Epson Stylus NX400 InkJet Printer Logo
Posted on Jun 05, 2010
Epson Stylus NX 400 won't start I only have an error message as follows; A printer error has occurred, Turn off the printer then press On button to turn on. I do that and nothing happens except same screen and message
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jun 05, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
978
Points
Need to install at my computer
  • Anonymous Jun 05, 2010
    need to install at my computer
5helpful
Printer TX550W has message "A printer error has occurred. Turn off and then on. See your documentation".
Hi, this error message usually caused by jammed papers or foreign objects inside your printer. To resolve this issue, please try the following steps.
1. Turn off the printer.2. Open the scanner unit.3. Check for any jammed papers or foreign objects then remove it.4. Check the ink cartridges and lids if push down fully.5. Close the scanner unit.6. Turn on the printer.
If the same error reappears, try the following.
1. Turn off the printer.2. Open the scanner unit.3. Remove all the ink cartridges.4. Turn on the printer >> your printer will display install ink cartridges.5. Install all the ink cartridges, make sure it clicks into place and also the lids should be push down fully.5. Close the scanner unit.6. Press the Start or OK button to charge the cartridges.
If the issue persists, your unit will require service. Please contact Epson so they can check if your printer is still under warranty or ask them for the nearest service center in your area.
2answers
Epson cx3200 printer has printing problem
Hello cockie ,
You can diagnose most problems by checking the control panel LED's for ink out, paper-out or copier problem.
If a problem occurs while you're printing, you'll see an error message in the progress window on your computer.
It may also be helpful to try running a printer nozzle check.
See the following message problems and solutions:
Error Message Probable Cause No color or black ink cartridge - - >
Press the Color Copy button to install a new ink cartridge.
The indicated cartridge is not installed or it is installed incorrectly. Color or black ink out - - >
Press the Color Copy button to begin replacing the ink cartridge.
The indicated cartridge is out of ink Ink cartridge error - - >
There is something wrong with the ink cartridge. Paper jam or misfeed - - >
Press the Color Copy button and clear the paper jam by hand if necessary.
Paper is jammed. Press the Color Copy button to clear the jam.
See the User's Guide for more troubleshooting tips.
Paper out - - >
Load paper in the sheet feeder and press the Color Copy button.
Paper is out. Load paper in the sheet feeder, then press the Color Copy button to continue printing. Scanner unit open - - >
Scanner cover open. Carefully lower the scanner cover and press it down until it clicks securely into place. Scanner error - - >
See your documentation and call Service if necessary.
Press the On button to turn off the EPSON CX3200. Check the transportation lock and unlock it, if necessary. Turn on your EPSON CX3200 again. If the error message still appears, contact your dealer or EPSON. Printer error - - >
Press the On button to turn off the EPSON CX3200, then press it again to turn it back on. If the message still appears, contact your dealer or EPSON.
How do i replace the ink cartridge on an epson stylus nx 400
to replace ink before they run out..
You can view on-screen instructions for replacing an ink cartridge using the printer maintenance utilities.,click the button on the Maintenance tab. then select Ink Cart Replacement and follow the instruction from there on.
12helpful
3answers
Epson Stylus dx8400 error message "a printer error has occurred"
unplug, and replug the power cord, then try to power on, after that try to open the carriage and check for any obstructions that maybe locking or obstructing the path of the printer head from moving left to right.
1helpful
2answers
My Epson NX 400 is giving me this error message:Error B88/69/68 C
Try to run the ink pad reset utility software.
Please log on to epson.com. The software runs on win xp and win vista.
1helpful
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
3helpful
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
