Question about GE (PSS26MSRSS) Side by Side Refrigerator
Ice build up on coils in freezer GE Profile PS123NC/psI23SC
Works for 1-2 weeks after thawing coils. Then temp slowly increases in freezer. and ice recollects.
  • 973 Answers
You may need to replace the automatic defrost sensor.
Posted on Jun 05, 2010
Hi, I have a ge profile side by side refridgerator that heats up in the freezer, top shel and ice maker area only, will melt the ice, thaws out food on top shelf, happens intermitently, will last for hours...
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Check cold control (thats where you turn it colder)
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME If this was helpful
Jul 29, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Coils in my 2454 packed solid with ice. Thawed it out....worked fine for a couple of weeks. It quit staying cold so I dug behind the freezer to discover the coils again encased in ice. Thawed it...
your defrost heater around the coils is open and can no longer heat,or the adaptive defrost timer or defrost thermistor are defective located in the refrige control panel behind the temp controls and the thermistor is located on the defrost heater assy
May 02, 2010 | Maytag MSD2454G Side by Side Refrigerator
GE 24 Profile refrigerator: The freezer part
my refrigerator goes into auto defrost every 60hrs for 45 minutes or till the bi metal(defrost thermostat) says it had enough....recently i had ice built up on the coil because my defrost thermostat was stuck open...
ice builds up because the moisture that comes from opening the door or food condenses on the cold coil...tempurature of the coil is below 32 degrees which will ice up the condensed moisture...
defrost is timed to remove this build up
Oct 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer keeps thawing. There was an ice build up.
Check the "flap" in the door where the ice is released. If it has come undone it will thaw the ice in the maker and into the freezer...
Jul 10, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice build-up around the fan making a noise.
Drain line froze.
Used hair dryer to thaw frozen line, works OK now. 01/07/09
Think the frozen drain line was caused by the light in the refrigerator not shutting off when the door closes, causing excess cooling in the freezer. Poor design on the light shutoff switch, corrected design to make permanent repair
chestnutlee.
Dec 27, 2008 | GE Refrigerators
GE side by side not working
Defrost cycle not functioning. Could be defrost timer, timer motor, or defrost heater. I detailed this for someone else. see other solutions.
Nov 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge profile refrigerator mod# tcx18paaarbb
drain tube is blocked .....you need to thaw it and after thawing clear drain tube all the way to condenser water tray in back
Apr 02, 2008 | Refrigerators
Auto defrost problem GE Profile PTC22MFMARWW
no relay stucks...you say once a year?..could be in winter time?...it could just be normal...try to increase the temperature setting on the thermostat on these times of the year. to increase the temperature of the coils to minimize frosting build up.
Feb 14, 2008 | Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
334 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
