Question about Karcher PSI Electric Pressure Washer
Motor cycles on and off when trigger not depressed
Simple fix...... There is an O ring on the end of the pressure hose that seals it to the pistol grip that the various nozzle wands fit into. The O ring is either cracked, which may not be obvious with a cursory inspection, or a small piece of it may be missing. The O rings harden over time and crack and then start to fall apart. Just fixed mine in 30 seconds with a free O ring from the hardware store. Just make sure it is of the correct diameter and material thickness and everything will go fine. The O ring should appear minutely larger than the brass stem is sits on.
Posted on Jul 14, 2010
Testimonial: "Great answer!"
I have a Bostich coil roofing nailer #RN46-1 leaking air at trigger area when depressed. Replaced trigger assy but same results. Anything else it could be?
Sounds like your gun needs servicing. normally strip, clean and usually fit new O rings to head valve assy, piston & usually sleeve.
Mar 29, 2014 | Stanley Bostitch Rn461 Gun Coil Roofing...
When the trigger is released, the motor stops as it should like it has built pressure. When I depress the trigger the motor cycles like it can't build pressure. The pressure goes up slightly and backs...
only reason you would have scale build up from hard water in a chainsaw, is if you have water inthe fuel.this sounds highly unlikey ,but water in fuel will make saw run like ****
also the laquer build up from 2 stroke oil in fuel mix will make it run bad
spray some carb cleaner in it or have the carb overhauled
Dec 14, 2010 | Garden
Air is leaking through trigger when trigger is not depressed. When trigger is depressed and nail tail cover is in safety position (holding gun in air) it completely stops. The gun fires well but there is...
could be either that or a damaged o ring, when was the last time serviced, all o rings replaced?? could be that the tool needs a thorough cleaning and new one installed. it is not hard
Aug 26, 2010 | Hitachi NV45AB2 Roofing Coil Nailer
My n59fn has huge air leak by the trigger and will not function
I had this problem once and the trigger was defective internally. You should be able to purchase a replacement trigger assembly at the link below.
Link: http://home-and-garden.become.com/tva6-trigger-valve-assembly--compare-prices--c205367842
Cost: $19.99
Hope this helps,
Dan
Apr 22, 2010 | Stanley Bostitch BT200K
My paslode nail gun has gas and full battery but is not firing what is usual problems
could be quite a few problems, to start what is it doing exactly, can you hear the fan come on when the safety is depressed or the trigger is squeezed, if not could be a bad fan motor, electrical short in the board a loose connection, the light on the side, what color is it flashing when you try depressing the trigger, if it is red the battery could be a problem, Let me know some more information along with the model number and I will try and help
Feb 12, 2010 | Air Tools & Compressors
Motor fails to run when trigger depressed
sounds like your armature and field is burnt. once they have both got hot you need to replace the armature and field as well as the brushes and holders.
Jan 24, 2010 | Drills
Karcher K 3.68M Electric Pressure Washer. Wand trigger Locks Up.
Sounds like the pressure valve is broken thats why you cant depress the trigger , the valve is on the pump , i would suggest taking it to a repair shop as they are fiddly things to fix
Jun 04, 2009 | Karcher PSI Electric Pressure Washer
Pump cycles when trigger is not open
it is normal,It is the governor on the engine that does this.
May 07, 2009 | Briggs & Stratton Garden
Karcher PSI Electric Pressure Washer Logo
882 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
