Question about Belkin F1DK102P 2-port KVM Switch
HOW DO I SWITCH PORTS?
I have used this switch before but I stopped when we moved our
business. soooo, I forgot how to switch ports from 1 to 2 to 1.
there is no physical switch.
    Scholar:
  • 60 Answers
I've never used that switch personally, but the standard for these kinds of switches of any brand is to hit Scroll Lock twice. The manual for this model says you need to press Scroll Lock twice then the Up arrow or Down arrow. Here is the link for the product manual: http://cache-www.belkin.com/support/dl/p74242-d_f1dk102p_manual.pdf
Posted on Jun 06, 2010
What's the difference between the Cisco 3850 and 3750-X series switches?
The difference between them as below, hope can help you to choose the best switches on your business.
1.Stacking bandwidth: 3750X for 64 Gbps while 3850 for 480 Gbps
2.Cisco IOS software wireless controller: 3750-X has none while Catalyst 3850 has
3.Queuse per port: 3750 has 4 while 3850 has 8
4.Quality-of-service model: 3750 with MLS while 3850 with MQC
5.Uplinks: 3750 be equipped with 4 x 1GE2 x 10GE NM4 x 1 GE or 2 x 10GE SM
3850 be equipped with 4 x 1GE2 x 1/10GE4 x 1/10GE(on 48 port model)
If you still have any question, you can log in
http://www.3anetwork.com/cisco-switches-price_c1
to know more about the datasheet and specification about the Cisco switches.
Jul 31, 2014 | Cisco Computers & Internet
AT-8000GS/24 reset password with out reset button
Forgot or lost the password
Contact Allied Telesis Technical Support for assistance.
Apr 22, 2014 | Allied Telesyn ?AT-8000GS/24PoE 24-Port...
Scroll lock + ?
Try scroll lock plus the number of the switch you want to move to, for example scroll lock + 1, etc.
Apr 15, 2014 | CP Technologies CP TECH LevelOne KVM-0421...
Problem with cisco sg500
I'm not familiar with the device, but it might be something in the configuration. It could be DHCP, it could be something deeper.
I suggest contact Cisco support directly, they have support forums too.
Dec 11, 2013 | Cisco Small Business 500 Series Stackable...
I forgot password of my linksys switch srw224g4. can anyone help me in this regard
[1] Connect to the console port using terminal emulation parameters (typically 38400, 8, 0, 1, None) [2] Reboot switch (Remove power) [3] Hold down Ctrl U while rebooting --[a] Menu will be displayed [4] Select> [D] Delete file [5] Type startup-config (be sure that this is the ONLY file that you delete - if you delete other files, you[ will have to reload the firmware) [6] Now, you have erased the configuration file and you should be able to reboot and login with the default username and password.
Mar 14, 2011 | Linksys SRW224G4 24-Port Ethernet Switch
How to connect 4computers with Swith or Hub
A switch or hub isn't very complicated.The primary benefits are connecting more than 1 computer and/or increasing the range of your wired network.
On the back of your switch,all you do is plug in each computer using an ethernet cable,plug in the switch power supply,and turn it on.The only caveat being if you're using 1 PC to connect to the internet,it should probably be plugged into port #1.It probably doesn't matter,but I'm not familiar with your brand of switch.
If this helps,would you please rate my post?
Thanks
Bob
Aug 15, 2010 | Network Computing Devices (NSH800S/A)...
Moved into house. Craftsman Garage Door Opener Model 139 18052 not working. Trolley won't move away from stop, chain loose, wires were not connected. Connected black to black port, red to red port, one...
YOU WILL NEED TO UNPLUG THE UNIT AND TAKE OFF THE COVER.
ROTATE THE MOTOR BY HAND UNTIL IT BACKS OFF FROM THE STOP - WHEN IT IS JAMMED NOTHING WILL WORK.
YOU SHOULD HAVE 2 WIRES WITH BLACK TRACE ON THEM 3 WHITE AND 1 RED TRACE.
YOU HAVE THE COLOR CODES RIGHT.
YOU CAN GO TO LIFTMASTER.COM AND DOWNLOAD A MANUAL FOR A SIMILAR UNIT - THEY MAKE THE CRAFTSMAN BUT USE A TOTALLY DIFFERENT MODEL # SYSTEM
HOPE THIS HELPS
Apr 30, 2010 | liftmaster Chamberlain Garage Door Opener...
Line 2 button light blinking, can't clear (and I have no line 2?)
Ok, i just figured this out a few min after posting the similar question. Reconnect your phone line to the data port and reselect the line one or line two selector swith position until the light goes out. I removed the phone from the wall to paint an must have accidently moved the switch. If the switch and the input port are out of sync you will get a red light on line one or two. Good luck!
Mar 13, 2009 | RCA ViSYS 2-Line Speakerphone
NTL codes for Eurovox Dublin.
12/1/09 IRE= 5401 B0 B8 4F 04 E6 5F 87 80 /// A3 EB EC 07 D6 49 D2 EB
Jan 16, 2009 | StarTech.com StarView SV211K 2-port KVM...
Casio cash register te-m80
Remove the wall plug and the batteries at the same time, wait ten minutes, put the batteries back first and then plug it back in and turn the key to Reg, you should see a row of zeros across the display as the machine resets itself.
If this doesn't happen the machine is dead and that is very unusual for a Casio.
Aug 21, 2008 | Casio Parts Cash Register PC Desktop
Belkin F1DK102P 2-port KVM Switch Logo
2,511 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
