Question about Brother GX-6750 Typewriter
A code seems to be stuck in the memory.
When you type the wrong letter types on the paper. I don't know how to clear the code.
  • Brother Master
  • 3,594 Answers
Turn it on, allow it to home, mark the printwheel with some white out.
Turn it off and on a few times if the mark dosen't always return to the same place the homing pawl is broken, you need a tech.
DickyO
Posted on Jun 05, 2010
Why does my typewriter only type the top half of the under-case letters?
There is most likely something interfearing with the type bar segment try ing to lift up, try pulling it up by hand.
DICKYO
Jun 17, 2013 | Royal Office Equipment & Supplies
Keyboard typing wrong letters
Your keyboard is not "typing wrong letters", you have a stuck key. The key is shorting out and is stuck on the letter W. Usually caused by dirt/dust/spills on the keyboard jamming the key so it can't release. Things to try in order of difficulty:
>Vacuum cleaner with brush attachment, vac the keys.
>Paper towel moistened lightly rubbed on the 4 sides of the W key; use a knife blade to gently work down into the edges.
>Soft toothbrush, lightly dampened with water, work the bristles all
all around the edges of the W key. After that do step 2 with a dry
dry paper towel.
>Take the keyboard apart; usually several tiny screws on the rear/sides. CAREFULLY remove the top. You may have to turn the board over, lie on its face to do this. Do not knock the letters out of order or you will have a headache placing them back in proper order! Clear whatever it blocking the W and replace the cover.
If none of the above works the keyboard has failed, needs to be replaced.
Jun 08, 2013 | Samsung Computers & Internet
Load Tray 1 Error Code: 024-965
you are using a wrong paper type setting, whenever in your "MS office" or "pdf reader" or others
if your printer uses letter, just set paper type as "letter" where you print the document, that should work.
Aug 26, 2011 | Dell 3110cn Laser Printer
I got an really old typewriter for my birthday last week and yesterday i deceided to type a letter to a friend on it. When i was testing out stuff, tabs and things like that, my space was stuck. After...
Your typewriter may just need some lubrication. using a 3 in 1 house hold oil, add a few drops to each letter arm at the bottom where it connects.If possible,use a compressed air source to blow out the entire unit (wear saftey glasses of course), the lubricate the moving key areas. This is the best case fix, worst case would be parts need replacement.
Jun 10, 2010 | Office Equipment & Supplies
IBM wheelwriter types wrong letters
Try holding the code key and pressing the "L". If that dosen't do it remove the batteries turn it off wait a minite and restart this will put everything at default setting and clear the memory. If you still have the problem Press code "L" hold down the "L" type 001 to set the keyboard to U.S. If this works you need a keyboard for a permanent repair. For a keyboard contact Geo. Beyers Co.
@ 800-392-8085.
DickyO
Dec 14, 2009 | IBM Wheelwriter 30 Typewriter
Everytime we print we get a beeping sound and an error message that says Change Tray 1 Plain Letter. If we press select, it will print
In the printer setup menu. You need to change the paper type for tray 1. It's likely set to a different type of paper (maybe card stock?).
The printer driver will specify what type of paper is being used, and the printer doesn't know what type of paper is in it other than what it is told, so a conflict occurs.
Oct 13, 2009 | Dell M5200n Laser Printer
WHEN TYPING THE WRONG LETTERS PRINT
Keyboard 99 is Laten supplemental. Try holding down the code key and pressing the x key it should reset the keyboard.
Jan 25, 2008 | IBM Wheelwriter 30 Typewriter
Types wrong characters
If the typewriter is typing letters or symbols that you do not type, it is usually because the Pitch Selector is set to "PS". The pitch selector is on the left hand side and has the numbers 10,12, 15 and PS. Place the selector on 10 or 12 and you will be OK.
Also, check to make sure your printwheel is installed properly. Remove it and put it back in to make sure.
Another thing you can try is to clear the memory. To do this, turn off the machine. Place a piece of paper in the machine sideways. Hold down the MAR REL key and while holding it down, turn on the machine. Wait 2 seconds, then let go of the key. The typewriter will start typing. Shut the machine off after about 15 seconds. Then turn it on as usual. This will clear the typewriter's memory and unexpected charaters should not happen anymore.
Jay @ www.granadahillsbusinessmachines.com
Aug 20, 2007 | Swintec 7040 Typewriter
Brother GX-6750 Typewriter Logo
139 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
