Question about LG Electronic Window Air Conditioner
Mt timer butoon is stuck on timer so unit wont work
  • 1,543 Answers
All LG room air conditioners should be able to be operated without using the remote, by just using the controls on the unit. Replacement remotes are available from an LG service provider.
Posted on Jun 05, 2010
Transported fridge now wont start
Be sure there is still power to the unit, could be stuck in defrost and need a new defrost timer
Dec 01, 2013 | Electrolux ER7620C Refrigerator
The unit I'm working on has a 1 month old 8145-20ex and now the unit wont go into defrost - The compressor and the evap do not stop and the heaters do not energize. I'm thinking the defrost termination...
Copy following links:
http://waterheatertimer.org/Paragon-timers-and-manuals.html#8145
http://waterheatertimer.org/pdf/How-to-test-Paragon-8145-timer.pdf
8145-20 is 240Volt defrost timer.
The defrost cycle will not begin. This implies that trippers are not in place, or trippers are worn out.... or limit switch is stuck ON or solenoid inside timer has gone bad.
Test across terminal N to X for 240Volt. Because voltage here will stop defrost cycle by activating solenoid inside timer, but continuous voltage will also stop next defrost cycle from beginning. Disconnect wire on terminal X and see if defrost cycle will begin at next tripper. If defrost begins, then limit switch is bad.
Gene
h
Aug 06, 2013 | Hardware & Accessories
The unit won't turn on or off. I've changed the battery but still no response. also the reset button is stuck and won't work
A stuck reset switch keeps the timer in a rest mode so that nothing else will function. Try to operate the switch so as to free it. Then reprogram the timer if you are successful.
Dec 30, 2010 | Intermatic Inc. ST01C Digital In-Wall...
I can use the touch screen but my keyboard and other butoons wont work. i cant turn it off
Take out the battery without turning it off, if that doesn't work looks like you might have to take it back and get it fixed.
Dec 24, 2010 | LG GW525 Cell Phone
My Malibu ML600TW power pack is stuck in the ''on'' position
There are no repair parts for intermatic/malibu power packs.
You can buy cheap plug-in timer, and plug power pack into cheap timer.
For more information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Oct 20, 2009 | Intermatic Malibu 300W Power Pack...
Kenmore refrigerator wont turn on.
your defrost timer is stuck locate it its recessed and on most units is near the controls or down below the front grille will need a screwdriver or butterknife turn clockwise unit will then start if sticks again replace the timer
Aug 29, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Timer stuck on dry
i have Miele electronic G562 dishwasher which gets stuck in cycle exactly on 1/2 way main wash when the water is is comming in can i fix it myself?
Dec 21, 2007 | Dishwashers
Wont turn on
Does the unit have a defrost timer??It may be stuck.Let me know,Mike
Nov 21, 2007 | Master Bilt 18.1 cu. ft. Commercial...
Timer stuck on cycle will work if manually moved
The timer has a small motor that advances it through the cycles. It either works or it's DOA. unfortunately you probably have to replace the timer complete.
Nov 01, 2007 | Roper RAS8445KQ Top Load Washer
LG Electronic Window Air Conditioner Logo
367 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
