Apr 26, 2009
  • 13 Answers
SOURCE: How to program TV Philips model 275t6210/27 with
try these codes
10054 or 10690
Posted on Aug 21, 2009
  • 5 Answers
SOURCE: philips tv model id: 19pfl5422d/27 terrible loud sound
The issue is 4 1000uF X 10V on the main board under the shield close to the connector that from the power board. you will see them because they will be FAT( exploded)
Posted on Apr 07, 2010
  • 2973 Answers
SOURCE: 37" full hd philips tv screen cracked because
If there is picture in the TV then probably it is the protective screen that has cracked and not the picture tube.Please check carefully.
Posted on Jan 20, 2011
My television's LCD screen is severely cracked. Where would I look for a replacement?
I would highly recommend you recycle the tv or sell it on Craigslist or Ebay for parts. Usually it will be cheaper to buy a new set vs. replacing the screen
Apr 10, 2012 | Philips 32PFL3403D/27 32 in. LCD TV
Philips tv jarred in drop
Tv's don't take rough treatment well,picture tubes and other displays break,circuit boards are easily cracked usually around heavy parts,that sounds like your type problem broken board,if the damage is not severe it may be possable a tech.can repair the broken copper traces but this is becoming more difficult with newer more densely packed circuit boards with thinner and thinner traces many are not repairable and even if a new circuit board is available from the mfgr.it will cost more then a new tv.Good luck
Feb 26, 2012 | Philips 27PT643R 27" TV
Picture wont come up on TV just the sound, i tryed unplugging everything and plugging it back in.
Ur tv the LCD inverter board is dead.Replaced this inverter board ur tv will get the picture back.Tries Websites like Shopjimmy.com,Ebay.com to buy an refurbish LCD inverter board for the replacement.It a long board in shape.
May 31, 2010 | Philips 52PFL3603D/27 52 in. LCD HDTV
Magnavox 19" TV shuts itself off.....won't stay on
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Jun 04, 2009 | Philips Magnavox 27MS343S 27" TV
Attempting to connect PC to Philips 32pfl3403d TV, getting no sig
I had the same problem had to buy a s - video lead then when connected hold in function button n f4 to send the signal
Mar 16, 2009 | Philips 32PFL3403D/27 32 in. LCD TV
Philips tv model id: 19pfl5422d/27 terrible loud sound
Feb 28, 2009 | Televison & Video
Unable to buy ''TA36N30p''
I've looked every where and I am unable to buy these transistors unless I want to buy 200 of them, what a joke, there are 3 options for these boards:
1. Buy 200 of these transistors
2. JVC sell a new version of this board for £50
3. Buy a fault TV on Ebay and take the parts from that.
I'm gonna go for option 3 then I will have loads of spare parts for any future problems.
Nov 25, 2008 | Philips Magnavox 27MS343S 27" TV
Philips 32PT6441/37 32" TV Logo
22 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
