Hoover 700LA: no wash cycles working but will spray rinse and spin dry
  • Washing Mach... Master
  • 713 Answers
Hi just read your posting. Now what wash temperature have you selected for the wash ?Is it cold , warm, or hot?Does it start to fill at all for the wash cycle?I have the same model at home so I know the model well.If it fills and does not wash it could be the timer or the reversing module. please reply and I can guide you throe step by step to rectify this fault.By the way does it finish filling on wash and not start the motor at all?Hope this helps, awaiting on your response.
Posted on Jun 05, 2010
  • washnot Aug 06, 2011
    yes the machine fills, drains and spins but does not agitate. The controller is working and the timer seems to work- it progresses throught the cycles. where is the reversing module?
Hoover troubleshooting
My Hoover Spin Scrub 60 will not spray on the wash setting but will spray on the rinse setting, what is the problem?
Jan 11, 2014 | Washing Machines
Hoover vhd sensor dry 59 minute programme not working
"Rapid W&D 59 Min.
When you only have a few items to wash and dry in a hurry, this 59 minute cycle is the ideal time saver! Suitable for a light 1,5 kg load size (e.g. 4 shirts) or slightly dirty fabrics, this cycle will wash, rinse, spin and dry your garments in under an hour.
We recommend that you reduce the detergent dosage when using this programme to avoid wastage".
If the other cycles work without issue, it in not faulty.
Check the wash weight.
Sep 20, 2017 | Hoover Washing Machines
I need a manual for a Hitachi PAF-1220P i dont understand the s when going throught the wash cycle there does not appear to have a rinse mode. thank you
Reply to rutledge5135 on Apr 11, 2011
(i need a manual for a Hitachi PAF-1220P i dont understand the s when going throught the wash cycle there does not appear to have a rinse mode. thank you)...
The 'S' is for 'Spray' which happens at the beginning of the Spin Cycle...it then goes on to rinse etc.
regards, avery.phill@gmail.com
Apr 11, 2011 | Hoover Washing Machines
Washing machine off balance in one cycle
Make sure washer is on a level surface and all four feet adjusted properly. A slight forward lean may help with this problem as the out of balance switch is at the rear.
Feb 28, 2010 | Washing Machines
We have a Hoover select 1500 washing machine. It still washes and rinses ok, but doesn't then move onto the spin cycle. But I can manually set the dial to spin and restart it. It then spins fine. I assume...
Could be but also could be rinse water valve not operating due to faulty solonoid. it does a final rinse / softner before spinning if valve faulty then no spin advance....
Nov 11, 2009 | Washing Machines
My hoover washing machine won't spray rinse or deep rinse on cold
Rinse cycles are normally with cold water only.
I believe you have a faulty cold water inlet valve. To confirm, put the machine on a cold only wash cycle, and see if it fill up with water.
If it does, then the valve is O.K. In that case the problem you are having with the rinse cycle is most likely a timmer fault.
Good Luck
Ash
Oct 23, 2009 | Hoover Washing Machines
Hoover elite 1210 won't progress to the final 'spray and spin dry cycle'.
Hoping to be of help after the spin dry wouldnt work on our hoover elite 1210.
It would do the wash cycle fine but as soon as it needed to drain, it wouldn't.
My handy man (Husband) is great at fixing things and opened the front panel by undoing the screws.
Near the motor on the bottom left, there is a wheel/fan looking thing.
(Turn the machine off first)
He tried to spin the wheel but it would only move clockwise and not anti-clockwise like it is supposed to.
So he gave the fan a few spins clockwise before giving it a gentle pull outwards in which it loosened the wheel and was able to move anticlockwise again.
We then turned the machine on and it started spinning and draining the machine.
This machine is a work horse and I refuse to get another. They don't make them like they used to!!
Mine has a leak and we use a drip tray underneath at the moment. So long as it works. I am happy.
Hope this helps someone else with the same problem.
Sep 21, 2008 | Hoover Washing Machines
Best temperature and spin cycle setting to wash cottons !
White cottons-Hot wash/Cold Rinse /high spin sycle
Colored Cotton Cold/Wash/Cold Rinse/ high spin cycle
Aug 21, 2008 | Hoover Washing Machines
Hoover hse 130m washing machine problem
i found a squirt of wd40 worked wonders
May 27, 2008 | Hoover H130E Front Load Washer
Washing Machines Logo
98 people viewed this question
Top Washing Machines Experts
