Question about Tappan TGF320 Gas Kitchen Range
I have a Tappan TGF320 and the oven quit working. The auto pilot is lighting up brightly but the main burner is not lighting. Where do I start?
  • markrussom Jun 10, 2010
    It has a glow light pilot and that is working, just no main burner. What do I do to fix?
  • 11,896 Answers
The main burner is the heating element, they can go bad. If the pilot is light, that is a good sign, You can replace the heating element (main burner) or remove it to make sure there is debris inside of it. Do make sure all parts are securely in tact. There should be a diagram on partselect . com that shows you all of the parts.
Posted on Jun 10, 2010
  • 6,487 Answers
That pilot that heats the safety element pictured lights off a standing pilot (constantly on) or a small glow coil. If the glow coil does not glow, it will not ignite the pilot flame.
If there is (or should be) a constant burning pilot flame just above the larger actuating flame that heats that element is not burning or will not light, the orifice is clogged. Smaller constant on flame will be located on the pilot assemble as will be the very tiny glow coil, which ever system is used.
Posted on Jun 08, 2010
    It has the glow pilot and it is working just no main burner light. What do I have to fix?
Tappan 32-1272-10/07056-8509-4080 gas range/oven pilot light works,main oven burner won't come on
You will need to look and see if the igniter is glowing a bright red. If it is weak, the oven will not light. Here is the igniter if you need to order it.
Also check and make sure your getting 3.2-3.6 volts AC to the valve.
Dec 01, 2012 | Tappan TGF320 Gas Kitchen Range
Pilot light lights but burner wont in gas oven
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
ssg
Sep 30, 2010 | Tappan TGF320 Gas Kitchen Range
I'm trying to light my tappan oven...can't find the pilot
Your oven doesn't have a pilot,it has a flat surface igniter.If the igniter is bad or not getting the correct voltage,the safety will not allow the gas valve to open.This being said,I will say any repair involving gas is best left to a qualified tech.If its just the igniter its pretty easy to check it with a ohm meter.It should glow bright red when its calling for the oven to ignite.Hope this helps
Jan 07, 2010 | Tappan TGF320 Gas Kitchen Range
Our tappan oven won't light. the pilot element lites and glows but no gas to the burner
Either the safety valve is stuck or the ignitor is weak. While the ignitor is glowing. use the handle of a large screwdriver to tap on the valve body. If it lights replace the ignitor. If it does not light replace both the ignitor and the safety valve.
Eric
Nov 08, 2009 | Tappan TGF320 Gas Kitchen Range
Oven does not light
If no gas at all is coming from the oven burner, then it sounds like you need a new gas valve. If the pilot lights but the main burner does not then its the thermocouple.
Nov 03, 2009 | Tappan TGF320 Gas Kitchen Range
Tappan gas range electric pilots will not light
The gas line in your Tappan could be closed or
stucked up. Have it check.
Sep 23, 2009 | Tappan TGF320 Gas Kitchen Range
Where is the pilot light for the oven?
Look inside the oven where the burners come into the oven. Right at that point you should find the pilot light. Here is where you light the pilot.If you smell a lot of gas when you open the door, turn off the gas altogether and let it dissipate. Then turn ot on and then you can light it.
Jan 30, 2009 | Tappan TGF320 Gas Kitchen Range
Tappan Stove 5 burner with Oven
does the pilot seem low?you can remove the pilot then clean it out,let me know.
Nov 10, 2007 | Tappan TGF320 Gas Kitchen Range
Tappan Gas Range Oven Will Not Light
probable displaced burner assembly, faulty flame failure device or blocked burner or jet. Regards Engineer
Jul 20, 2007 | Tappan TGF320 Gas Kitchen Range
Tappan TGF320 Gas Kitchen Range Logo
94 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal DeAngelo
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
