Question about Dryers
Kenmore 11060612990 - unit overheats and cuts off. After cooling down you can restart and after just a few minutes will cut off again. Lent trap is clean and lent exhaust is also clean. Solutions please?
  • 10,319 Answers
Replace the moister control sensor
Posted on Jun 05, 2010
Sime ecomfort plus 30 HE keeps cutting out and shows a flashing green light. Sometimes it will run ok for a couple of hours before cutting out.
I had the identical problem with the same model. Technician eventually diagnosed faulty fan; the fan cools the heat exchanger. When fan fails, exchanger overheats and boiler automatically shuts down. It is possible to restart the boiler when it cools down but when the heat rises again - off it goes! Only answer is to replace the fan. My technician did the same as yours - on first visit he got the boiler running and left. Half hour later, boiler shut down. I read the installation manual and operating instructions and when he called again I pointed him in direction of fan, which had failed completely. These guys!
Apr 11, 2012 | Televison & Video
I have a kenmore dry that seems to hum very load once it heats up. If you turn it off and rest for 30 minutes it will sound fine again until it is 15 minutes into the cycle. What would be the likely...
Hello Bill,
Sorry to be the bearer of bad news,but what your describing sounds exactly what a bad motor will do...run whiles is realitivly cool,cut off when hot the restart after a cool down period and run for a while till hot again.
GENE
Sep 12, 2011 | Kenmore 84072 Electric Dryer
I have a Kenmore Dryer Mod#110 62722101. It will run about 10 minutes and shut off, after a cool down period it will restart but only run about 10 mins. Heats, fine, tumbles fine. A few days before this...
If it runs after a cool down period, then the high temperature limit is part of the cause. What is causing the high temperature limit to overheat is next.
Strong stream of air should be felt coming out the exhaust, make sure this exhaust air works or the burner part will overheat and cut out the flame/burner on hight temp safety.
With good exhaust air varified, the drying air operating temperature sensor needs to be checked, this cuts power to the burner. The sensor must open electricaly when satisified on temperature and should be properly mounted for proper sensing of temperature.
Bottom line: Check the hot air and its control
Jun 04, 2017 | Dryers
My electric Kenmore dryer model # 96591210 shuts off after approximately 15 minutes, and will not restart for at least an hour. If I try to restart it after it shuts off, it will make a humming noise, but...
The first things I would do would be to disconnect the dryer hose and make sure that it is not clogged, and that you have good air flow through to the outside. Then I would check to make sure that your lint trap is clean and able to pass air through it. If you use fabric softner dryer sheets make sure you do a water test on the screen to make sure that it is not blocked.
Then I would try it again. If the same problem occurs then there is a thermal cut off fuse in your unit http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Dryer-Parts/279769/0026/110/Model-11096591210/0582/0151200?keySuffixId=NA&productTypeId=0151200&searchModelNumber=11096591210&subCompDesc=Bulkhead%20parts&brandDesc=KENMORE&modelDesc=ELECTRIC-DRYER&blt=11
Jun 26, 2011 | Kenmore Dryers
I replaced a bad 325 degree thermal cut-off on my kenmore dryer and 30 minutes it went out again. any suggestions?
Two cut off units will not be bad, and they should reset when cooled. Check your air flow. pull the hose off of the back of the machine, turn it on and form an opinion of the volume and force of the air flow.....Hook everything back up, turn on machine, go outside and verify VERY SIMILAR air volume and force.
If the air is restricted, the system will overheat and the limiters will trip.
Dec 24, 2010 | Kenmore 62802 Electric Dryer
Dryer will run for about 20 minutes then it cuts off.
Are you able to restart the Amana dryer right back up when it shuts down? If you can, there is a short issue. If you have to wait a few minutes and you might even hear a faint click, then it will start, your motor needs replaced.....If Ic an help further, I am here.....
Waiting to hear from you,
Eric Campion
Feb 14, 2009 | Amana DLE330RAW Electric Dryer
Kenmore 90 series gas dryer
possible motor overheat ..if unit has a lot of lint or has had vent problems now or in past lint may have accumilated around motor and caused it to overheat and shut off.. probably to late to save motor
Sep 29, 2008 | Kenmore 73952 Gas Dryer
Dyson Quits
cut out switch on the motor needs replacing this overheats and cuts of the motor when the motor cools down it will start again you have to keep both filters and cyclone clean and free of dust or after replacement the same will happen again
Sep 04, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Overheating?
yes - it is cutting out on overheat. there are two fans - which one was replaced - cavity fan or casing fan?
possible reasons are:
faulty casing fan
not enough ventilation
faulty overheat stat
faulty fan stat
oven operating stat faulty but you would be burning your cooking in this case
Dec 21, 2007 | Electrolux EOB5665G Ultrafan Electric...
Dryers Logo
57 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
