Question about Sta Rite Sr200lp Max E Therm Pool & Spa Heater Dual Electronic Ignition Lo Nox 200,000 Btu Propane Gas
Heater isn't starting...how do I reset? Error
Pool heater isn't starting...how do I reset? Error message appears to be "180 r8"
  • 640 Answers
The users manual for these pool heaters has a very detailed troubleshooting guide. I would start there. A pdf version is below.
http://www.backyardcitypools.com/images/bwp/Max-E-Therm-Manual.pdf
Posted on Aug 17, 2010
My heater displays R8 when I turn it on then it will not start
That is a Circuit Board Logic confirmation code, informing of what 'Revision' it is. Not an Error/Fault code.
we need more info if possible, what is it doing, what have you done, Are getting a fault code? Is the 'service' lite on? Is gas valve on? Is gas supply valve open? Etc.
May 21, 2015 | Pool & Spa
I reset the heater by shutting it off for about
sounds like temp sensor is bad
Sep 27, 2014 | Pool & Spa
Error 180 / r 9
not an error code! part of the start up sequence
Aug 18, 2014 | Sta Rite StaRite SR400HD Max Therm Pool...
Sta rite heater code A20 SFI 828 r8
this is not an error code
Nov 24, 2013 | Pool & Spa
Heater shuts down and message says "Fan Lockout".
Shut off the breaker to the heater and turn it back on to reset heater and clear error code.
Oct 16, 2013 | Rheem 266K to 399K BTU Swimming Pool...
What does R8 code mean on sta rite pool heater
These pool heaters have a very detailed and specific troubleshooting manual that will probably be the most helpful thing for you. They ask very specific questions about what appears on your heater and you will need to be looking at it to troubleshoot. Try walking through the troubleshooting guide below.
Jun 24, 2010 | Sta Rite SR400LP Max E Therm Pool Spa...
I have two error codes: 180/R9 anlong with 128/R8 HELP!
Error pertains to stack flue sensor setting.
There are two modes for low level programming and default is a (0) Zero but for outdoor spas this must be reset to a one ( 1 )
Just hold the off button down for 30 seconds let up, press down again, use arrow buttons on key pad to set from 0 to 1...press off again....play with it and see for yourself...I don't now why Sta-rite buries this information and makes us guess.
Again, on mine, this all pertains to the Stack Flue Sensor setting.... you can look at your heater and see what they look like...outside toward bottom the SF must be a 1 and not Zero or you get the quick flash 128-R8 notice...also, the Stack flue senor is finicky and connections must be good...use steal wool to re-seat but be careful as connector break off easily thus requiring a new stack flue sensor...
I accidentally discovered this when I turned the board upside down and spotted the LED red light on indicating a fault with the SFS**
I wish some one would tell us how to by-pass the stack flue sensor to make the heater work.
Good luck...hopefully the power button is close by and your board is working....
Jan 21, 2010 | Sta Rite Sta-Rite Max-E-Therm High...
Error AD0 SF0 180 r8
the stack flue sensor is bad make sure you order the identical part since is two model for thre same heater
Oct 09, 2009 | Sta Rite Maxi Therm 400k Btu Propane...
R8 Error
dont know what heater yuo got may be a board or temp sensor also post if automatic control
Sep 13, 2009 | Sta Rite STA-RITE CONTROL BOARD KIT -...
Sta-Rite Problem; Error codes R8, Won't stay on.
Its the top membrane where the control buttons are. The circuit board plugs in to it.
Aug 21, 2009 | Sta Rite STA-RITE CONTROL BOARD KIT -...
Sta Rite Sr200lp Max E Therm Pool & Spa Heater Dual Electronic Ignition Lo Nox 200,000 Btu Propane Gas Logo
569 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
steve morris
steve morris
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
